POV-Ray : Newsgroups : povray.newusers : Lighting Server Time
14 Jul 2026 22:33:25 EDT (-0400)
  Lighting (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Lighting
Date: 4 Feb 2004 21:58:08
Message: <4021b140$1@news.povray.org>
Oh, and I forgot about the table too! A little reflection there and a little
specular highlight and BAM (to steal from Emeril)!
#include "textures.inc"
#include "shapes.inc"
#declare SnakeWood =
texture {  /* Bottom wood-grain layer */
        wood
        turbulence 0.05
        color_map {
            [0.00 rgb <0.58, 0.45, 0.23>]
            [0.34 rgb <0.65, 0.45, 0.25>]
            [0.40 rgb <0.33, 0.23, 0.13>]
            [0.47 rgb <0.60, 0.40, 0.20>]
            [1.00 rgb <0.25, 0.15, 0.05>]
    finish {
        crand 0.02
        //ambient 0.32
        diffuse 0.63
        phong 0.2
        phong_size 10
    normal { bumps 0.05 }
texture {     /* top layer, adds small dark spots */
        bozo
        color_map {
            [0.0 rgbt <1.00, 1.00, 1.00, 1.00>]
            [0.8 rgbt <1.00, 0.90, 0.80, 0.80>]
            [1.0 rgbt <0.30, 0.20, 0.10, 0.40>]
    scale 0.25
// New stuff -- DAP
light_source
  <60, 20, -50>
  color rgb <0.2, 0.25, 0.3>
  shadowless
sky_sphere
 pigment
  wrinkles
  color_map
   [0, rgb <0, 0, 0> ]
   [1, rgb <0.7, 0.6, 0.5> ]
  scale <0.1, 0.1, 0.1>
light_source {<-20, 20, 0> color White area_light  <5, 0, 0>, <0, 0, 5>, 11,
11 adaptive 1 jitter photons { refraction on reflection on } }
camera  {
        location <0,10,-25> look_at <0,0,0>
//background { Black }//color <0.25,0.35,0.80> }
box     {
        <-1,-1,-1>,
        <1,1,1>
                pigment { Red }
        scale <2,2,2>
        rotate <0,-15,0>
        translate <2,1,10>
box     {
        <-1,-1,-1>,
        <1,1,1>
                pigment { Red }
        scale <2,2,2>
        rotate <0,-16,0>
        translate <2,1,-9>
cylinder{
        <-1,-1,-1>,
        <1,1,1>,
        1
                pigment { White*2 }
        scale <1,5,1>
        translate <-7,3,0>
plane   { <0, 1, 0>, -0.001
        texture { SnakeWood }//pigment { checker pigment{Red},
pigment{White} } scale <10,10,10> rotate <0,43,0>}
        finish { specular 0.3 reflection 0.15 }
#declare Point1 = <-10,1,10>;
#declare Point2 = <-10,1,0>;
#declare Point3 = <-10,1,-10>;
#declare Point4 = <0,1,-10>;
#declare Point5 = <10,1,-10>;
#declare Point6 = <15,1,2>;     //<10,1,0>;
#declare Point7 = <10,1,2>;    //<10,1,10>;
#declare Point8 = <0,1,10>;
#declare Point9 = <-14,1,12>; //<-10,1,10>;
#declare Point10 = <-10,1,0>;
#declare Point11 = <-10,1,-10>;
merge {
// outside of the puddle
sphere_sweep {
        cubic_spline
        11,
        Point1,1
        Point2,1
        Point3,1
        Point4,1
        Point5,1
        Point6,1
        Point7,1
        Point8,1
        Point9,1
        Point10,1
        Point11,1
// inside of the puddle
prism {
    cubic_spline
    0, // sweep the following shape from here ...
    2, // ... up through here
    11, // the number of points making up the shape ...
        <Point1.x,Point1.z>,
        <Point2.x,Point2.z>,
        <Point3.x,Point3.z>,
        <Point4.x,Point4.z>,
        <Point5.x,Point5.z>,
        <Point6.x,Point6.z>,
        <Point7.x,Point7.z>,
        <Point8.x,Point8.z>,
        <Point9.x,Point9.z>,
        <Point10.x,Point10.z>,
        <Point11.x,Point11.z>
        hollow
                 rgbft <0.2, 0.16, 0, 0.8, 0.3>
                        //Clear // rgbt <0.858824,0.576471,0.439216>
                finish  {
                        reflection { 0.1,0.9 }
                        specular 0.5
        interior        {
                        ior Water_Ior
        translate <0,-1.5,0>
Date: 5 Feb 2004 06:20:00
Message: <opr2v9spm2p4ukzs@news.povray.org>
On Wed, 4 Feb 2004 16:34:56 -0000, Felbrigg <som### [at] microsoftcom> wrote:
> I've already posted a couple of images in the binaries.images section
> namely
> "Cactus halo" and "Rain Drops" but if you would like to help me out, look
> there for one I've just posted called "Spilled Liquid" (Source included)
> This is an example of an almost but never quite right table top image.
> If
> you can give me some tips on how to improve it, adjusting the lighting
> etc I
> would be very grateful.
> Thanks.
> "Dan P" <dan### [at] yahoocom> wrote in message
> news:402117ff$1@news.povray.org...
>> Also, I find that using multiple light sources can go along way. Throw a
>> bright, shadowless indigo light at a different location (color rgb <0.8,
>> 0.9, 1> for example) and it will add a lot of depth. In reality, there
>> is
>> rarely only one light source and you don't always need radiosity to get
>> a
>> realistic effect. Look at a book cover once: often, you'll see that one
> side
>> of the face is lit with a yellowish light and the other side is light
>> with
>> an indigo/cyan light. It makes a really neat effect.
>> If you're willing, we're interested in seeing your work if you post it
>> on
> a
>> site and helping you out that way too. There are lots of tricks of light
>> (pun intended) that can turn a blah scene into something amazing.
If you are still interested google "three point lighting"
http://www.3drender.com/light/3point.html
This link's quite basic but still worth a look at, more advanced stuff is
also available on google
Hope it's of use to you.
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 5 Feb 2004 06:55:54
Message: <mpb420h1n2f5c13n3f0k9u9liqsephasdu@4ax.com>
On Wed, 4 Feb 2004 16:34:56 -0000, "Felbrigg" <som### [at] microsoftcom> wrote:
> If you can give me some tips on how to improve it, adjusting the lighting etc I
Interesting reading here. Again basic but that is what you need to start out
with.
http://www.cybercollege.com/indexall.htm
Lighting starts here
http://www.cybercollege.com/tvp027.htm
Regards
Date: 5 Feb 2004 07:14:42
Message: <402233b2$1@news.povray.org>
Where to begin?
The second coloured light, had me foxed at first, I couldn't see the
difference until I opened "before" and "after" side by side in paint shop.
It does improove the scene - Good Tip.
Specular highlighting, hmm,  rendered it despite my misgivings and at first
I thought I was right and you were wrong, again, side by side in Paint shop
and WOW, it is better, you were right.  It gives better definition to the
spill, allowing the liquids edge to look truely curved.
Coffee colouring, nice.  I'd tried rgbf and rgbt but you hit me with a new
one there, rgbft, again WOW.
Reflection and specular on the table, didn't see that one coming.  Took me a
while to see a difference, It seems to have made the light source have a
sharper definition on the table top.  Is that it?  Can you give me any
pointers as to why you suggested this, what am I missing?
I'm struggling with this lighting stuff,  so much of it seems
counter-intuitive to me.  Your pointers have been really eye - opening.
Thanks very much.
P.S. I see from your other posts your a 'C' man.  Scary stuff, the nearest
I've got to that is C# what I call "the laymans C".  Do you know if it
possible to use C# to fire off PovRay like (i think) Moray does.  I've often
thought about writing a Win32 app to automate some animation experiments,
thus freeing me from the clock and frames constraints.
news:4021b140$1@news.povray.org...
little
>     pigment {
>         wood
>         turbulence 0.05
>         color_map {
>     finish {
>         crand 0.02
>         //ambient 0.32
>         diffuse 0.63
>         phong 0.2
>         phong_size 10
>     pigment {
>         bozo
>         color_map {
>     scale 0.25
> // New stuff -- DAP
> light_source
>   <60, 20, -50>
>   shadowless
> sky_sphere
>  pigment
>   wrinkles
>   color_map
>    [0, rgb <0, 0, 0> ]
11,
> camera  {
> box     {
>         <-1,-1,-1>,
>         <1,1,1>
>         texture {
>                 pigment { Red }
>         scale <2,2,2>
>         rotate <0,-15,0>
>         translate <2,1,10>
> box     {
>         <-1,-1,-1>,
>         <1,1,1>
>         texture {
>                 pigment { Red }
>         scale <2,2,2>
>         rotate <0,-16,0>
>         translate <2,1,-9>
> cylinder{
>         <-1,-1,-1>,
>         <1,1,1>,
>         1
>         texture {
>                 pigment { White*2 }
>         scale <1,5,1>
>         translate <-7,3,0>
> merge {
> sphere_sweep {
>         cubic_spline
>         11,
>         Point1,1
>         Point2,1
>         Point3,1
>         Point4,1
>         Point5,1
>         Point6,1
>         Point7,1
>         Point8,1
>         Point9,1
>         Point10,1
>         Point11,1
> prism {
>     cubic_spline
>         hollow
>         texture {
>                 pigment {
>                 finish  {
>                         specular 0.5
>         interior        {
>                         ior Water_Ior
Date: 5 Feb 2004 09:05:48
Message: <cjameshuff-B435B0.09055805022004@news.povray.org>
In article <402233b2$1@news.povray.org>,
You'll learn to see this kind of thing more easily...just takes time and
practice. Before long you won't be able to stop. YKYBRTTLW...
Bad advice, IMO. The most realistic method that I've found is to use an
entirely transparent texture (a pigment with rgbf 1), and media or
interior attenuation for coloring. A colored transparent texture is like
a thin film covering the coffee, but this simulates color throughout the
body of the coffee.
http://tag.povray.org/
Date: 6 Feb 2004 00:01:17
Message: <40231f9d$1@news.povray.org>
"Felbrigg" <som### [at] microsoftcom> wrote in message
news:402233b2$1@news.povray.org...
> Where to begin?
first
shop
The higher the specular value, the more defined the highlight becomes.
a
It added a highlight to the table. The trick is that it makes the surface
look less uniform.
> Thanks very much.
No problem! :-)
often
Sure, you can fire off POV-ray with pretty much any language -- it's just a
matter of running pvengine.exe. My job allows me to do a lot of different
programming languages so I get a really different perspective sometimes.
I'm glad I was able to help and I really liked that scene! It would be the
perfect scene for a tutorial too.
Date: 6 Feb 2004 00:05:47
Message: <402320ab$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-B435B0.09055805022004@news.povray.org...
> body of the coffee.
Thanks for the tip! It makes sense to make the actual liquid itself the
color and not just the skin around the outside. The reason I did it that way
was for speed, really; I find interior media to really slow down my
renderings and I like to do a lot of animation with motion blurs so I throw
out a lot of frames. However, for a still-shot, I think Chris is definitely
right here -- it'll make the light interact with the coffee better.
Date: 6 Feb 2004 10:27:27
Message: <cjameshuff-5E6769.10274006022004@news.povray.org>
In article <402320ab$1@news.povray.org>,
Absorbing media will have a much lesser impact on speed than scattering
media, especially when there's no variation in density to sample. And
interior attenuation is very fast, because it never has to handle
variable density and can use a much simpler method to compute the
attenuation.
Date: 6 Feb 2004 10:36:27
Message: <cjameshuff-886A52.10363906022004@news.povray.org>
In article <40231f9d$1@news.povray.org>,
The higher the specular value, the brighter it becomes, specular 1
giving full brightness at the brightest points of the highlight. The
"roughness" parameter controls the "sharpness" of the highlight...small
values will give a more hard, highly polished look.
Date: 6 Feb 2004 11:15:52
Message: <4023bdb8@news.povray.org>
news:cjameshuff-5E6769.10274006022004@news.povray.org...
> attenuation.
Oh, I see what you mean. I was basing that perception on scattering media,
not absorbing media. I'm really glad I've been reading these newsgroups --
it's been having a very positive impact on my scenes. Thanks, Chris!!!
