POV-Ray : Newsgroups : povray.newusers : Poser 5 Server Time
21 Mar 2026 10:53:37 EDT (-0400)
  Poser 5 (Message 1 to 10 of 43)
Subject: Poser 5
Date: 9 Jan 2004 20:35:54
Message: <3fff56fa$1@news.povray.org>
Has anyone determined if they can convert/import Poser 5 models to PovRay?
If so, are there limitations? I've been doing a lot of Google searches and
have only found references to Poser X <= 4. Money is tight for the Danster
and I only want to invest in Poser 5 if I'm sure I can cleanly put my models
in PovRAY.
Thanks!
- Respectfully,
Dan
"When it is not in our power to follow what is true,
we ought to follow what is most probable."
                                         - Rene Descartes
Subject: Re: Poser 5
Date: 9 Jan 2004 21:38:48
Message: <3fff65b8$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message
news:3fff56fa$1@news.povray.org...
models
> in PovRAY.
> Thanks!
Alright, I've decided I have no choice; I have to take the risk if I'm going
to make this game. So, I'll get on this and report my findings regarding
Poser 5. :-)
Date: 10 Jan 2004 01:20:16
Message: <3fff99a0$1@news.povray.org>
"Dan P" <dan### [at] yahoocom> wrote in message news:3fff65b8
going
> Poser 5. :-)
To close my own thread, yes; Poser5 works with Povray by outputting a
Wavefront .obj object and converting it with PoseRay. No weirdness hath I
found. But, I'm a fairly new Poser user.
(Whew... money wasn't wasted. In fact, Poser5 seems to be well worth the
cash!!!)
Date: 10 Jan 2004 02:51:14
Message: <Uk4NlDAd46$$Ewd$@econym.demon.co.uk>
>in PovRAY.
The techniques for Poser 4 work for Poser 5 except for the handling of
strand based hair.
P5 strand based hair is saved as guide strands, not a polygon mesh. I'm
not aware of any method of converting this data into anything that can
be correctly rendered in anything else.
If there were to be something that would correctly convert strand based
hair to POV format it would have to use the guide hair information to
generate the *actual* hairs. It would probably also have to work from
actual Poser data files, because most of the export formats don't
support all the information required to rebuild the hair correctly. E.g.
in OBJ format there doesn't appear to be any information about how many
actual hairs to generate per guide strand nor any information about how
the radius of the strand changes along the length of the hair.
In practice, very few P5 users end up using strand based hair to any
great extent. It's an absolute pain to get it to look anything like
reasonable, and it renders slowly in P5 itself. If you look at any forum
where Poser 5 images are posted you'll see very few that use strand
based hair.
Mike Williams
Gentleman of Leisure
Date: 10 Jan 2004 15:22:02
Message: <40005eea@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:Uk4NlDAd46$$Ewd$@econym.demon.co.uk...
> strand based hair.
> based hair.
Very true.  I posted an attempt (in p.a-u) to get Poser 5 dynamic hair to
work in a somewhat reasonable manner.  I think it might be possible, but I
eventually gave up the pursuit (at least for now), thinking that it was just
too difficult, and the benefits weren't enough to make me continue.  And, as
you said, I'm still not completely sold on the idea of dynamic hair.  It
sounds good, but my results (in P5) just weren't any more impressive than
using other types of hair.
Jeremy
www.beantoad.com
Date: 10 Jan 2004 15:29:36
Message: <400060b0$1@news.povray.org>
Sorry, I didn't see your post last night, or I would have replied.
I'm also new to Poser 5, having bought it just a few weeks ago.  Make sure
you download the latest service pack (SP3), though.  It makes a big
difference.  Also, I've heard that you should have at least 512MB of RAM for
it to run in a stable manner, but if you're using it fine with with less,
good for you.
PoseRay is an amazing tool.  I'm very impressed with how far FlyerX has
taken it in just the past year.  Before that, converting Poser models was an
arduous process.  It's still not the easiest thing, though.  I'm still
learning many of the in's-and-out's of using it as well.
I've sometimes thought that we should have a povray.poser group here because
of all of the Poser users we have.  Personally, I'm never quite sure where
to post on that topic.
Jeremy
www.beantoad.com
news:3fff99a0$1@news.povray.org...
> going
> > Poser 5. :-)
> cash!!!)
Date: 10 Jan 2004 20:04:35
Message: <4000a123$1@news.povray.org>
"Jeremy M. Praay" <sla### [at] hotmailcom> wrote in message
news:40005eea@news.povray.org...
<snip>
just
as
At least PovRay did render the guide hairs, though. I thickened the guide
hairs to 0.0004 in the .inc file and got some results (it looked like a mop,
though). You're right, though; PoseRay, although worked perfectly for
converting the .OBJ files to .INC so there's no risk to getting Poser5 and
not being able to create PovRay models (which was my main concern), the
dynamic hair thing just didn't seem to be economical yet.
I run a 1.5 Ghz machine with 1G of memory and it still took a while to parse
it out in PovRay with just the guide hairs alone. The feature works really
good, though; the computer technology just has to catch up to it yet.
Date: 10 Jan 2004 20:27:51
Message: <4000a697$1@news.povray.org>
news:4000a123$1@news.povray.org...
> <snip>
<Hack!>
no problem getting the figures into POV-Ray, the problem is getting them
posed so they fit where you want them to.  IF you want them sitting on a
chair generated in POV, poser won't import the chair so you can see it to
make the figure fit.
Date: 10 Jan 2004 21:05:24
Message: <cjameshuff-5DFB8F.21053510012004@netplex.aussie.org>
In article <4000a123$1@news.povray.org>,
Raytracing isn't very good at rendering very small objects...such
objects can easily fall between pixels, and tracing enough additional
samples to catch them is time consuming. I've been thinking about
various possibilities with media using direction-dependent
textures...I've already done some tests, though with a function pattern
(using my function pattern extensions) on a surface rather than in
media. Perhaps this can help fill out hair generated through actual
geometry...and this is another area where some form of variable
antialiasing would be useful.
http://tag.povray.org/
Date: 10 Jan 2004 21:07:28
Message: <4000afe0@news.povray.org>
"GreyBeard" <r.b### [at] sbcglobalnet> wrote in message news:4000a697
<Chop!>
Perhaps a good way to do this would be to create a patch in SPatch/HamaPatch
that generally conforms to the same dimensions of the chair (but with
considerably less detail). When Poser exports the scene to Wavefront .obj,
and then PoseRay exports the .obj to .pov, the chair will be isolated in
your .pov file. Then, just replace the chair patch with your real chair (in
what ever method you used to make it -- very likely not a patch, of course,
if it is made in PovRay alone).
