POV-Ray : Newsgroups : povray.newusers : hemisphere Server Time
30 Sep 2024 16:17:53 EDT (-0400)
  hemisphere (Message 1 to 9 of 9)
Subject: hemisphere
Date: 14 Jun 2004 19:35:01
Message: <web.40ce359f86b59361dc24a13d0@news.povray.org>
is there a way to make a hemishere?
Subject: Re: hemisphere
Date: 14 Jun 2004 21:20:54
Message: <40ce4ef6$1@news.povray.org>
"FCB" <nomail@nomail> wrote in message
news:web.40ce359f86b59361dc24a13d0@news.povray.org...
I'll answer with one complete simple solution, but if you're asking about
something more than what's shown below feel free to ask more.
/* BEGIN simple hemisphere */
camera {location -4*z look_at 0}
light_source {-100*z,1}
#declare Hemisphere=
intersection {
  plane {-y,0} // could use x, instead of y, for East/West
 // negative y for northern hemisphere, positive for southern
  sphere {0,1}
  pigment {color rgb <1,1,1>}
object {Hemisphere
  rotate < 15 , 0 , 0 > // to turn whichever way needed
  translate -1.25*x} // put on left side
/* and to hollow it out... */
difference {
  object {Hemisphere}
  sphere {0,1 // cutaway object
   pigment {color rgb <1,0,0>}
   scale 0.9 // scale for thickness ( nearer 1 is thinner)
  translate 1.25*x // put on right side
/* END */
Date: 15 Jun 2004 06:11:20
Message: <40cecb48$1@news.povray.org>
Hughes, B. nous apporta ses lumieres ainsi en ce 14/06/2004 21:20... :
>intersection {
>  sphere {0,1}
>object {Hemisphere
>difference {
>  object {Hemisphere}
>/* END */
I prefer to use a box instead of a plane like:
intersection{
    sphere{0,1}
    box{<0,1.1,1.1>,-1.1}
    pigment{MyPigment}
    scale MyScale
If you want an empty hemisphere, try this:
difference{
    sphere{0,1}
    sphere{0,.9}// adjust for the thickness you want
    box{<0,-1.1,-1.1>,1.1}
    pigment{MyPigment}
    scale MyScale
That way, the bounding is more efficient (tighter)
Date: 15 Jun 2004 07:31:59
Message: <40cede2f$1@news.povray.org>
"Alain" <aze### [at] qwertygov> wrote in message
news:40cecb48$1@news.povray.org...
> >intersection {
> >  sphere {0,1}
> intersection{
>     sphere{0,1}
>     pigment{MyPigment}
>     scale MyScale
I was going to concede about this until I decided to try a test of the two
ways.
Yours parsed and rendered slower, than mine, (in version 3.6) over several
runs, rather consistently too. I put them into a while loop, making a
150X150 grid facing the camera. Output image resolution was 1280X1024 and
default AA used. I kept the number of objects down to prevent going to XP's
Page File, so it wouldn't interfere.
plane = Parse: 1 to 2 seconds Render: 19 to 20 seconds, or averaging 21
seconds total.
box = Parse: 2 to 4 seconds Render: 23 to 24 seconds, or averaging 27
seconds total.
Perhaps imprecise, being so short-lived, but I believe it is showing the
introduction of the box is actually causing a loss of optimization or
something. I don't know the truth behind the numbers; it just looks like the
plane has an advantage, at least in this case.
Bob H.
Date: 15 Jun 2004 14:05:00
Message: <web.40cf39d319bfb51fa0c272b50@news.povray.org>
This may go right to something I have wondered for a while.  When using a
plane in CSG, how is the bounding box determined?  Per the docs regarding
manual bounding, the automatic bounding uses the size of the objects used
in the CSG, but I'm thinking here that infinite is not used...
RG
Date: 17 Jun 2004 19:12:33
Message: <40d22561$1@news.povray.org>
> RG
I'm not sure if this is it, but I'd image that in a difference it only
needs to take the bounding box of the first object and that in an
intersection it only needs the bounding box of the smallest object.
Shalom Naumann
Date: 17 Jun 2004 22:03:52
Message: <40d24d88$1@news.povray.org>
Hughes, B. nous apporta ses lumieres ainsi en ce 15/06/2004 07:31... :
>ways.
>seconds total.
>seconds total.
>Bob H.
OK. Aparently, when removing a plane, an infinite object, the bounding
is limited to the original object, but when removing a box, a finite
object, the bounding encompas both objects. Did you try both
intersection and difference?
Date: 18 Jun 2004 05:08:04
Message: <40d2b0f4$1@news.povray.org>
news:40d24d88$1@news.povray.org...
> Did you try both intersection and difference?
No, had not. Have now, here are the results:
I= parse 3 sec.; render 20 sec.
D=parse 4 sec.; render 25 sec.
I had to change the -y plane to +y in order to get the same object, and move
the sphere to first place in the CSG, other than that it's all the same as
before.
Oh yeah, and the box isn't <1.1,0,1.1>,-1.1, like the originally suggested
one, I tightened it up some and went with a <1.01,0,1.01>,-1.01. However,
also checking into using either one of these isn't showing any true change I
can be certain of; only a peculiar instance of a 2 seconds parse when I
moved the negative corner ahead of the positive, which hasn't occured again.
That shows an unworthiness to my tests but the ones done between plane or
box and intersection or difference are still very consistent, even if it is
a mere several seconds of time.
Bob H.
Date: 21 Jun 2004 11:52:01
Message: <web.40d268a619bfb51f69cbdc8c0@news.povray.org>
Im not too sure about bounding objects, but in the case of a difference from
a sphere it makes sense that a planar difference is more efficient than a
boxed difference.
This is because the plane only has 1 component; that is...plane exists if
y>0 and plane doesn't exist if y<0. So when cutting it out of a sphere only
one component of the sphere needs to be checked, in this case the y
component.
For a box; the sphere needs to be checked against all 3 components <x,y,z>.
Is this right?
387
> >ways.
> >seconds total.
> >seconds total.
> >Bob H.
> Alain
