POV-Ray : Newsgroups : povray.newusers : out of memory Server Time
30 Sep 2024 14:17:04 EDT (-0400)
  out of memory (Message 1 to 7 of 7)
Subject: out of memory
Date: 30 Jun 2004 12:07:50
Message: <40e2e556@news.povray.org>
I've managed to create a scene that takes POV-Ray to the limit and beyond,
where memory is concerned.
After 9min of parsing, POV-ray tells me it is out of memory and can't continue.
And looking in the scene file where it stops it has hardly begun...
I have 256MB RAM and 640MB virtual memory allocated on Windows XP.
The scene I'm trying to render is a cloud using a density field (df3) and a
tree with several hundreds of leaves. I'm using a while loop to place these two
objects a number of times in different locations around the scene.
I'm wondering how I can render the scene without problems.
Would increasing the virtual memory help (say, 10x more)?
Please don't tell me I'll need to upgrade ;-)
Maurice
Subject: Re: out of memory
Date: 30 Jun 2004 12:20:02
Message: <cbup06$dl6$1@chho.imagico.de>
SomeOne wrote:
> Hi,
If POV-Ray tells you this the OS is not able to provide POV-Ray more
memory.  I'd try to reduce the scene as much as required to make the
scene render and see what amount of memory is reported in the Render
statistics.  If that's more than you have as physical memory it would be
wise to forget about rendering the scene, if not your OS is probably
broken or misconfigured.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 30 Jun 2004 12:26:30
Message: <40e2e9b6$1@news.povray.org>
How about converting the tree to a mesh, meshes can be repeated for very
little memory cost.  Can you replace the DF3 with simple media, that might
be less memory hungry ( worth experimenting anyway )
Date: 30 Jun 2004 13:30:07
Message: <40e2f89f$1@news.povray.org>
"Josh" <som### [at] microsoftcom> schreef in bericht
news:40e2e9b6$1@news.povray.org...
| little memory cost.
Mmmm. I'd have to look into that. Find out how to make a mess^H^H^H^Hmesh out
of the tree.
The way this cloud looks is sooo perfect, I doubt if it can be done by media.
BTW there are several pictures of this cloud and tree in P.B.I. thread: "New
Project"
Thanks for the suggestion.
Date: 30 Jun 2004 13:37:14
Message: <40e2fa4a$1@news.povray.org>
"SomeOne" <ask### [at] yahoocouknospam> wrote in message
news:40e2e556@news.povray.org...
> Hi,
continue.
a
these two
> Maurice
are you sure the loop ever terminates? maybe it's just creating objects
forever and never reaching a "stop" condition.
Date: 30 Jun 2004 15:37:07
Message: <40e31663$1@news.povray.org>
"Ross" <rli### [at] everestkcnet> schreef in bericht
news:40e2fa4a$1@news.povray.org...
| > Hi,
I'm using two properly terminated  #while loops. They are supposed to create a
total of 80 "islands" as shown in the thread in P.B.I.: "New Project".
Date: 30 Jun 2004 16:19:48
Message: <40e32064$1@news.povray.org>
news:40e31663$1@news.povray.org...
> | > Hi,
beyond,
create a
thought i'd try the easiest solution :)
