POV-Ray : Newsgroups : povray.newusers : Can't Access Certain Commands in Tools Server Time
8 Apr 2026 23:49:34 EDT (-0400)
  Can't Access Certain Commands in Tools (Message 18 to 27 of 47)
Subject: Re: Can't Access Certain Commands in Tools
Date: 18 May 2004 16:50:00
Message: <web.40aa75bc27c58a6a6b9afb860@news.povray.org>
> Ok.. First off, it can't 'run' POV files. It can only take images and
> compress them into a video stream. So, what you need to do is run the
> clockdemo.ini file inside POVRay. The ini file includes the information
> needed to tell POVRay how many frames to create, etc. These frames will
> probably be called something like clockdemo1.bmp, clockdemo2.bmp, etc.
> You need to select the clockdemo1.bmp file in TMPGEnc, since that is the
> 'first' image in the sequence you want to make into a movie. TMPGEnc will
> then run you through a series of screens for various settings, unless you
> know what you are doing, ignore these. Finally it will reach a screen
> with the 'output file'. This will likely be something like clockdemo.mpg,
> so unless you want to name it something else, you can also leave that
> alone. TMPGEnc should then read in each file one at a time, until it
> reaches that last bmp file with clockdemo in its name, followed by a
> number. Really simple. ;)
> Now, as for the .ini files in povray. Most do not include a line
> specifying the 'type' to produce. This means that unless you have done
> what I did and edited povray.ini to change the default to png (I did this
> because I don't have the space for the 100+ images some animations
> generate), it will default to the 'system' type, which in windows is
> .bmp. If you change this default in povray.ini or in the clockdemo.ini,
> file instead. However, if you use this type, you 'must' install the vfpng
> files I mentioned first, since TMPGEnc doesn't know how to read them
> without it. If you have lots of drive space (like an 80GB drive or
> something), then this is going to be a lot less of an issue than for me.
> lol In that case, you can probably stick with .bmp and be OK. At least as
> long as you eventually delete all the original images after you have a
> mpg video you like. ;) lol
That's odd. I'm using POV-ray version 3.5. The tutorial that came with
version 3.5 said that the older versions required the manual creation of
separate frames in a sequence, each frame with its own name. The tutorial
said that the new version I'm NOW using doesn't require that, anymore. The
tutorial said that I do not need a separate batch script and no external
sequencing programs. Apparently, the command line can be used to activate
an internal animation sequence that causes POV-ray to automatically handle
the animation loop details for me. All I'd need to put into the ini file
are "Initial_Frame=1 Final_Frame=20" if I wanted to generate 20 frames for
the animation. I could also have the option of putting "Initial_Clock=0.0
Final_Clock=2.0" if I wanted the clock to cycle through values other than
the default of just 0.0-1.0. Then, I also have a third option of adding
"Subset_Start_Frame=7 Subset_End_Frame=12" if I wanted to view just frames
7-12 in an animation of about 20 frames. After that, I just render the
whole animation at once. I don't think your explanation coincides with the
version of POV-ray I'm using. Do you recognize any of the stuff I put up
above?
Date: 18 May 2004 17:11:56
Message: <MPG.1b1429c190150a6c989a4e@news.povray.org>
In article <web.40aa75bc27c58a6a6b9afb860@news.povray.org>, nomail@nomail
says...
> above?
Ok, yes, you can use the command line parameters to specify both file
type, the number of frames, etc. I am used to using the GUI and frankly
never saw any real point to running it from the command line, so
basically using the command line in this case is just like using the INI
file. All the INI file really does is provide POVRay with the command
line options in a file you can run from the GUI. The results are exactly
the same.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 18 May 2004 19:25:14
Message: <40aa9b5a$1@news.povray.org>
Patrick Elliott nous apporta ses lumieres ainsi en ce 2004/05/18 17:10... :
>says...
>>above?
>the same.
In the windows version, there is a "command line" box nexe to the quick
res drop-list. For a 20 frame animation you just put +kff20 there, start
the render, sit back, and you get your 20 frames animation.
You can input parameters far longer than what you can see in the box,
separate each parameters by a space.
Look section 5.2.1 (Animation Options) in the documentation.
+kfi<val> = initial frame
+kff<val> = final frame
+ki<float> = initial clock
+kf<float> = final clock
+sf<val> = start subset frame (+sf0.<val> for % position)
+ef<val> = end subset frame
+kc = cyclic animation
Date: 19 May 2004 03:28:44
Message: <40ab0cac@news.povray.org>
In article <web.40aa75bc27c58a6a6b9afb860@news.povray.org> , "CFM"
You are confusing batch scripts and INI files.  INI files store the render
options.  The manual explains how to use INI files.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 19 May 2004 16:50:00
Message: <web.40abc81027c58a6ac3f22c770@news.povray.org>
> >the same.
> Alain
OK, I rendered the POV-ray file clockdemo.pov, and the program renders the
20 frames, one after the other. I don't consider that an animation. It's
too slow. I still cannot figure out how to use TMPGEnc to run it in faster
speed. If TMPGEnc only compresses multiple frames with different file names
into a running video stream, then it would not work in this case since all
20 frames are created in just one file: clockdemo.pov. It looks to me that
the version of POV-ray that I'm using renders multiple frames in only one
file. It's not one frame per file, but 20 frames in a single file. So if
TMPGEnc won't work with this, then what will?
Date: 19 May 2004 18:28:50
Message: <Xns94EF4E32A352seed7@news.povray.org>
in news:web.40abc81027c58a6ac3f22c770@news.povray.org CFM wrote:
> It looks to me that
> one file. It's not one frame per file, but 20 frames in a single
> file.
There is no official version of POV-Ray that renders all frames into one
single file (and no un-official onne that I know off).
Are you looking in the right directory for the resulting images?
In your povray.ini file, is there a line that starts with
Output_File_Name=...? If so, what does the whole line look like?
Ingo
Date: 19 May 2004 18:56:26
Message: <MPG.1b1593b5ac824b37989a51@news.povray.org>
In article <web.40abc81027c58a6ac3f22c770@news.povray.org>, nomail@nomail
says...
> > >the same.
> > Alain
Umm. What??? Try looking in the folder with clockdemo.pov. Unless you
have changed the master file (povray.ini), then by default all 'frames'
are outputed into that same folder as clockdemo1.bmp, clockdemo2.bmp,
clockdemo3.bmp, etc. These are the actual animation that gets generated.
Lets put it this way.. Think of the clockdemo.pov file like a set of
instructions for a photographer. You give him a folder named "clockdemo",
which contains the instructions on 'what' to photograph (clockdemo.pov).
However, your sticking a post-it note on the outside (your command line
options), and telling him to ignore the instruction in the folder
(clockdemo.ini). He takes out the .pov instructions, sets up his camera
in front of the stuff it tells him to take pictures of, then starts
snapping photos according to your instructions on the post-it note. Each
photo he takes (he is using a Polaroid, so the develop themselves each
time one is snapped), he numbers it and drops it into the folder. Once he
has all twenty, he hand the folder back to you, with each of the numbered
photos in it.
I think what is confusing you is that POVRay only 'takes' the snapshots
and shows the one 'currently in front of the camera'. It doesn't have any
way to look at all the ones it previously took. You need a program like
Photoshop, Paintshop Pro, Gimp, etc. to look at each of the snapshots.
What TMPGEnc does is take each of those individual snapshots and stick
them together into a movie. The images needed to do this are *not* in the
clockdemo.pov file, but they 'should' be in the same folder though and be
numbered 1 through 20.
If they are not there, then try looking in a couple of other places. The
first place to look, if you are running it using the command line thing
'inside' POVRay is in the directory POVRay itself runs from. It is
possible, since you are not using the normal method of running it, that
it could be placing them there instead, but I doubt it. If you are
running it from a DOS window, try looking in the same place as you ran it
from in there. If you still can't find it, then look in povray.ini for
the line:
Output_File_Name= ...
If this line exists, then it should only contain a directory. All images
you create with POVRay will be created in 'that' folder. Normally this
line is empty or blocked out so it doesn't do anything. I don't remember
which. In any case, someplace, somewhere you have a set of files called
clockdemo1.bmp through clockdemo20.bmp or something similar. If all else
fails, open a DOS window and type "dir clockdemo*.* /s/p". If the files
are anywhere on you hard drive, it will find them. TMPGEnc needs the
'first' one of those files, **not** the .pov file.
void main () {
  else
Date: 22 May 2004 17:25:00
Message: <web.40afc50027c58a6ad5551b880@news.povray.org>
> photos in it.
> the line:
> void main () {
>   else
OK, I think I spotted the problem. I couldn't understand you. I assumed the
version of POV-ray I'm using rendered all the pics in one file:
clockdemo.pov. Instead, my program rendered each picture and automatically
stored them in a separate FOLDER somewhere else. I found them in the
POVimages folder (clockdemo, clockdemo00, clockdemo01, etc.). Now what? Oh,
BTW, there are many other images in that folder besides those from the
clockdemo. Should I seclude them into a separate folder?
Date: 22 May 2004 17:52:43
Message: <40afcbab$1@news.povray.org>
CFM nous apporta ses lumieres ainsi en ce 2004/05/22 17:24... :
> <snip>
> Oh,
You don't need to. Some of those may be used by some sample cenes, and
need to stay where POV Ray expect them to be. You can move them
somewhere else, but be prepared to move them back if some renders return
an error. Check presisely what the error say.
Date: 22 May 2004 18:56:19
Message: <MPG.1b1987e747a913b8989a55@news.povray.org>
In article <web.40afc50027c58a6ad5551b880@news.povray.org>, nomail@nomail
says...
Yes. POV-Ray can't place anything into a single file. There is no version
that I know of that can or does do so. It is intended only to generate
each separate 'frame', requiring you to connect them all together in a
movie.
Don't worry about secluding the images. You could copy them all into a
separate folder if you want, but it isn't necessary. The one merely
called 'clockdemo.bmp' may be a problem though. In general if the image
doesn't have a number, then it is a 'still' image, not part of an
animation. What likely happened is that you ran clockdemo.pov without
animation turn on, so POV-Ray generated a single still image from it.
This image is "identical" to clockdemo00. This will be a problem when you
run TMPGEnc, since that program looks for 'all' files that start with a
name + numbers. The result will be:
In other words, it will incorrectly believe that the one without any
number is the 'first' frame in the animation, even though it is actually
a duplicate of clockdemo00.bmp. So, unless you move all the rest of them
into a separate folder, you will need to delete the one that only shows
'clockdemo', with no numbers.
Now, when TMPGEnc loads and you pick a movie type is will ask you:
Video File:                    [Browse...] <- click this button
Audio File:                    [Browse...]
Select 'clockdemo00.bmp' from the folder with all the images in it.
TMPGEnc will automatically shorten it to 'clockdemo.bmp', so when it is
making the movie, it will first look for 'clockdemo.bmp, then
'clockdemo00.bmp' and so on, until it runs out of files with that name.
Basically it is asking you for either a) an existing movie file to import
or b) the first 'frame' of a series of numbered images to make into one,
which is what you are trying to do. ;) Don't bother with the audio
option, it will automatically set that to the same file(s), unless you
specifically need to use one. Click "next" until you get to a page that
asks for the "Output File:". The other pages have a bunch of setting that
only an expert will likely know how to manage. At this point you can
change where it will place the file or the name it is going to use, just
make sure it has the right extension (.mpg for normal movies or .m2v +
.wav) for DVD).
By default it will put the finished movie in the same place as the images
used to make it, so you can probably leave this alone to and just click
the "OK" button. It will them tell you that 'clockdemo.mpg does not
exist' (or something similar) and ask you if it should create it. Click
OK. It should then pop to a screen that will show frames being loaded and
put into the file. This screen will also show the Input, Audio and Output
files it is using. Just sit back and watch it build the file. Once the it
shows 100%, your movie is finished. ;)
You can also use the Setting button and other options on this page to
fiddle with how the movie is made, but all this stuff is automatically
set by the wizard, which is generally good enough, unless you know what
you are doing. In any case, now all you need to do is open up the new
clockdemo.mpg file in your favorite player and watch the animation. ;) Is
is going to be short though, it takes a lot more images to make something
that runs for any length of time. The pentmap.pov demo (assuming they
didn't rename it. My own copy of clockdemo is called clockd, so they may
have renamed some of the files) has 300 images in is and is only 1 minute
in length. The clockdemo will be 0.4 seconds in length. lol
Clockdemo is only intended to give a basic example of how animation
works, not a full length animation. In fact, the longest animation of any
of them is Life.pov at 1 minute, 40 seconds. The rest are on average only
about 12 seconds in length.
void main () {
  else
