POV-Ray : Newsgroups : povray.newusers : Scale a picture Server Time
16 Jun 2026 09:03:32 EDT (-0400)
  Scale a picture (Message 1 to 4 of 4)
Subject: Scale a picture
Date: 8 May 2005 14:24:26
Message: <427e595a$1@news.povray.org>
Hi all,
Is it anyway to scale a complete picture?
Thanks,
Oleguer
Subject: Re: Scale a picture
Date: 8 May 2005 21:05:01
Message: <427eb73d@news.povray.org>
  Download an image manipulation program (such as the gimp) and
scale the picture with it?
Date: 9 May 2005 08:15:01
Message: <427f5445$1@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:427e595a$1@news.povray.org...
> Hi all,
> Thanks,
> Oleguer
Hi Oleguer,
Your question does not seem very clear.
Here are some ideas about what you might  be asking:
You can adjust the size of a rendered image by adjusting the resolution as a
render option e.g. changing it from 640x480 to 800x600 to get a larger or
smaller rendered image,
or,
If you want to 'zoom' in or out (to alter the amount of the scene you get in
the render window from a given camera position), you can add the 'up' and
'right' vectors to your camera statement,
alternatively,
If you mean that you would like to scale a picture that you are using as an
image_map to texture an object then you can use 'scale' inside the texture
definition.
If 'none of the above' (and Warp's answer didn't hit the spot) then a little
more detail on what you want to do would be helpful.
Chris B.
Date: 9 May 2005 11:37:49
Message: <427f83cd@news.povray.org>
Yeah, thanks Warp and Chris.
I had done it using the camera parameters, up, right and angle.
I use CorelDraw and I supose that it can do it, but I have to check it, if
it can't do it maybe Photoshop will be able to do it.
But no, I used the camera parameters and that's all.
Best regards,
Oleguer (EA3AWX)
news:427f5445$1@news.povray.org...
>> Hi all,
>> Thanks,
>> Oleguer
> Hi Oleguer,
> a
> or,
> in
> alternatively,
> an
> definition.
> little
> Regards,
> Chris B.
