POV-Ray : Newsgroups : povray.newusers : Simple outdoor landscapes for fast-rendering Server Time
12 Jul 2026 03:47:28 EDT (-0400)
  Simple outdoor landscapes for fast-rendering (Message 1 to 10 of 10)
Subject: Simple outdoor landscapes for fast-rendering
Date: 25 Jan 2004 22:38:27
Message: <40148bb3@news.povray.org>
I'm about to try my hand at some outdoor scenes, where I'd like rolling
hills.
Any tips on the best way to get a fast-rendering scene (for use in
animations)
height fields,  isosurfaces, bicubic patches,  one of the above then
converted to meshes ?
I'm guessing my biggest mistake with povray is always wanting to model an
entire continent rather than just  the area in the field of view ahead of
me.
Subject: Re: Simple outdoor landscapes for fast-rendering
Date: 25 Jan 2004 23:46:36
Message: <40149bac@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:40148bb3@news.povray.org...
> hills.
> animations)
I personally like using patterns as functions in height_fields:
Note how fast this scene renders:
camera
 location <0, 2, 0>
 rotate 30*x
sky_sphere
 pigment
  gradient y
  color_map
   [0.5 rgb <1, 1, 1> ]
   [1 rgb <0, 0, 0> ]
light_source
 <-100, 100, -100>
 color White
#declare f_hills =
function
 pattern
  bumps
  scale <0.1, 0.1, 0.1>
height_field
 // Incease your resolution here if you need to.
 function 256, 256 { f_hills(x, y, z) }
 smooth
 pigment
  color rgb <1, 1, 0.8>
 translate <-0.5, 0, -0.5>
 scale <10, 0.5, 10>
camera
 location <0, 2, 0>
 rotate 30*x
sky_sphere
 pigment
  gradient y
  color_map
   [1 rgb <0, 0, 0> ]
light_source
 <-100, 100, -100>
 color White
#declare f_hills =
function
 pattern
  bumps
height_field
 smooth
 pigment
 scale <10, 0.5, 10>
Date: 25 Jan 2004 23:58:57
Message: <40149e91$1@news.povray.org>
> hills.
> animations)
iso's just seem the right thing for me, except it does have the pitfalls of
getting it to look right. By that I mean the surface deformations together
with a texture.
HF's are nice sometimes but you would have a more difficult time getting
both a fast and good surface due to the parse times demanded of higher
resolutions. I'd think meshes would also suffer the same fate, since by
animating you don't preserve the mesh in memory like a copy of it in a
still.
Here's a quick example of rolling hills made with a iso having a simple bump
pattern. Rendering 16 frames of it at 160x120 pixels and with default AA
takes a mere 24 seconds on my P4 2 GHz notebook. Even though it would get
slower as more detail were added it could be easiest to work with and
animate. My opinion anyway.
[oh good, I see now that Dan P replied with a HF example which
renders more than twice as fast as my iso here. Although, I get an artifact
on its horizon for some reason.]
#declare RollingHills=
function {
 pigment {bumps}
isosurface {
 function {
  y-RollingHills(x,y,z).gray*0.5
 contained_by {
  box {-<10,1,10>,+<10,1,10>}
 threshold 0
 accuracy 0.01
 max_gradient 1
 pigment {rgb <0.4,0.9,0.5>}
Bob H.
http://www.3digitaleyes.com
Date: 28 Jan 2004 22:12:51
Message: <40187a33$1@news.povray.org>
Here's a modification of Daniel's code.  Why is there a distortion in x but
not z??
#include "functions.inc"
camera
 location <0, 2, -10>
 rotate 90*y
light_source
 <-100, 100, -100>
 color White
#declare f_hills =
function
 pattern
  bumps
#declare blah=10;
#declare f_hills2=function{f_noise_generator(x,y,z,2)}
height_field
 function 256, 256 { f_hills2(x*blah, y, z*blah) }
 smooth
 pigment
 scale <10, 0.5, 10>
Date: 29 Jan 2004 19:13:24
Message: <4019a1a4$1@news.povray.org>
news:40187a33$1@news.povray.org...
but
> not z??
I was "flattening" the landscape by scaling Y. Otherwise, it was too hilly.
Date: 30 Jan 2004 12:25:55
Message: <401a93a3$1@news.povray.org>
"Greg M. Johnson" wrote in message news:40187a33$1@news.povray.org...
> but not z??
If you use (x*blah, y*blah, z) instead of (x*blah, y, z*blah) you get what you
expect to see. The question is: Why? Is f_noise_generator right-handed?
Date: 30 Jan 2004 22:00:45
Message: <401b1a5d$1@news.povray.org>
"Tim Riley" <tim### [at] netscapenet> wrote in message
news:401a93a3$1@news.povray.org...
> > but not z??
you
It's a matter of style for me. I like to set things up so that I can easily
modify them later. I find tacking on a scale on the end is easier to
comprehend, for me, than changing the parameters to the function. But, I'm
kindof a dimwit, and you can always tell that in my code (cough, production
code, Warp :-) ) because if I don't make it readable, I can't read it later
and I stop enjoying writing code. Think of me as a painter who loves to
paint but would never cut his ear off. That's why I enjoy reading these
newsgroups because everybody on it is more clever than I and I learn more
from that than reading documentation.
Date: 31 Jan 2004 09:29:31
Message: <401bbbcb@news.povray.org>
> > but not z??
you
The reason is that function n,n works as an image_map, which exists in the
x,y plane (and from top to bottom in the y direction IIRC). The z in this
case isn't taken into account.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 2 Feb 2004 14:03:07
Message: <401e9eeb$1@news.povray.org>
Ah, now it makes sense. I couldn't find a reference to it in the help file
earlier, but I just looked again and there it was - "6.7.11.16  Function Image".
My computer must have been experiencing a temporal reference breach; I doubt if
it had anything to do with the fact that I was searching for it at 2am.
Date: 2 Feb 2004 17:54:45
Message: <401ed535$1@news.povray.org>
news:401e9eeb$1@news.povray.org...
Image".
doubt if
Sorry, I misunderstood the question :-) Thanks for the save, Gilles.
