POV-Ray : Newsgroups : povray.newusers : Transparent Objects Server Time
14 Mar 2026 03:43:39 EDT (-0400)
  Transparent Objects (Message 1 to 10 of 17)
Subject: Transparent Objects
Date: 26 May 2007 17:57:46
Message: <4658ad5a@news.povray.org>
Hi all,
wonder if someone can point me in the right direction for how to fade an
object into/out of visibility.
I can do rgbt and modify the t but have some complex (for me) objects so not
sure how to do it for the whole union'd object rather than on a per-pigment
basis. Ideally I just want to change what % of light rays passing through
the volume of the objects are affected by them
Sorry if that was a tad unclear - Any help greatly appreciated
-Simon
Subject: Re: Transparent Objects
Date: 26 May 2007 18:27:54
Message: <r0dh53h9dbq1r82c3aoi66aj8opdr81no3@4ax.com>
On Sat, 26 May 2007 22:58:12 +0100, "Simon" <povray@*NOSPAM*SOWare.co.uk> wrote:
>Hi all,
>-Simon
You could add a variable to all the rgbt values you want to fade.
#declare FadeValue =0;
colour rgbt <1.0, 0.5, 0.2, .6*FadeValue>
Regards
Date: 27 May 2007 05:03:56
Message: <4659497c$1@news.povray.org>
Thanks very much, I'll have to do that. Was hoping there was a neater way
Thanks again!
S
"Stephen" <mcavoysATaolDOTcom@> wrote in message
news:r0dh53h9dbq1r82c3aoi66aj8opdr81no3@4ax.com...
> wrote:
>>Hi all,
>>not
>>per-pigment
>>-Simon
> Regards
> Stephen
Date: 27 May 2007 05:23:32
Message: <ufji535jehjpm0ha8valurh9kcp85ath21@4ax.com>
On Sun, 27 May 2007 09:57:17 +0100, "Simon" <povray@*NOSPAM*SOWare.co.uk> wrote:
I don't think that there is.
Remember to "Merge" any object that you are going to fade out to get rid of
internal surfaces. Help - 3.4.6.5  Merge
Regards
Date: 27 May 2007 07:43:13
Message: <46596ed1$1@news.povray.org>
Much appreciated - I'll have a look at that now :)
news:ufji535jehjpm0ha8valurh9kcp85ath21@4ax.com...
> of
> Regards
> Stephen
Date: 27 May 2007 07:50:29
Message: <46597085@news.povray.org>
  Note that merge only removes the surfaces inside the object. It doesn't
make the inner side of the outer surfaces invisible. This may or may not
become a problem, depending on the effect you want to achieve.
  A completely transparent interior_texture might be worth a try if you
want to make the inner sides invisible.
Date: 27 May 2007 08:43:05
Message: <s4vi53dqvcjldjegnql3i21nrok4kd3gnh@4ax.com>
A good point. That probably explains a few of my failures.
Regards
Date: 27 May 2007 09:40:46
Message: <46598a5e$1@news.povray.org>
It's working (ish) with the objects. I have a sky sphere and want to fade
that too....
 #local p_image=
 pigment{
  image_map{
   jpeg SkySphere
   map_type 1
   interpolate 2
 #local p_image_filtered=
 pigment{
  image_map{
   jpeg SkySphere
   map_type 1
   interpolate 2
   filter all light_filter
Any suggestions how I coul re-work this?
news:s4vi53dqvcjldjegnql3i21nrok4kd3gnh@4ax.com...
>>> of
> Regards
> Stephen
Date: 27 May 2007 10:38:07
Message: <465997cf$1@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> schreef in bericht
news:4658ad5a@news.povray.org...
> Hi all,
> not
> per-pigment
Hi Simon,
I think that  instead of union {}, you should use merge{}probably because
otherwise, by making the (collection) of objects transparent, you will see
the inner limits of the individual objects constituting the union. Merge is
specific for transparent objects.
Now concerning your question, if each constituent object has its own
pigment, I would make a  #declare T = yourvalue; and use that in every
pigment inside the union/merge block. If the union/merge block has only one
pigment, then it is much easier of course :-)
I hope this answers your question. Post an image in p.b.i. if in doubt.
Date: 27 May 2007 11:57:29
Message: <5iaj539kp36u1urgbqo3th2pgbv7lf2u5a@4ax.com>
On Sun, 27 May 2007 14:41:24 +0100, "Simon" <povray@*NOSPAM*SOWare.co.uk> wrote:
>that too....
I've never obtained satisfactory results when trying to fade an object. So I
might not be the best person to help you further. :-(
But I've just checked this and it looks like Pov can only use one sky_sphere.
The last in the scene is the one it uses.
Regards
