POV-Ray : Newsgroups : povray.newusers : 2 problems Server Time
18 Sep 2025 11:14:06 EDT (-0400)
  2 problems (Message 1 to 6 of 6)
Subject: 2 problems
Date: 31 Oct 2003 21:55:01
Message: <web.3fa31f44e63905fc30a67eb20@news.povray.org>
I have this landscape I'm working on. I'm trying to use media to generate a
blue sky. Basically, it is a scattering media of type 4, and the color it
scatters is <.2,.2,.0001>*.0005. This gets me the blue sky I want. However,
all the objects in the scene turn blue. I have some white snow that
especially turns blue, almost the same blue as the sky. I have tried
setting ambient to 1 with radiosity turned on, but it still comes up blue.
2nd Problem: I've been trying really hard to come up with a good texture to
coat the mountains so that it looks like they have snow on top, but not
down below. This is what I have so far for that:
#declare pigment1 =
pigment
  slope
    y, .5, 1
  color_map
    [0 color rgbf <0,0,0,1>]
    [.25 color rgbf <1,1,1,.9>]
    [1 color rgbf <1,1,1,0>]
#declare pigment2 =
pigment
  slope
    y, .5, 1
  color_map
    [.6 color rgbf <1,1,1,0>]
#declare pigment3 =
pigment
  slope
    <0,2,3>
  turbulence .5
  color_map
    [0 color rgbf <1,1,1,0>]
    [.4 color rgbf <1,1,1,1>]
    [.6 color rgbf <1,1,1,.6>]
    [1 color rgbf <1,1,1,1>]
#declare rock =
  isosurface
    function
      (y-fnpigment2(x,y,z).gray*100)-(fnpigment1(x,y,z).gray +
fnpigment3(x,y,z).gray*10 + fnpigment4(x,y,z).gray*10 +
fnpigment5(x,y,z).gray*.05)
    contained_by
      box
        <-5000,0,-5000>,<5000,500,5000>
    max_gradient 4
    texture
      T_Stone44
    texture
      pigment
        gradient y
        turbulence <0,.1,0>
        pigment_map
          [0 color rgbf <1,1,1,1>]
          [.3 pigment1]
          [.79 pigment2]
          [.8 color rgbf <1,1,1,0>]
        scale y*1000
      finish
        ambient .6
    texture
      pigment
        gradient y
        turbulence <0,.1,0>
        pigment_map
          [.3 pigment3]
          [1 pigment3]
        scale y*1000
      finish
        ambient .6
    scale <1,4,1>
The first two declared pigments are supposed to contribute to the appearance
of snow that has accumulated on the flat parts, while it tends to fall away
from cliff-sides exposing rock. The 3rd declared pigment is supposed to add
more snow on the sides of the slopes facing directly away from the main
light_source. All of these have transparent parts because they lie on top
of the texture for the stone. This is the first texture in the actual
isosurface object. The second texture is a pigment map that is supposed to
properly combine all the declared pigments. The last one is there to make
sure that all the areas that are over a certain height are completely snow
covered.
The problem is that I have not been able to find any peaks that are
completely snow-covered. Just small scattered patches. I'm a little bit
unsure how to make sure that the top end of my gradient is at the top of
the peaks.
Subject: Re: 2 problems
Date: 1 Nov 2003 09:30:17
Message: <cjameshuff-97EEDC.09300701112003@netplex.aussie.org>
In article <web.3fa31f44e63905fc30a67eb20@news.povray.org>,
You don't show the code for the media you're using. Anyway, the solution
is simple: make the media less dense, and make the sky container bigger
to compensate.
http://tag.povray.org/
Date: 1 Nov 2003 20:45:01
Message: <web.3fa45ec67933238264ba676d0@news.povray.org>
Christopher James Huff wrote:
>In article <web.3fa31f44e63905fc30a67eb20[at]news.povray.org>,
>to compensate.
Thanks. Actually, I decided for now to go with just enclosing the scene in a
giant blue sphere, but I still want to use media for general air thickness
so that distant objects look faded. Here is my current media block:
box
  <-5000,0,-5000>,<5000,800,5000>
  texture
    pigment
      color rgbt <1,1,1,1>
  interior
    media
      method 3
      samples 4
      intervals 1
      scattering
        4,
        color rgb <1,1,1>*.00075
        extinction 1
  hollow
The air thickness looks about right, but I've noticed that objects casting
shadows don't seem to be casting shadows through the air itself as I've
seen in other scenes with media. Is there anything special I have to turn
on that I've forgotten? There is a keyword "media_attenuation" that goes in
the light_source but I'm not really sure if that is it, and since it
currently takes about 6 hours to render this image with media, I think it
would be quicker to ask here.
Date: 2 Nov 2003 00:48:16
Message: <3fa49aa0@news.povray.org>
"Justin Smith" <t74### [at] yahoocom> wrote in message
news:web.3fa45ec67933238264ba676d0@news.povray.org...
in
Should not need media_attenuation on, since that is for fading the light as
it passes through the media. You'd likely get even less shadowing that way.
The scattering extinction 1 could be the culprit, so try it at 0 or near
zero and see if that helps or hinders what you had in mind for the overall
effect. Oh yeah, and use partial render output instead of the entire image
and you can see certain parts much quicker than that 6 hours. If you use the
Windows (or Mac) POV then click/drag the cursor at the spot needed to test.
Start with a small resolution to get the window to appear first then change
the output resolution before doing the selection area. Pardon me if you knew
about it already but sounded like you hadn't.
You have mentioned that you didn't like the bluish snow from radiosity being
used. Try setting its grey_threshold near to 1 (default is 0). That should
help prevent the color-bleed.
I saw your questions a couple days ago but I needed to check out what you
wanted to do about getting the snow to be more in the shadows than sunlit
sides of the terrain. I had done this kind of thing long ago but I had
practically forgotten how to use the slope pigment pattern. Maybe I've
relearned it again because I think I achieved the right effect after some
trial and error. Scaling was really throwing me off, I reduced your bounding
box vertically a lot, and changed a few aspects of the textures too.
I might have been better off searching for a previous scene file rather than
rewriting it.  :-)
Anyway, I'll post it over at povray.text.scene.files so you can have a look
at the changes. I'll call it "mountians with snow preferential to shadows"
so you'll know what to look for.
Bob H.
Date: 2 Nov 2003 19:17:51
Message: <cjameshuff-037BFE.19172902112003@netplex.aussie.org>
In article <web.3fa45ec67933238264ba676d0@news.povray.org>,
media_attenuation will have little effect with such a low-density media
except to slow it down. That feature controls the attenuation of light
passing through the media, which will probably be unnoticeable. The most
likely problem is that you don't have enough samples, there aren't
enough to pick up the shadows. Or they may just not be very visible with
the settings and angles you have.
Date: 3 Nov 2003 00:30:02
Message: <web.3fa5e7b8793323823d5cc6550@news.povray.org>
Thank you Bob H. for the work you did to help me out. I'm not sure if I'm
going to go with that, but I did learn a bit from it. I'm still
experimenting around.
-Justin Smith
