POV-Ray : Newsgroups : povray.newusers : Transparent Objects Server Time
17 Mar 2026 00:20:46 EDT (-0400)
  Transparent Objects (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: Transparent Objects
Date: 27 May 2007 09:40:46
Message: <46598a5e$1@news.povray.org>
It's working (ish) with the objects. I have a sky sphere and want to fade
that too....
 #local p_image=
 pigment{
  image_map{
   jpeg SkySphere
   map_type 1
   interpolate 2
 #local p_image_filtered=
 pigment{
  image_map{
   jpeg SkySphere
   map_type 1
   interpolate 2
   filter all light_filter
Any suggestions how I coul re-work this?
"Stephen" <mcavoysATaolDOTcom@> wrote in message
news:s4vi53dqvcjldjegnql3i21nrok4kd3gnh@4ax.com...
> On 27 May 2007 07:50:29 -0400, Warp <war### [at] tagpovrayorg> wrote:
>>Stephen <mcavoysATaolDOTcom@> wrote:
>>> Remember to "Merge" any object that you are going to fade out to get rid
>>> of
>>> internal surfaces. Help - 3.4.6.5  Merge
>>  Note that merge only removes the surfaces inside the object. It doesn't
>>make the inner side of the outer surfaces invisible. This may or may not
>>become a problem, depending on the effect you want to achieve.
> A good point. That probably explains a few of my failures.
> Regards
> Stephen
Date: 27 May 2007 10:38:07
Message: <465997cf$1@news.povray.org>
"Simon" <povray@*NOSPAM*SOWare.co.uk> schreef in bericht
news:4658ad5a@news.povray.org...
> Hi all,
> wonder if someone can point me in the right direction for how to fade an
> object into/out of visibility.
> I can do rgbt and modify the t but have some complex (for me) objects so
> not
> sure how to do it for the whole union'd object rather than on a
> per-pigment
> basis. Ideally I just want to change what % of light rays passing through
> the volume of the objects are affected by them
> Sorry if that was a tad unclear - Any help greatly appreciated
Hi Simon,
I think that  instead of union {}, you should use merge{}probably because
otherwise, by making the (collection) of objects transparent, you will see
the inner limits of the individual objects constituting the union. Merge is
specific for transparent objects.
Now concerning your question, if each constituent object has its own
pigment, I would make a  #declare T = yourvalue; and use that in every
pigment inside the union/merge block. If the union/merge block has only one
pigment, then it is much easier of course :-)
I hope this answers your question. Post an image in p.b.i. if in doubt.
Date: 27 May 2007 11:57:29
Message: <5iaj539kp36u1urgbqo3th2pgbv7lf2u5a@4ax.com>
On Sun, 27 May 2007 14:41:24 +0100, "Simon" <povray@*NOSPAM*SOWare.co.uk> wrote:
>that too....
I've never obtained satisfactory results when trying to fade an object. So I
might not be the best person to help you further. :-(
But I've just checked this and it looks like Pov can only use one sky_sphere.
The last in the scene is the one it uses.
Regards
Date: 27 May 2007 12:16:44
Message: <4659aeec$1@news.povray.org>
Sorry, I should've been more clear - I'm actually just using a real sphere
with various lighting effecets to light my scene - so whilst it is
technically a sky sphere, it's not done the way POV usually would - I'm
trying to get a natural lighting effect (as per a seminar I saw by Paul
Debevec). Results have been quite good (I've posted a vid in p.b.a if you're
interested)
The Sky declaration is:
 union{
  sphere{0,5
   hollow no_shadow
   texture{
    pigment{
     function{fp(x,y,z).gray}
     poly_wave light_exponent
     color_map{
     [0.0 rgb 0]
     [1.0 rgb light_ambient]
  finish { ambient light_ambient diffuse 0 }
  sphere{0,4.999
   hollow no_shadow
   texture{
    pigment{p_image_filtered}
(I hasten to add that this is not my code - I grabbed it online. Am not 100%
sure where from but will find it if anyone wants to know)
Thanks for any help you can give Stephen :)
-Simon
news:5iaj539kp36u1urgbqo3th2pgbv7lf2u5a@4ax.com...
>>that too....
> I
> sky_sphere.
> Regards
> Stephen
Date: 27 May 2007 19:56:03
Message: <465a1a93$1@news.povray.org>
>  union{
>   sphere{0,5
>    hollow no_shadow
>    texture{
>     pigment{
>      color_map{
>      [0.0 rgb 0]
>   sphere{0,4.999
>    hollow no_shadow
>    texture{
Have the inner sphere become increasingly transparent to reveal the
outer sphere.
If p_image_filtered is a texture declared in Pov, you can add change the
transmit value of the colors as mentioned earlier in the thread.
If it's an image, you can use the transmit bitmap modifier, described here:
http://povray.org/documentation/view/3.6.1/337/
(While I was looking that up, I accidentally ran across the
interior_texture option. I didn't know about that--it looks really useful!)
William Tracy
|a|f|i|s|h|i|o|n|a|d|o|@|g|m|a|i|l|.|c|o|m|
|w|t|r|a|c|y|@|c|a|l|p|o|l|y|.|e|d|u|
You know you've been raytracing too long when you actually contemplate
spending $$$ at a printing bureau to litho some of your raytraces for
your non-computer-literate relatives.
George Erhard
Date: 28 May 2007 08:38:35
Message: <465acd4b@news.povray.org>
"William Tracy" <wtr### [at] calpolyedu> wrote in message
news:465a1a93$1@news.povray.org...
> here:
Thanks so much, that was exactly what I was looking for! Between you and
Stephen, I've got my answer. Thank you all so much!
Date: 28 May 2007 08:54:08
Message: <465ad0f0$1@news.povray.org>
news:46597085@news.povray.org...
>  A completely transparent interior_texture might be worth a try if you
> want to make the inner sides invisible.
Thanks for that Warp, I was getting a problem where: If the object passed
behind itself while transparent, It is visible even is the transparency
should be 100% - I think this may fix it...
Thanks again,
S
Date: 28 May 2007 09:08:47
Message: <465ad45f@news.povray.org>
  That may have more to do with max_trace_level.
Date: 28 May 2007 09:23:49
Message: <465ad7e5@news.povray.org>
(excuse me while I go kick myself a few times)
It may well do. I reduced max_trace so I could get some test renderings done
with positioning - and never set it back up before moving on. As I've never
used transparency before, I assumed I was making a mistake there.
Thanks Warp.
news:465ad45f@news.povray.org...
>                                                          - Warp
Date: 28 May 2007 16:36:37
Message: <465b3d55$1@news.povray.org>
I've certainly made max_trace_level mistakes myself.
I remember posting one image here with the comment that I might need to
go back and make some of the shapes slightly lighter and less opaque.
Someone pointed out that had nothing to do with it--it was
max_trace_level. :-P
William Tracy
You know you've been raytracing too long when you've tried rendering
hair with each strand as an object.
Quietly Watching
