POV-Ray : Newsgroups : povray.newusers : Deleting triangles Server Time
21 Nov 2025 22:56:58 EST (-0500)
  Deleting triangles (Message 1 to 10 of 12)
Subject: Deleting triangles
Date: 3 Jan 2002 07:47:46
Message: <cqj11a.lnl.ln@cthulhu.hans.5sl.org>
Hello,
I wrote a macro to build a mesh from mathematic formulas. Is it
possible to delete some triangles from tihs mesh, i.e. to cut a hole
in the generatet surface?
Greetings,
  Johannes
#macro q(s)(s*s)#end union{#declare C=-1;#while(C<1)sphere{<512*(11*C-9)/q(121*C
*C-198*C+97)-4,4.22*(3-11*C)/(exp(C*11/4)+2.12)+11*C-8.5,20>.3}sphere{<4-.15*exp
(3.3*C),12/5-11*C/2,20>.3}sphere{4*<1-4*(q(C*C)-C*C),C+7/8,5>.3}sphere{<2*C-6,
7.5,20>.3}#declare C=C+.01;#end pigment{color x}}light_source{-4*x 1}
Subject: Re: Deleting triangles
Date: 3 Jan 2002 08:06:54
Message: <ihl83u4knnigjjmh09qtq0ffe1jtuag8eg@4ax.com>
On Thu, 3 Jan 2002 13:46:04 +0100, Johannes Bretscher <bre### [at] 5slorg> wrote:
> Is it possible to delete some triangles from tihs mesh, i.e. to cut a hole
there is many ways to do it. it depend what your hole is and what your object is
check clipped_by{}, bounded_by{}, difference{}, intersection{}
if you want remove exat triangle then it is better to store vertices in some
structure (mainly array) and remove vertices from this structure first and
create mesh at final stage
you can be interested in
http://news.povray.org/Xns915C94A8BA293seed7%40povray.org
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 3 Jan 2002 11:24:19
Message: <chrishuff-909D6D.11251903012002@netplex.aussie.org>
In article <cqj### [at] cthulhuhans5slorg>,
There is no way to remove a triangle from a mesh, your best bet would
probably be to do it as you generate the mesh, just leaving the
triangles out instead of trying to remove them later. An alternative
might be to store the mesh data in an array and remove the triangles
from that, maybe by storing the vertices in one array, and using another
2D array to store the triangles, using vertex indexes. You could then
use a "magic number" to "delete" a triangle.
#declare VertArray = array [NumVertices];
#declare TriArray = array [NumTriangles][3]
   {1, 5, 8},
   {TRI_2_VERTEX_1, TRI_2_VERTEX_2, TRI_2_VERTEX_3},
   {-1,-1,-1},//deleted triangle
   {TRI_N_VERTEX_1, TRI_N_VERTEX_2, TRI_N_VERTEX_3}
Or you could just use the clipped_by feature, if you want to cut out an
arbitrary shape instead of individual triangles.
Date: 3 Jan 2002 12:47:41
Message: <ib121a.b9m.ln@cthulhu.hans.5sl.org>
So CSG can be used with a mesh. That was the hint I needet. I thought
only solid objects are.
Thanks for the link.
> ABX
Johannes
Date: 3 Jan 2002 12:56:57
Message: <slrna396rb.4sl.ron.parker@fwi.com>
That's true.  You can only use union with non-solid objects.   You can still
use clipped_by, though, as long as the clipping object has an inside.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 3 Jan 2002 12:57:49
Message: <6m693uo4eocfmft5prpo836fh4526ph88o@4ax.com>
On Thu, 3 Jan 2002 17:37:06 +0100, Johannes Bretscher <bre### [at] 5slorg> wrote:
Only solid objects.
Documentation for 3.5 says:
"There are six totally thin, finite objects which have no well-defined inside.
They are bicubic patch, disc, smooth triangle, triangle, polygon and mesh /
mesh2. They may be combined in CSG union but cannot be used in other types of
CSG (or inside a clipped_by statement)."
However if there are reasonably small number of triangles then you can simulate
trangles with clipped planes. That's why I said "it depends what your hole is
and what your object is".
ABX
Date: 3 Jan 2002 13:17:02
Message: <chrishuff-DB221A.13180503012002@netplex.aussie.org>
In article <ib1### [at] cthulhuhans5slorg>,
Not in official POV-Ray. MegaPOV does have this, though it doesn't work
will all meshes.
The clipped_by feature does work in the official version, though.
Date: 3 Jan 2002 13:32:58
Message: <chrishuff-D2CF83.13340003012002@netplex.aussie.org>
In article <6m693uo4eocfmft5prpo836fh4526ph88o@4ax.com>,
You misunderstood, you can't use them in a clipped_by statement, but you
can still use a clipped_by statement in them. That is the closest thing
to CSG that you can get with patch objects.
Date: 4 Jan 2002 03:09:48
Message: <hloa3uo4gostcvmpjfsvq66uigprahlmcd@4ax.com>
On Thu, 03 Jan 2002 13:34:00 -0500, Christopher James Huff <chr### [at] maccom>
Did I say something different ??? I quoted text about CSG operations not about
object modificators.
ABX
Date: 5 Jan 2002 08:29:05
Message: <chrishuff-853ECE.08302805012002@netplex.aussie.org>
In article <hloa3uo4gostcvmpjfsvq66uigprahlmcd@4ax.com>,
You also suggested for him to use clipped planes, and by the phrasing of
your message you seemed to think clipped_by couldn't be used on meshes.
