POV-Ray : Newsgroups : povray.newusers : Casting sinusoidal shadow on an object ? Server Time
22 Dec 2025 15:51:27 EST (-0500)
  Casting sinusoidal shadow on an object ? (Message 1 to 5 of 5)
Subject: Casting sinusoidal shadow on an object ?
Date: 12 Nov 2003 15:40:01
Message: <web.3fb29a7b2d6843d5d947fdc0@news.povray.org>
I'd like to create a sinusoidal shadow on an object.
Does anyone have an idea on how to do that?
Here what I've tried: I created several boxes objects between the source
light and the object to be shadowed. I then set the light to be a an
area_light type. But...it creates a triangular shadow (when doing a line
profile in X).
Something I would have liked to try, is defocusing the shadow produced by my
boxes objects using some kind of lens...but I don't know how to do that.
Any help?
O.
Source Code:
/// Synthesize a BGA 19x19 image
global_settings { assumed_gamma 2.2 }
#include "textures.inc"
#include "stones.inc"
  orthographic
  location <0, 0, -500>
  right <640, 0, 0>
  up <0, 480, 0>
  look_at <0, 0, 0>
background { color MidnightBlue }
plane { z, 0
      colour Gray40
   finish {
      ambient 0.2
      diffuse 0.8
#declare Unit_To_Mm = 1;    // 1 unit is X mm
#declare Ronchi_Line_Width = 5;
#declare Ronchi_WidthX = 1200;
#declare Ronchi_HeightY = 1200;
#declare Fringe = box {
    <0, Ronchi_HeightY,  0>,  // Near lower left corner
    <Ronchi_Line_Width, -Ronchi_HeightY, 0>   // Far upper right corner
    pigment { color Black }
#declare Ronchi = union {
 object { Fringe translate <0,0,0> }
 //object { Fringe translate <2*Ronchi_Line_Width,0,0> }
 #declare F = 2*Ronchi_Line_Width;
 #while (F < Ronchi_WidthX/2)
  object { Fringe translate x*F }
  object { Fringe translate -x*F }
  #declare F = F + 2*Ronchi_Line_Width;
object { Ronchi translate <0, 0, -1900> }
light_source { <0, 0, -2000> colour Gray70
    area_light <5, 0, 0>, <0, 1, 0>, 10, 1
    adaptive 1
    jitter
Subject: Re: Casting sinusoidal shadow on an object ?
Date: 12 Nov 2003 18:38:43
Message: <cjameshuff-3748BE.18355612112003@netplex.aussie.org>
In article <web.3fb29a7b2d6843d5d947fdc0@news.povray.org>,
Put a sinusoidal object between it and the light?
> profile in X).
I'm having trouble understanding what kind of shadow you are trying to
achieve. You want something sinusoidal in intensity rather than shape?
You use the term "Ronchi" several times...you're trying to simulate a
Ronchi grating?
Try a plane with a partially transparent texture instead:
plane {-z, 1900 hollow
        pigment {gradient x scale Ronchi_Line_Width
            sine_wave
            color_map {[0 rgb 1] [1 rgbf 1]}
Well, fuzzy shadows can be had with an area light, but you already know
that...if you're looking for a true diffraction effect, POV is incapable
of simulating it.
BGA 19x19?
http://tag.povray.org/
Date: 13 Nov 2003 10:20:01
Message: <web.3fb3a0b3a347d771ccd526b40@news.povray.org>
Christopher James Huff wrote:
>In article <web.3fb29a7b2d6843d5d947fdc0[at]news.povray.org>,
Yeah.. couldn't figure out how.. ;)
>> profile in X).
>Ronchi grating?
Yes, I want a sinusoidal signal in intensity.. actually simulating a
defocused Ronchi grating
>    texture {
>            sine_wave
Oh great, that's what I was looking for!
Nice, it seems to work the way I want.. but is there a way to get rid of the
discontinuity occuring at x=0? (the sine phase starts at phi=0 and
increments in both direction, thus creating positive values over an entire
period of the sine)
>of simulating it.
Okay.. no problem, the hollow plane will do the trick
Thanks again,
O.
Date: 13 Nov 2003 10:46:01
Message: <cjameshuff-C652EB.10430113112003@netplex.aussie.org>
In article <web.3fb3a0b3a347d771ccd526b40@news.povray.org>,
> period of the sine)
Forgot about that...the simplest solution would be to replace "gradient
x" with "function {sin(x)/2 + 0.5}", or you could use cos() if you want
a symmetrical pattern. Oh, and remove the sine_wave keyword, since it is
now in the pattern itself. Or you could just translate the pattern far
enough that the mirroring point is out of your way.
Date: 13 Nov 2003 12:10:01
Message: <web.3fb3bab0a347d771ccd526b40@news.povray.org>
Ok, replacing the gradient x with a function is a far better solution than
what I did.. which was to add the keyword "phase 0.25" so the sin would be
in sync ;)
Thanks for the tip,
O.
