POV-Ray : Newsgroups : povray.newusers : blob between declared object Server Time
23 Dec 2025 06:47:17 EST (-0500)
  blob between declared object (Message 1 to 6 of 6)
Subject: blob between declared object
Date: 6 Sep 2002 06:15:06
Message: <web.3d787f3ceba2df3426f959360@news.povray.org>
Hi all
i'am very 'green' so bare over with me..
I'm having two declared objects (just a sphere and a box):
obj1 & obj2
I would like to make a blob between them
i have tried
blob{
    threshold .12
    obj1
    obj2
but that gives an error (must have one object..)
same with
blob{
    threshold .12
    object{obj1}
    object{obj2}
i have looked through the 'handblob example' but all segments are
'hardcoded' inside the blobdefinition.
is it not posible 'to blob' with named/declared objects?
if so -how can u blob between complext objects?
regards krus
Subject: Re: blob between declared object
Date: 6 Sep 2002 07:13:23
Message: <3D788DD2.8471C63E@gmx.de>
krus wrote:
> Hi all
> obj1 & obj2
Where is written that the blob object accepts arbitrary objects as
components?
The allowed components are:
sphere{<Center>, Radius, [ strength ] Strength [COMPONENT_MODIFIER...] }
cylinder{<End1>, <End2>, Radius, [ strength ] Strength
Blobbing arbitrary objects isn't possible but you can achieve something
isosurface functions'.  The IsoCSG library also contains some macros for
simplifying this:
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/index.html
and it works for arbitrary functions, therefore also for shapes like
boxes.  See:
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/docu02.html#BlobShape
Date: 6 Sep 2002 07:28:11
Message: <3d78914b@news.povray.org>
"krus" <nomail@nomail> wrote in message
news:web.3d787f3ceba2df3426f959360@news.povray.org...
> Hi all
See Cristoph's reply, but it's also worth mentioning (unless this has been
changed in 3.5) that you can't even declare valid blob components outside of a
blob - e.g.:
#declare BC1 = sphere{0,1,1}
blob{
    threshold 0.5
    object{BC1}
    sphere{0,1,1}
will fail on the declaration of BC1, since the extra component is only valid
within a blob statement. A macro call from within the blob could probably get
around any limitations that this seems to impose.
If this is wrong, will someone please correct it?
Date: 6 Sep 2002 08:55:06
Message: <web.3d78a51c18aeca4226f959360@news.povray.org>
Christoph Hormann wrote:
>krus wrote:
>> Hi all
>> obj1 & obj2
>components?
>simplifying this:
>boxes.  See:
>Christoph
>POV-Ray tutorials, IsoWood include,
>TransSkin and more: http://www.tu-bs.de/~y0013390/
That explain it!
Thanks to both of you!
regards krus
Date: 9 Sep 2002 09:05:39
Message: <3d7c9ca3$2@news.povray.org>
news:3D788DD2.8471C63E@gmx.de...
> objects as components?
You *should* be able to do something along the lines of what he's trying.
Here's the workaround:
Use macros!
#macro blobby1()
        sphere{x,2,1}
        sphere{y,2,1}
#macro blobby2()
        sphere{-x,2,1}
blob{
threshold 0.1
blobby1()
blobby2()
translate 8*z
pigment{rgb 1} finish{ambient 1}
Date: 9 Sep 2002 20:20:04
Message: <web.3d7d3a9718aeca4226f959360@news.povray.org>
Greg M. Johnson wrote:
>"Christoph Hormann" <chr### [at] gmxde> wrote in message
>news:3D788DD2.8471C63E[at]gmx.de...
>Use macros!
>#macro blobby1()
>        sphere{x,2,1}
>        sphere{y,2,1}
>#end
>#macro blobby2()
>        sphere{-x,2,1}
>#end
>blob{
>threshold 0.1
>blobby1()
>blobby2()
>translate 8*z
That was a very interesting example!
Thank you!
regards krus
