POV-Ray : Newsgroups : povray.newusers : Skybox Issue Server Time
29 Sep 2024 00:16:32 EDT (-0400)
  Skybox Issue (Message 1 to 8 of 8)
Subject: Skybox Issue
Date: 10 Oct 2007 15:04:23
Message: <470d2237$1@news.povray.org>
I've posted an image in p.b.i
Short version: I've got some images to use for a skybox, 112.5 degree
viewing angle on the images and they should all match up perfectly.
I've only got the sides not the top and bottomin place but I can already see
that the images don't join smoothly. I've set ambient 0 diffuse 1
I believe I need to stop light being effected by the angle of incidence,
unless someone else can point out the obvious?
Would someone please kick me in the right direction?
Subject: Re: Skybox Issue
Date: 10 Oct 2007 15:26:30
Message: <470d2766$1@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> wrote in message
news:470d2237$1@news.povray.org...
> see that the images don't join smoothly. I've set ambient 0 diffuse 1
try the opposite: ambient 1 diffuse 0
cu!
Date: 10 Oct 2007 15:33:29
Message: <470d2909$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:470d2766$1@news.povray.org...
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
Thanks for the reply - you're quite right - I'm having a slow day :)
Having tried that, however, it's still the same. (For your ref, I have a
rgb1 light source at the origin - I used it when placing walls and never
removed it, hence the fact the image I posted wasn't black)
Date: 10 Oct 2007 15:35:31
Message: <470d2983$1@news.povray.org>
Hmmm there's something strange going on here. With ambient 0 diffuse 0, I
can still see the box (although it's darker). Would it help if I posted the
code?
> cu!
Date: 10 Oct 2007 17:14:12
Message: <470d40a4$1@news.povray.org>
> code?
Simon,
Are the images PNG files? If so, try using a different format. PNGs
store gamma and alpha information, both of which can give unexpected
results down the line.
Does your scene have fog? Is the skybox 'hollow'? If you are still
seeing the box even with ambient 0 diffuse 0, then fog may be affecting
your scene.
How did you create the images? Are you interested in trying something
new? Rune's Illusion Include file lets you render a backdrop and place
it into an existing scene (onto an object such as a skybox). It will
work great if the camera does not move.
Link:
http://runevision.com/show.asp?id=96
Beyond that, make sure that ambient 1 and diffuse 0 are the *only*
finish attributes in the box's texture.
Sam
Date: 10 Oct 2007 17:52:18
Message: <470d4992@news.povray.org>
thanks for the idea, I'll have a look at Rune's site. Unfortunately, I do
want the camera to move. I have however, solved that problem:
What you all failed to account for was my stupidity:
 I rendered the skybox images in Bryce and failed to unlink the sun and the
camera. The upshot? images with mis-matched light levels when joined (but
perfectly matching borders).
Sorry for the hassle.
Having said that, the image on the skysphere seems very "faded". Is there
any way I can make it more vibrant?
Sorry again and thanks for any further help
-Simon
"Samuel Benge" <stb### [at] THIShotmailcom> wrote in message
news:470d40a4$1@news.povray.org...
>> the code?
> Simon,
> Are the images PNG files? If so, try using a different format. PNGs store
> gamma and alpha information, both of which can give unexpected results
> down the line.
> Does your scene have fog? Is the skybox 'hollow'? If you are still seeing
> the box even with ambient 0 diffuse 0, then fog may be affecting your
> scene.
> How did you create the images? Are you interested in trying something new?
> Rune's Illusion Include file lets you render a backdrop and place it into
> an existing scene (onto an object such as a skybox). It will work great if
> Link:
> Beyond that, make sure that ambient 1 and diffuse 0 are the *only* finish
> Sam
Date: 10 Oct 2007 18:01:09
Message: <470d4ba5$1@news.povray.org>
Oh and no fog and also, for your ref, I'm creating the box out of 6
infinitely thin cubes
>> the code?
> Simon,
> down the line.
> scene.
> Link:
> Sam
Date: 11 Oct 2007 07:26:39
Message: <470e086f$1@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> schreef in bericht
news:470d4992@news.povray.org...
When using image_maps, I often use a diffuse of 0.7 or 0.8 to correct
exactly that.
