POV-Ray : Newsgroups : povray.newusers : Texture Library plugin Server Time
18 Jan 2026 05:15:32 EST (-0500)
  Texture Library plugin (Message 1 to 10 of 15)
Subject: Texture Library plugin
Date: 7 Aug 2003 08:38:44
Message: <3f324854$1@news.povray.org>
Hello,
I used Pov-Ray a few years ago when designing furniture pieces. At the
time there was a brilliant little plugin that visually showed all the
textures in Pov-ray plus a few more. Metal, Stones etc. It was very
small and worked perfectly. You could visually browse the
textures/finishes and then double click the one you wanted and it would
automatically insert the declaration. Unfortunately with non-use and new
PC's etc, I have lost it. I wonder if anyone knows what/where it is? For
someone who is trying to use Pov-ray for making 3d designs a little more
realistic but does not want to get into creating whole new textures it
was invaluable. If anyone can help, it would be appreciated.
Thanks
Subject: Re: Texture Library plugin
Date: 7 Aug 2003 08:55:06
Message: <7ni4jvgp2qkstm76cg77a7u5v9tc5kn1d6@4ax.com>
On Thu, 07 Aug 2003 13:38:52 +0100, Patrick <pat### [at] myrealboxcom>
wrote:
> For
Even plugin can only take effect from process of "creating whole new textures"
and then I don't see what is advantage of that plugin over customizable Insert
Menu with prerendered images ?
http://abx.art.pl/pov/bonus/
ABX
Date: 7 Aug 2003 09:14:32
Message: <3F325217.CC7B3A90@pacbell.net>
Patrick wrote:
> Hello,
TextureVeiw?
http://www.friedemann-schmidt.com/software/index.html
Ken Tyler
Date: 7 Aug 2003 12:36:55
Message: <3f328027$1@news.povray.org>
Thanks Ken,
that is exactly what I was after. Thanks also to ABX.
Great response!
Ken wrote:
> Patrick wrote:
>>Hello,
> TextureVeiw?
Date: 7 Aug 2003 16:21:32
Message: <MPG.199c618aece985e9989854@news.povray.org>
In article <7ni4jvgp2qkstm76cg77a7u5v9tc5kn1d6@4ax.com>, abx### [at] abxartpl
says...
You mean besides the fact that there is an internal limit on the number
of items in this menu and that the last batch I added suddenly caused
POV-Ray to show menu images on menus 'other' than the insert menu as a
side effect?
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 8 Aug 2003 02:24:56
Message: <c9g6jvohfqcgie45tjdpj21bn8td0umliv@4ax.com>
On Thu, 7 Aug 2003 13:16:35 -0700, Patrick Elliott <sha### [at] hotmailcom>
> says...
What limit? I just looked into BuildDirList function in codemax code and do
not see any hardcoded limit.
> side effect?
Can you write me more about it?
Have you already reported your problems somewhere ?
ABX
Date: 8 Aug 2003 12:28:36
Message: <3f33cfb4$1@news.povray.org>
>>says...
>>side effect?
> ABX
I mentioned this a while back (a couple of months perhaps, but a search
of news.povray.org doesn't reveal the message) and didn't see a response
that addressed a solution. This also was brought up by Thomas Eicher on
10 Sept, 2002. It shows up when adding a couple of Insert menu add-ons
("Basic templates" by Friedrich Lohmueller and "IsoCSG include file" by
a person whose name I don't have access to at this time).
Two problems show up:
1) Past a certain point in the Insert menu, nothing is inserted in the
    file being edited. With both add-ons installed, Shapes/quadric will
    insert text, but Shapes/quartic will not. This breakpoint changes
    depending on which add-ons are present, and what position they are
    placed in the menu.
2) Previews show up in strange places. With the above mentioned add-ons
    installed, I see previews under various items in the Render menu (for
    example "Select File and Render" and "Run Demo"). They show up all of
    the way through to "Help/About POV-Ray for Windows...".
Let me know if you need any additional info.
Date: 8 Aug 2003 21:16:04
Message: <MPG.199df8172330d692989855@news.povray.org>
In article <3f33cfb4$1@news.povray.org>, tim### [at] netscapenet
says...
>     placed in the menu.
Exactly. I have the IsoCSG one and the scene templates menus, but as far
as I know I haven't run into item 1 above. However, I do suffer from item
2. On mine I am get the following quirks:
Menu                            Image
Render - Edit Settings          CSG Operations - Intersection
Render - Start Render           Patterns 1 - Cylindrical
Render - File Queue             Patterns 1 - Brick
Render - Animation - No Shell.. IsoCSG include file  - iso_bcsg.inc
                                  - shape macros - IC_BSuperellipsoid
Options - Other Settings
  - Show Tips of the Day        IsoCSG include file - iso_chars.inc
                                  - IC_Text()
  - Show Next Tip               Pattern/Texture Attributes
                                  - Wave form attribute
Options - Render Window
  - Force 8-bit display         Patterns 1 - function
  - Close                       Transformations - Rotate
  - Keep Above Main             IsoCSG include file - iso-csg.inc
                                  - shape macros - IC_Box()
Options - Message Window
  - Select Plain Background     Transformation - Translate
  - Text Font                   IsoCSG include file - iso-csg.inc
                                  - CSG macros - IC_Difference4()
  - Text Color                  IsoCSG include file - iso-csg.inc
                                  - CSG macros - IC_Merge2()
  - Choose Background - Browse  IsoCSG include file - iso-csg.inc
                                  - IC_Displace()
Help - Bug Reporting            Patterns 1 - Slope
Help - Show Tip                 Pattern/Texture Attributes
Help - About...                 Patterns 2 - Leopard
It may help to know if this is common to all cases of having those menu
extensions installed. I think this started happening right after I
installed the CSG ones, but before adding the Basic scene template one,
so the CSG by itself may somehow be doing it. It is definitely odd and I
don't trust the menu at all because of it.
void main () {
  else
Date: 8 Aug 2003 21:23:25
Message: <MPG.199df9cf9da2704989856@news.povray.org>
In article <3F325217.CC7B3A90@pacbell.net>, tyl### [at] pacbellnet says...
> Patrick wrote:
> > Hello,
> TextureVeiw?
Hmm. The plugin won't work on my copy of 3.5 for some odd reason. It will
load POV-Ray and apparently does something.. But there is no rendering,
it just dims the 'Render' button and the after a bit times out or
something and goes back to normal, with no image created for the texture.
Needless to say this kind of defeats the purpose of the program. :p
Does anyone else have this issue?
void main () {
  else
Date: 11 Aug 2003 05:20:50
Message: <ngnejvo53l7dknjhlbla70cgj6sarajuh9@4ax.com>
On Fri, 08 Aug 2003 10:28:35 -0600, Tim Riley <tim### [at] netscapenet>
I would need some screenshots and your system specification. IIRC Insert Menu
is handled by CodeMax library and I think debugging and recompiling it is much
more complicated than povray sources but who knows...
ABX
