POV-Ray : Newsgroups : povray.newusers : Ingraving Text Server Time
17 Jan 2026 20:02:20 EST (-0500)
  Ingraving Text (Message 1 to 9 of 9)
Subject: Ingraving Text
Date: 5 May 2004 10:25:01
Message: <web.4098f88ef7b95717a81507220@news.povray.org>
Hey, just started using this program... I'm trying to make a logo for a
website, and I want an engraved sword... I'm learning how to make the
sword, but I can't seem to get anything with engraved text... I checked the
documentation, I saw something with a difference tag, but couldn't get it
working... any suggestions?
Subject: Re: Ingraving Text
Date: 5 May 2004 11:12:39
Message: <40990467$1@news.povray.org>
"Master Xan" <nomail@nomail> wrote in message
news:web.4098f88ef7b95717a81507220@news.povray.org...
the
First off, welcome to povray. second, using True Type Fonts in scenes can
become slow, especially with difference. Difference is what you want to do,
you were right on that point.
basically, what you do is this
difference {
   object {my_sword}
   object {my_text]
you may want to try with simple object at first if you havn't. for instance
difference {
   /* object to cut into */
   box {
      <1, 1, 1>, <-1, -1, -1>
      pigment {rgb <0, 0, 1>}
   /* this box cuts a square shaped hole all the way through the above box
   box {
      <.5, 2, .5>, <-.5, -2, -.5>
      pigment {rgb <1, .5, 0>}
   rotate 45*y
   translate <0, 1, 0>
the important part is making sure that the object that does the cutting
actually comes into contact with the object you want to cut into. It is
sometimes useful to use "union" in that testing phase (so you actually see
where the cutting object is), then replace the union keyword with difference
when you have it in the right place.
what specific problems are you encountering?
Date: 5 May 2004 16:35:00
Message: <web.40994fcfdac6dcb5ad78b6540@news.povray.org>
> the
> difference {
>    object {my_sword}
>    object {my_text]
> difference {
>    box {
>    box {
>    rotate 45*y
>    translate <0, 1, 0>
Well, I can't get all the words visable beyond the cone I'm trying to use
(kinda looks like a sword if you can't see the ends, I'll replace it
later). I think it's because I can't get the text to slant (the cone goes
from 0 Z to 3 Z, but the text won't start at 0 Z and end at 3 Z)
On an unrelated note, is there a list of included things (textures,
pigments, whatever) that comes with the program, or do I have to copy them
from the website?
Date: 5 May 2004 19:40:28
Message: <40997b6c$1@news.povray.org>
Master Xan nous apporta ses lumieres ainsi en ce 2004/05/05 16:34... :
>>the
>>difference {
>>   object {my_sword}
>>   object {my_text]
>>difference {
>>   box {
>>   box {
>>   rotate 45*y
>>   translate <0, 1, 0>
>from the website?
You can rotate the text around any axis. So, assuming your "sword" sit
along the x axis, with the small end on the right, rotate your text by
-1 to -5 on the y axis like "rotate -2*y". you may need to translate
along the z axis. Some trigonometry can give you the exact angle. The
origin of your text is completely to the left front of the first letter
on the base line of the text (text goes up and right from the origin
point and is extruded back)
Date: 6 May 2004 00:32:27
Message: <4099bfdb$1@news.povray.org>
>>> the
>>>> get it
>>> can
>>> to do,
>>> difference {
>>>   object {my_sword}
>>>   object {my_text]
>>> instance
>>> difference {
>>>   box {
>>> box
>>>   box {
>>>   rotate 45*y
>>>   translate <0, 1, 0>
>>> actually see
>>> difference
>> them
>> from the website?
> Alain
as though it was in a box { <0,0,0>,<len, height, depth>}
height, length, depth related to size of letters on relevant axes
stephen
Date: 6 May 2004 04:49:09
Message: <4099fc05$1@news.povray.org>
> from the website?
If your on windows, look in Program Files\PovRay For Windows\ Scenes\Inc
Demos
There are a lot  of demo pov files in there that show you a lot of pigments
and textures.  The Pov files will show you what textures are in what files.
Have fun...
Date: 6 May 2004 06:26:08
Message: <opr7kpv7p4p4ukzs@news.povray.org>
On Thu, 6 May 2004 09:49:09 +0100, Felbrigg <som### [at] microsoftcom> wrote:
>> them
>> from the website?
> Demos
> pigments
> files.
> Have fun...
They are also listed in the help file under "Standard Include Files", but
better yet try http://texlib.povray.org/ which will show you what they
look like without having to render all those files :)
Enjoy creating your sword.
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 6 May 2004 17:15:00
Message: <web.409aaab1dac6dcb5ad78b6540@news.povray.org>
Thanks for the good help guys. I bookmarked that link, I'll be spending
quite a lot of time there... I appreciate the commands too, I seem to have
missed half the commands for the program on my first searches for an
answer!
Again, thx.
Dan
Date: 7 May 2004 09:39:37
Message: <409b9199$1@news.povray.org>
Did you considered using a bump_map rather than difference? It would render
a lot faster, be easy to position.In many cases, it would look as good, if
not better.
Cheers,
the
