POV-Ray : Newsgroups : povray.newusers : Can I do an Axonometric projection? (primitive game style isometric(ish) projection) Server Time
11 Jul 2026 16:08:56 EDT (-0400)
  Can I do an Axonometric projection? (primitive game style isometric(ish) projection) (Message 1 to 3 of 3)
Subject: Can I do an Axonometric projection? (primitive game style isometric(ish) projection)
Date: 23 Dec 2004 10:04:11
Message: <41cade6b$1@news.povray.org>
Rather hard to describe in words but..
Has anyone got POV to render images in the false isometric view where
the x and y-axes of the (3-dimensional) world space are projected to x
and y in the scene and z is mapped to a diagonal line
y    z
----------x
I want to display a map and instead of just displaying it flat I wanted
a pretty rendered 3D view but without any perspective issues.
The map is retangular and so I want its sides parallel and the top and
botom to be horizontal, is this too perverse for POV ray?
I can get fairly close with an orthographic projection but then I have
to shear the image externally to make the nearside of the map horizontal.
Subject: Re: Can I do an Axonometric projection? (primitive game style isometric(ish) projection)
Date: 23 Dec 2004 14:28:15
Message: <41cb1c4f@news.povray.org>
Orthographic is the way to go, but to get the effect you're looking for,
you'll have to shear the *camera*.
Start with a camera looking straight at the X-Y axes (I'm assuming
left-handed coordinates here so the Z axis is pointing away):
    orthographic
    location -z
    right x*mapwidth/2
    up y*mapheight/2
    look_at 0
With this camera, the Z axis will be pointing straight away from the camera.
To make it point kind of diagonally, we can use a simple matrix
transformation:
    matrix <
        1,0,0,
        0,1,0,
        -xamnt,-yamnt,1,
        0,0,0
where xamnt and yamnt are the amounts that the z axis points in the x and y
directions. To match up with your picture, try xamnt = .3 and yamnt = .8.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 24 Dec 2004 05:16:05
Message: <41cbec65$1@news.povray.org>
Thanks that works fine - obvious in hindsight and once you know matrix
transforms are legit on the camera (as long as you don't have vista
buffers - which I don't need but had for some legacy reason).
The end result is a rather odd optical illusion when you use it on a
chequered plane, the squares further away look larger and the right side
of the map looks more sloped.
I'm now playing with the matrix transform on perspective cameras, so
I've now got many options for displaying the map :-)
thanks again
		Martin
