POV-Ray : Newsgroups : povray.newusers : Internal function Server Time
27 Jul 2024 14:33:25 EDT (-0400)
  Internal function (Message 1 to 10 of 11)
Subject: Internal function
Date: 18 Feb 2017 06:18:15
Message: <58a82d77$1@news.povray.org>
How to convert old scene which uses internal function ?
POVRay 3.7 raise this error : Function 'internal(XX)' does not exist.
Thanks
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: Internal function
Date: 18 Feb 2017 07:33:32
Message: <58a83f1c$1@news.povray.org>
Am 18.02.2017 um 12:18 schrieb kurtz le pirate:
Are you sure this is a genuine POV-Ray scene (as opposed to e.g. a
MegaPOV scene)? I'd be surprised if POV-Ray ever ditched any of its
inbuilt functions or renumbered them.
That said, in either case you'll have to:
1. Figure out what mathematical function the numeric code "XX" is
supposed to represent.
2. Replace the unsupported `internal` function with either:
2.a) The corresponding named function from `functions.inc` (if it exists).
2.b) A corresponding user-defined function.
2.c) A user-defined macro (if the function is used in a manner that it
can be replaced with a macro).
The trickiest part will be Step 1. There are essentially two ways you
can do this:
1.a) Examine the scene and guess what the function is.
1.b) Examine the source code of whatever version or derivative of
POV-Ray the scene was originally rendered with, to find out what the
internal function actually did.
We may be able to help you with this, but only if you disclose some more
details. For an attempt at 1.a) we'd probably need to see the entire
scene. For an attempt at 1.b) we'll need to know at least the internal
number of the function in question (the "XX" part), and anything that
might help to identify the version originally used.
Date: 18 Feb 2017 09:25:59
Message: <58a85977$1@news.povray.org>
> [snip]
Thanks for your help, and yes, it's a POVRay scene.
Here the begin of the code :
// Persistence of Vision Ray Tracer Scene Description File
// File: mb_basic.pov
// Vers: 3.6, 3.7
// Desc: Basic Scene Example
// Date: 12/18/09
// Auth: David Wagner
// Cite: http://www.skytopia.com/project/fractal/2mandelbulb.html
#version 3.6;
#declare f_mandelbulb=function{internal(79)};
global_settings {
   assumed_gamma 1.0
I had already looked in 'functions.inc' and 79 is not defined in the
file. Last is 78, f_noise_generator :(
Kurtz le pirate
Date: 18 Feb 2017 09:39:31
Message: <58a85ca3$1@news.povray.org>
>> [snip]
> // Vers: 3.6, 3.7
> // Date: 12/18/09
> #version 3.6;
> global_settings {
>   assumed_gamma 1.0
If I recall correctly, David was running his own patched version of
POV-Ray where he added the additional function himself. You would need
to do the same I guess.
Bill P.
Date: 18 Feb 2017 09:57:02
Message: <58a860be$1@news.povray.org>
>> [snip]
> // Vers: 3.6, 3.7
> // Date: 12/18/09
> #version 3.6;
> global_settings {
>    assumed_gamma 1.0
Have a look at these threads:
http://news.povray.org/povray.general/thread/%3C4b2c7c62$1@news.povray.org%3E/?ttop=385585&toff=600
http://news.povray.org/povray.binaries.scene-files/thread/%3C4b3c8167@news.povray.org%3E/
Regards
Date: 18 Feb 2017 18:45:38
Message: <58a8dca2$1@news.povray.org>
Am 18.02.2017 um 15:25 schrieb kurtz le pirate:
>> [snip]
Ah! The famous Mandelbulb function!
I'm sorry, but it is /not/ really a POV-Ray scene: It is a scene for a
special /patched/ version.
The other fellows' posts might provide useful pointers.
Date: 19 Feb 2017 02:30:10
Message: <58a94982$1@news.povray.org>
OK, Thanks...
Kurtz le pirate
Date: 19 Feb 2017 03:15:01
Message: <web.58a95371c68401151bab66820@news.povray.org>
> > [snip]
> // Vers: 3.6, 3.7
> // Date: 12/18/09
> #version 3.6;
Note that the documentation is very clear on the use of "internal" - do not,
ever, use it directly in your scene. Use functions.inc .
Date: 21 Feb 2017 07:55:01
Message: <web.58ac385bc6840115c437ac910@news.povray.org>
so then,
#macro WorstMacroEver (Variable)
global_settings {
     assumed gama 2.2
#declare Mangled = Variable * internal(666);
Mangled;
would not be recommended practice?
:D
Date: 21 Feb 2017 09:28:33
Message: <58ac4e91$1@news.povray.org>
> so then,
> global_settings {
>       assumed gama 2.2
> Mangled;
> #end
> :D
Except on Soul Cake Tuesday. ;)
Regards
