POV-Ray : Newsgroups : povray.newusers : Difference fom height field. Server Time
11 Jun 2026 14:38:11 EDT (-0400)
  Difference fom height field. (Message 1 to 7 of 7)
Subject: Difference fom height field.
Date: 27 Apr 2007 10:20:51
Message: <463206c3$1@news.povray.org>
I'm trying to make a pediment (I think that's the architectural term for
the triangle on top of columns on classical buildings) out of a
height-field differenced with two sloping boxes.
Using difference I'm not successfully cutting out the triangle. (it
works if I replace the height-field with a box) Am I missing something
obvious in the manual... is there a good reason for this not to work?
I can get it to work if I take the intersection of the height_field with
a suitably differenced box but this seems silly.
Also is there a way to invert the height field (I ended up inverting the
image in an image editor).
Here's a minimal scene showing the problem (it's meant to render a
triangle). The commented out code shows that it works with intersection.
thanks
#default {
   pigment {rgb 1}
   location  <0.0, 3.5, -9.0>
   //direction 1.5*z
   //right     x*image_width/image_height
   look_at   <0.0, 1,  0.0>
light_source {
   <-30, 30, -30>
   color rgb 1
#local fh = 3;
#local fl = 5;
#local fw = 4;
#local fa = degrees(asin(fh/fl))  ;
difference {
   height_field {
     png "plasma3.png"
     rotate x*-90
     translate <-0.5,0,0>
     scale <fw*2,fh,0.2>
   union {
     box{<0,-0.1,-2> <fl,4,2> rotate z*-fa translate <0,fh,0>}
     box{<0,-0.1,-2> <fl,4,2> rotate z*-fa translate <0,fh,0> scale x*-1}
/*intersection {
   height_field {
     png "plasma3.png"
     rotate x*-90
     scale <fw*2,fh,0.2>
   difference {
     box { <-fw,0,-1> <fw,fh,1> }
     union {
Subject: Re: Difference fom height field.
Date: 28 Apr 2007 06:29:54
Message: <46332222@news.povray.org>
Height_fields have depth, but only the "field" surface
is rendered... so you need to difference off a
slightly smaller box to give it edges...
difference {
   height_field {
     png "plasma3.png"
     rotate x*-90
     scale <fw*2,fh,0.2>
   box{<-0.49,0.01,0>,<0.49,0.99,-1> inverse scale <fw*2,fh,0.2>}
   box{<0,-0.1,-2> <fl,4,2> rotate -fa*z translate <0,fh,0>}
   box{<0,-0.1,-2> <fl,4,2> rotate -fa*z translate <0,fh,0> scale -x}
or alternately, treat it as just a surface of triangles,
and use clipped_by ...
height_field {
   png "plasma3.png"
   rotate x*-90
   scale <fw*2,fh,0.2>
   clipped_by {
      box{<0,-0.1,-2> <fl,4,2> inverse rotate -fa*z translate <0,fh,0>}
scale -x}
Date: 29 Apr 2007 03:38:02
Message: <46344b5a$1@news.povray.org>
Thanks ok I see this works fine. It still seems a little odd.
To me it seems counterintuitive that taking a height-field and
differencing a larger box from it leaves anything. It's even stranger
that whats left is outside the original bounding box of the height_field
difference {
   // height_field from <0 0 0> to <1 1 1>
   height_field {
     png  "plasma3.png"
   box { -1, 2 }
It seems height_fields could be considered of infinite depth but that
apart from the top face their faces don't show until something is
differenced.
   In this case I'm not interested one way or the other in any edges as
they won't be visible so clipping works fine too, and I *think* I now
understand how hf's behave.
Now to try to complete the rest of my Before-After 3D-rtc entry :- )
thanks
Date: 29 Apr 2007 07:00:01
Message: <web.463479816244d7c29d1710750@news.povray.org>
Yep, it's very easy: When you scale your height_field, make the
y-component negative.  For example, scale <10,-2,10>
Ken W.
Date: 29 Apr 2007 09:02:58
Message: <46349782$1@news.povray.org>
> Ken W.
I'd tried that but as soon as you do CSG that doesn't achieve the same
thing as inverting the image.
You end up with the flat side of the height field facing you instead of
the bumpy side :-)
(for an example change
scale <fw*2,fh,0.2>
to
scale <fw*2,fh,-0.2>
in the height_field in Tim's first code suggestion)
If I use clipped by instead of difference then it works fine though.
Date: 29 Apr 2007 09:17:32
Message: <46349aec@news.povray.org>
> > Ken W.
  Then apply 'inverse' to the heighfield besides the scale.
Date: 29 Apr 2007 15:52:12
Message: <4634f76c$1@news.povray.org>
>>> Ken W.
Grrr too obvious - Yup that would do it.
thanks
