POV-Ray : Newsgroups : povray.newusers : Circular Helix Server Time
1 Nov 2025 14:27:55 EDT (-0400)
  Circular Helix (Message 1 to 10 of 20)
Subject: Circular Helix
Date: 27 Oct 2004 05:28:14
Message: <417f6a2e$1@news.povray.org>
Ok, last question and I'll stop bugging everybody with my n00bness :)
I'm using POV purely because of the ability to script and render a scene;
I'm writing a front end to accomplish the task.
Initially I had expected to export objects to a POV mesh but this particular
scene is particularly complex - hitting over 200MB so far, and I'm not quite
half-way through.
Can POV nativly build a helix that wraps around itself, to form a closed
loop? Imagine a helix following the path of a curve.
All I need to specify is circle diameter, helix thickness and number of
twists (as well as the usual colour/texture etc).
I expect this way to be a lot quicker, if it is supported...
Thanks again for everybody's help so far!
David
Subject: Re: Circular Helix
Date: 27 Oct 2004 11:00:00
Message: <web.417fb7a44c4748cbff5df6e40@news.povray.org>
There is an isosurface called the Helical Torus that does
what you're looking for. Some info on the parameters
are available at this (very excellent!) resource provided
by Mike Williams:
http://www.econym.demon.co.uk/isotut/nfunc2.htm#ht
Here are a couple of helical tori you can use as starting
points. I used the following parameter values for thin rope
trim around a window:
 f_helical_torus(x,y,z, 100, 60, 2,
         1.0, 1,
         0.5,
         0.25, 1, 1.0, 0)
These parameters were for a thick rope around the base of
a pillar:
 f_helical_torus(x,y,z, 6.0, 8, 2,
         0.5, 1,
         0.5,
         0.25, 1, 1.0, 0)
Isosurfaces are not usually considered a newusers feature
as they can be confusing, but once you get used to them
they are much more powerful than normal csg objects.
Also, if you need a mesh, I believe there are macros on
Mike's website that convert isosurfaces to meshes, but
I've not used them.
For non-circular curves, you can draw a normal
isosurface rope (f_helix1) along the path of a spline.
-Mark Slone
Date: 27 Oct 2004 12:05:47
Message: <417fc75b$1@news.povray.org>
"Renderdog" <slo### [at] hiwaaynet> wrote in message
news:web.417fb7a44c4748cbff5df6e40@news.povray.org...
> by Mike Williams:
>          1.0, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> a pillar:
>          0.5, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> I've not used them.
> -Mark Slone
Ah, thanks for the tip. Looks good - but I'm afraid I don't understand POV
enough yet to debug this:
Parse Error: Expected 'object or directive', function identifier found
instead
So, I'm assuming either my syntax is all wrong (I literally copy/pasted) or
I should have some #include files.
Sorry about this, I'll be off everybody's back soon :)
David
Date: 27 Oct 2004 12:30:00
Message: <web.417fcc974c4748cb4428009b0@news.povray.org>
> instead
An isosurface requires more than just the function, you'll
have to read the documentation to make use of the helix
functions in an isosurface.
Here's a little more to go on, but you'll probably have
difficulty with it until you play with the simpler isosurfaces
first.
#local RopeHoop = function {
         1.0, 1,
         0.5,
         0.25, 1, 1.0, 0)
isosurface {
 function { RopeHoop(x,y,z) }
 max_gradient 3.0
 contained_by { box { <0, 0, 0>, <110, 10, 75> } }
 scale 0.04
 rotate -90*x
Date: 27 Oct 2004 13:38:26
Message: <417fdd12$1@news.povray.org>
news:web.417fcc974c4748cb4428009b0@news.povray.org...
POV
> > instead
or
> first.
>          1.0, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> isosurface {
>  max_gradient 3.0
>  scale 0.04
>  rotate -90*x
Thanks a lot for the tip - nearly all sorted now. This is the code so far:
global_settings {
    radiosity {}
    location <0, 0, -5>
    look_at 0
background { color rgb <1, 1, 1> }
global_settings { ambient_light color rgb <0, 0, 0> }
#include "functions.inc"
#declare RopeHoop = function {
         f_helical_torus(x,y,z, 5, 7, 2,
         1.0, 1,
         0.5,
         0.25, 1, 1.0, 0)
isosurface {
 max_gradient 1
 contained_by { box { <0, 0, 0>, <200, 200, 200> } }
 scale 0.1
 rotate 90*x
  pigment { color rgbf <1, 0, 0, 0> }
  finish  { ambient 1 diffuse 1 }
Only real problem right now is that it only renders 1/4 of the scene (but I
have a feeling it is more likely to be building 1/4 of the model). I've
tried playing with a couple of settings but nothing is making enough of a
difference to hit me in the face with a clue...!
I'm also trying to view this from top down.
Thanks a lot,
David
Date: 27 Oct 2004 15:40:01
Message: <web.417ff8e44c4748cb250c7b0b0@news.povray.org>
The f_helical_torus is centered about <0,0,0>, so you might try
   contained_by { box { <-200, -200, -200>, <200, 200, 200> } }
to show the entire object.
f_helical_torus is a hoop about the Y axis, so to view the entire
hoop from above (camera at +Y) you might remove the
   rotate 90*x
which I used to rotate it to face the Z axis.
Finally, the
   scale 0.1
is there because I couldn't get the ratio of the rope to the hoop's
radius what I wanted without scaling the entire object.
Date: 27 Oct 2004 15:43:42
Message: <lYiq5FAKl$fBFwSo@econym.demon.co.uk>
That's because your "contained_by" box has a corner at the origin, but
the helical torus is centred at the origin. So all the bits on the
negative sides are outside the container.
Try
 contained_by { box { -8,8 } }
 max_gradient 3
Mike Williams
Gentleman of Leisure
Date: 27 Oct 2004 15:50:38
Message: <o46pxLAor$fBFwRF@econym.demon.co.uk>
>by Mike Williams:
I actually had no idea that the helical torus could be used to create a
circular helix. When I was developing that tutorial I experimented with
lots of different values but never happened to stumble on a set that
worked that way.
Mike Williams
Date: 27 Oct 2004 15:53:37
Message: <417ffcc1$1@news.povray.org>
I'm not sure if you want it. Tray with this code:
#declare RopeHoop = function { f_helical_torus(x,y,z, 5, 7, 2, 1.0, 1, 0.5,
0.25, 1, 1.0, 0) }
isosurface {
max_gradient 7
contained_by { sphere { .4, 50*2 } }
translate x*10
scale 1
rotate 0*x
Oleguer
news:417fdd12$1@news.povray.org...
> POV
> > > instead
copy/pasted)
> or
> > first.
> >          1.0, 1,
> >          0.5,
> >          0.25, 1, 1.0, 0)
> > isosurface {
> >  max_gradient 3.0
> >  scale 0.04
> >  rotate -90*x
> global_settings {
>     radiosity {}
> camera {
>     location <0, 0, -5>
>     look_at 0
>          1.0, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> isosurface {
>  max_gradient 1
>  scale 0.1
>  rotate 90*x
>  texture {
I
> Thanks a lot,
> David
Date: 27 Oct 2004 16:01:52
Message: <417ffeb0@news.povray.org>
news:web.417ff8e44c4748cb250c7b0b0@news.povray.org...
(but I
a
>    rotate 90*x
> Finally, the
>    scale 0.1
Ok, I'm starting to understand it now. Thanks for everything so far :)
However, I think the Torus aspect is not quite what I had in mind, now that
I can see it in its entirety. I have attached an image to show an example if
it helps. It shows two intertwined helixes.
Hopefully this is achievable? There are going to be a number of these in the
scene, each one larger than this (and with more twists each time) - as I
say, if I export a mesh from a different program, things get unmanageable
very quickly.
Thanks again,
David
Download 'double spun helix.jpg' (36 KB)
Preview of image 'double spun helix.jpg'
