POV-Ray : Newsgroups : povray.newusers : Polygon Sweeps Server Time
30 Sep 2024 20:11:31 EDT (-0400)
  Polygon Sweeps (Message 1 to 7 of 7)
Subject: Polygon Sweeps
Date: 23 Feb 2004 13:54:26
Message: <403a4c62@news.povray.org>
Hi all,
    Is there a way to do simple polygon/spline sweep rather than sphere
sweep? By this, I mean sweeping a 2D object along a 3D spline. I feel like
it should be there but I did not see this in the docs.
    Thanks
Subject: Re: Polygon Sweeps
Date: 23 Feb 2004 21:35:41
Message: <cjameshuff-47EE6F.21362623022004@news.povray.org>
In article <403a4c62@news.povray.org>,
There is no built in primitive that does this. However, you can do it by
using the scripting language to build an appropriate mesh, and someone
may have done an include file for this already.
http://tag.povray.org/
Date: 24 Feb 2004 05:41:57
Message: <403b2a75$1@news.povray.org>
bongotastic wrote:
> Hi all,
>     Thanks
you could create two splines, one for the position and the other one for
rotation and simply create many instances of your mesh along the spline.
the problem is that you need an awful lot of objects to make it look
smooth. i did this a while ago to make something like a woven piece of
cloth and it had about 5k objects just for one strand of wool, so it's a
rather ineffective way...
bye,
	Marc
and god said: let there be a light_source { location SUN look_at EARTH,
rgb SUNLIGHT }
Date: 24 Feb 2004 14:12:03
Message: <a3Z+xHAc35OAFw6c@econym.demon.co.uk>
Now that the web interface to news is back up, I can tell you that you
can get my SweepSpline macro which does that from
http://news.povray.org/povray.binaries.scene-files/thread/%3C3fb73d9e%40news.povray.org%3E/
(The trick for finding the message-id, and thereby writing more direct
and shorter URLs seems to not be present any more, so you'll have to
make do with this long threadwise URL.)
For a polygon to work properly, you should make it a linear_spline and
ensure that its control points take values that are multiples of
1/Vpoints. E.g. if you tell the mesh to use 20 points around the
circumference, then you can set your control points to multiples
of 0.05
Mike Williams
Gentleman of Leisure
Date: 24 Feb 2004 22:05:29
Message: <403C119C.F3B06CBF@tag.povray.org>
Use - http://tinyurl.com/
This -
Becomes this -
http://tinyurl.com/2u4ox
Ken Tyler
Date: 25 Feb 2004 10:32:40
Message: <403cc018$1@news.povray.org>
Thanks, I will try this later on today.
bongo
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:a3Z+xHA### [at] econymdemoncouk...
like
> of 0.05
> Mike Williams
Date: 25 Feb 2004 10:56:16
Message: <403cc5a0$1@news.povray.org>
In article <a3Z+xHA### [at] econymdemoncouk> , Mike Williams
.povray.o
> rg%3E/
It will be back in a few days.
<http://news.povray.org/*/thread/%3C3fb73d9e%40news.povray.org%3E/>
or for the message
<http://news.povray.org/%3C3fb73d9e%40news.povray.org%3E>
will also work.
    Thorsten
e-mail: tho### [at] trfde
