POV-Ray : Newsgroups : povray.newusers : tile texture Server Time
10 Oct 2024 08:20:09 EDT (-0400)
  tile texture (Message 1 to 8 of 8)
Subject: tile texture
Date: 19 Apr 2001 11:51:44
Message: <MPG.1549280482705584989745@NEWS.POVRAY.ORG>
Who can help me with the building of a texture (macro) that has the look
of the image in pbi? I have not the slightest idea where to begin... :(
Regards,  Sander
Subject: Re: tile texture
Date: 19 Apr 2001 16:28:13
Message: <3ADF4B20.9384CEA6@erols.com>
> look of the image in pbi? I have not the slightest idea where to
> begin... :(
Since you and I share the same birthday, I'll help you.
A test picture is posted to p.b.i.
Use the macro this way:
object { MyObject
    Herringbone(BrickTexture,MortarTexture,MortarWidth)
John
ICQ: 46085459
// MACRO CODE FOLLOWS
#macro Herringbone(tS,tM,sW)
// tS is the brick texture
// tM is the texture for the stuff between the bricks
// sW is the width of the mortar
#local tA=texture { gradient x
  texture_map { [.50+sW/2 tM][.50+sW/2 tS][.75-sW/2 tS][.75-sW/2 tM]}
#local tB=texture { gradient x
  texture_map { [sW/2 tM][sW/2 tS][.50-sW/2 tS][.50-sW/2 tM]
    [.75+sW/2 tM][.75+sW/2 tS][1-sW/2 tS][1-sW/2 tM]
#local tC=texture { gradient x
  texture_map { [.75+sW/2 tM][.75+sW/2 tS][1-sW/2 tS][1-sW/2 tM]}
#local tD=texture { gradient x
  texture_map { [sW/2 tM][sW/2 tS][.25-sW/2 tS][.25-sW/2 tM]
    [.25+sW/2 tM][.25+sW/2 tS][.75-sW/2 tS][.75-sW/2 tM]
#local tE=texture { gradient x
  texture_map { [sW/2 tM][sW/2 tS][.25-sW/2 tS][.25-sW/2 tM]}
#local tF=texture { gradient x
    [.25+sW/2 tM][.25+sW/2 tS][.50-sW/2 tS][.50-sW/2 tM]
    [.50+sW/2 tM][.50+sW/2 tS][1-sW/2 tS][1-sW/2 tM]
#local tG=texture { gradient x
  texture_map { [.25+sW/2 tM][.25+sW/2 tS][.50-sW/2 tS][.50-sW/2 tM]}
#local tH=texture { gradient x
  texture_map { [.25-sW/2 tS][.25-sW/2 tM]
gradient z
  texture_map {
    [sW/2 tA][sW/2 tB]
    [.25-sW/2 tB][.25-sW/2 tC]
    [.25+sW/2 tC][.25+sW/2 tD]
    [.50-sW/2 tD][.50-sW/2 tE]
    [.50+sW/2 tE][.50+sW/2 tF]
    [.75-sW/2 tF][.75-sW/2 tG]
    [.75+sW/2 tG][.75+sW/2 tH]
    [1-sW/2   tH][1-sW/2   tA]
// END OF MACRO CODE
Date: 20 Apr 2001 02:33:40
Message: <MPG.1549f6bdce9bb528989747@NEWS.POVRAY.ORG>
In article <3ADF4B20.9384CEA6@erols.com>, John VanSickle says...
> object { MyObject
>   texture {
Thank you very much!! We may share our birthday, we do not share the
ability to cough up a piece of work like you did. Wonderful. I'll try
and understand how it works. But I have the impression that it is beyond
me :))
Regards,  Sander
Date: 20 Apr 2001 09:54:42
Message: <3ae03fa2@news.povray.org>
John VanSickle wrote in message <3ADF4B20.9384CEA6@erols.com>...
> > begin... :(
same my test picture
and here is my solution using repeating warps (first time for me) and layered
textures (first own by me)
code is much shorter I think
I considered repeating of rotated image
#macro TexForSander(MS,L,MC,IN)
  // MC - Mortar color
  // MS - Width of mortar
  // L  - Length of piece
  // IN - Image name
  #local W=(L-MS)/2; // Width of piece
  #local P=2*(MS+L); // Distance of repeating
  #local Img1=texture{pigment{
    image_map{sys IN once}
    rotate x*90
    scale <W/P,1,L/P>
    warp {repeat x}
    warp {repeat z}
    scale P
  #local Img2=texture{Img1 rotate y*90}
  #local V=MS+W;
  #local U=MS*(1+z);
  texture{pigment{color rgb MC}}
  texture{Img2 translate MS}
  texture{Img2 translate MS+V}
  texture{Img2 translate MS+2*V}
  texture{Img2 translate MS+3*V}
  texture{Img1 translate U+V}
  texture{Img1 translate U+2*V}
  texture{Img1 translate U+3*V}
  texture{Img1 translate U+4*V}
use it for example this way:
plane { y,0 TexForSander(0.05,1,color rgb 0,"back78.bmp") }
I worked on it with megapov but it should work with povray 3.1
ABX
Date: 20 Apr 2001 12:46:44
Message: <slrn9e0pvl.1fg.ron.parker@fwi.com>
Somehow my newsreader unsubscribed me from a bunch of groups, including this
one, but I noticed a thread in pbi about this subject and thought I had to
join the whatever-it-is going on here.  Thus, here's my entry into the fray.
Note that while it takes the same parameters as John's macro, it has problems
with mortar pigments that aren't solid colors.  That could be fixed, but at
the expense of making the macro approximately twice as long (or using a
layered texture, which I consider cheating.)
#macro Herringbone( Brick, Mortar, Thick )
  #local Gz=pigment {
    gradient z
    pigment_map {
      [Thick/2 Mortar][Thick/2 Brick][.5-Thick/2 Brick][.5-Thick/2 Mortar]
  #local Onebrick=pigment {
    gradient x
    pigment_map {
      [Thick/2 Mortar]
      [Thick/2 Gz]
      [1-Thick/2 Gz]
      [1-Thick/2 Mortar]
  gradient x
  pigment_map {
    [.5 Onebrick scale .5]
    [.5 Onebrick scale .5 rotate 90*y translate <.5,0,.25>]
    [.75 Onebrick scale .5 rotate 90*y translate <.5,0,.25>]
    [.75 Onebrick scale .5 rotate 90*y translate <.75,0,.5>]
  warp {repeat x}
  warp {repeat .25*z offset -.25*x}
  scale 2
plane {y 0
  pigment {Herringbone(pigment{bozo scale .3}, pigment{color rgb .6}, .1)}
  finish {ambient 1}
camera {location 10*y sky z look_at 0}
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 20 Apr 2001 14:37:07
Message: <3AE0829C.5581EBA7@erols.com>
The reason I didn't use the repeating warps was because I couldn't see a
way to eliminate the discontinuity that would appear in the middle of the
bricks that traverse the border.
John
ICQ: 46085459
Date: 20 Apr 2001 14:49:36
Message: <slrn9e1162.1ik.ron.parker@fwi.com>
There's no such discontinuity in mine, because the bricks all use the same
area of the pigment, as with ABX's bricks.  If you wanted to do it without
the repeating patterns, you could wrap my macro in pigment_pattern with a
brick pigment of rgb 1 and a mortar pigment of rgb 0 and then use a
pigment_map to apply the brick and mortar pigments you really want to use.
That, of course, requires MegaPOV... at least for now.
Date: 21 Apr 2001 12:43:19
Message: <3AE1B973.71D6A5F0@erols.com>
Ah, John understand!  I only started using it just this past
IRTC round.  It does media better, for starters.
John
ICQ: 46085459
