POV-Ray : Newsgroups : povray.newusers : Texture Server Time
18 May 2026 04:13:44 EDT (-0400)
  Texture (Message 11 to 17 of 17)
Subject: Re: Texture
Date: 16 Feb 2005 10:06:29
Message: <42136175$1@news.povray.org>
Props to you.  I basically understand it.  I learn by taking source code of
programs apart and trying various things.  So thanks again!  If you want to
see my finished logo for proposal, I'll be happy to send it to you.  Now its
off to combining the alphabet blocks (or my own) to this.  Should look
prerty convincing.
"Bob Hughes" <omn### [at] charternet> wrote in message
news:4212c756$1@news.povray.org...
> "Daniel" <new### [at] hotmailcom> wrote in message
> news:42129027$1@news.povray.org...
>> Can some1 please make me a sample?  I'm very new at POV ray.
> Since you're new to this I sure hope you can figure out what I've done
> here:
> // BEGIN HERE
> global_settings {
> assumed_gamma 1
> camera {location -3*z up y right image_width/image_height*x look_at 0}
> light_source {<100,100,-100>,1}
> #declare ImagePart=
> texture {
>  pigment {
>   image_map {
>   png "alpha.png"
> #declare InvisiblePart=
> texture {
>  pigment {
>   rgbt 1
> // thick-walled box
> intersection {
> height_field {
>  png "alpha.png"
>  water_level 0.005 // remove lowest/darkest part
>  // some adjustments to get into place
>  rotate -90*x
>  scale <1.001,1.001,2>
>  translate 0.5*z
> difference {
>  box {
>   0,1 // outside
>  box {
>   0.1,0.9 // inside
> texture {
>  gradient z
>  texture_map {
>   [0.1 ImagePart] // trying to match thickness surface...
>   [0.1 InvisiblePart] // ... so are transformations below
>  scale <1.02,1.02,2> // some adjustments to get into place...
>  translate <-0.01,-0.01,-0.01> // ... so that coverage is good
> translate <-0.5,-0.5,-0.5> // center on world origin
> rotate <0,-45,0> // turn to show thickness better
> // show where box is
> difference {
>  box {
>   0,1 // outside edges
>  box {
>   0.01,0.99 // cutaway sides
>    scale <1.1,1,1> translate -0.015*x
>  box {
>   0.01,0.99 // cutaway top/bottom
>    scale <1,1.1,1> translate -0.015*y
>  box {
>   0.01,0.99 // cutaway front/back
>    scale <1,1,1.1> translate -0.015*z
>  pigment {
>   color rgb 1
> // END HERE
> No doubt this complicated to go through just for a simple thing such as
> this but I'm not able to think of a better way. Obviously there's a whole
> lot of juggling the positions around to fit it all together right, and I
> suppose you'll be changing it to do what you want.
> Maybe this will help anyhow. You can always ask more questions.
> Bob Hughes
Date: 16 Feb 2005 15:12:01
Message: <4213a911$1@news.povray.org>
BTW is there a way to interpolate in the alpha area to make it a solid
object?
news:42136175$1@news.povray.org...
> of programs apart and trying various things.  So thanks again!  If you
> want to see my finished logo for proposal, I'll be happy to send it to
> you.  Now its off to combining the alphabet blocks (or my own) to this.
> Should look prerty convincing.
>> here:
>> // BEGIN HERE
>> global_settings {
>> assumed_gamma 1
>> #declare ImagePart=
>> texture {
>>  pigment {
>>   image_map {
>>   png "alpha.png"
>> texture {
>>  pigment {
>>   rgbt 1
>> // thick-walled box
>> intersection {
>> height_field {
>>  png "alpha.png"
>>  rotate -90*x
>>  translate 0.5*z
>> difference {
>>  box {
>>   0,1 // outside
>>  box {
>>   0.1,0.9 // inside
>> texture {
>>  gradient z
>>  texture_map {
>> difference {
>>  box {
>>  box {
>>  box {
>>  box {
>>  pigment {
>>   color rgb 1
>> // END HERE
>> Bob Hughes
Date: 16 Feb 2005 15:18:42
Message: <4213aaa2@news.povray.org>
Okay. Good that you think it'll work for you. I thought afterward that I
should maybe have said something about the "alpha.png" being used for both
height_field and pigment, along the lines of: it might not do well to use
the same exact image file because of the HF using a specific color=height
thing. Probably not always going to work right. And water_level I gave it
would drop any dark parts- including those that are in your logo/symbol.
Best thing would be a cutout kind of image so whole thing is just black and
white, that way you have a reasonably good edge for the graphic your trying
to create the extrusion for.
Not always easy to convey every detail for a new POV-Ray user. Good to read
the documentation for what you find in the scripts, in order to get the
details figured out or move on to the next question.
Oh yeah, and thanks for the offer to see the result but no need to do that.
Unless you want to post at povray.binaries.images, of course.
Bob Hughes
Date: 16 Feb 2005 15:59:55
Message: <4213b44b$1@news.povray.org>
Could I email you a pix of what i got so far.  There are some bugs that you
may know how to fix.  Thanks!
news:4213aaa2@news.povray.org...
> and white, that way you have a reasonably good edge for the graphic your
> trying to create the extrusion for.
> read the documentation for what you find in the scripts, in order to get
> the details figured out or move on to the next question.
> that. Unless you want to post at povray.binaries.images, of course.
> Bob Hughes
Date: 16 Feb 2005 16:08:34
Message: <4213b652$1@news.povray.org>
It looks fuzzy if you know what I mean.  When I have the block set to
intersection, and the block becomes fuzzy when it is white or on another
Pigment.
news:4213b44b$1@news.povray.org...
> you may know how to fix.  Thanks!
>> both height_field and pigment, along the lines of: it might not do well
>> to use the same exact image file because of the HF using a specific
>> color=height thing. Probably not always going to work right. And
>> water_level I gave it would drop any dark parts- including those that are
>> in your logo/symbol. Best thing would be a cutout kind of image so whole
>> thing is just black and white, that way you have a reasonably good edge
>> for the graphic your trying to create the extrusion for.
>> Bob Hughes
Date: 16 Feb 2005 16:14:12
Message: <4213b7a4$1@news.povray.org>
news:4213a911$1@news.povray.org...
> object?
Missed you asking this by only minutes, apparently.
I don't think I know what you're actually asking. If I understand you right
all you're wanting to do is keep that face of the box intact instead of just
leaving the logo image floating in midair. If so, the water_level amount I
mentioned before will allow that to happen if you change it to 0 or no
keyword and number at all, as long as the surrounding image color is only
solid black. However, your original question seemed to indicate you wanted
it as a cutout having nothing surrounding it, hence the alpha channel for
transparency.
Sorry, I forgot about the way it also intersects with the thick-walled box
object. You'd need to keep the HF from getting snipped off by rescaling it
to be shallower and/or move it outward (-z*?) some. Or even making the box
solid itself first by removing the differenced inner box.
Only other thing I can guess you might have meant is, if the edge of the HF
image can be smoother than it is now. I can only suggest adding the keyword
'smooth' into the HF (before or after water_level) or increase your logo
image resolution.
Otherwise, please elaborate on the question, if you can.
Bob Hughes
Date: 16 Feb 2005 17:49:19
Message: <4213cdef$1@news.povray.org>
Sure thing. Could be the only way to ever know what is being described
anyway.
Bob Hughes
