POV-Ray : Newsgroups : povray.newusers : Texture Library plugin Server Time
5 Jul 2026 03:37:07 EDT (-0400)
  Texture Library plugin (Message 11 to 15 of 15)
Subject: Re: Texture Library plugin
Date: 11 Aug 2003 13:41:20
Message: <3f37d540@news.povray.org>
"Patrick Elliott" <sha### [at] hotmailcom> wrote in message
news:MPG.199df9cf9da2704989856@news.povray.org...
> In article <3F325217.CC7B3A90@pacbell.net>, tyl### [at] pacbellnet
says...
> Hmm. The plugin won't work on my copy of 3.5 for some odd reason. It
will
> load POV-Ray and apparently does something.. But there is no
rendering,
> it just dims the 'Render' button and the after a bit times out or
> something and goes back to normal, with no image created for the
texture.
> Needless to say this kind of defeats the purpose of the program. :p
> Does anyone else have this issue?
     Yep, me Patrick. Is it supposed to render the images though? Or
is there something we're both missing? If we have to render the
images, how long will it take? I have something like 550 textures on
my PC.
    ~Steve~
> void main () {
>     call functional_code()
>   else
>     call crash_windows();
Date: 11 Aug 2003 17:29:01
Message: <MPG.19a1b77362e340ed989857@news.povray.org>
In article <3f37d540@news.povray.org>, dot### [at] dotcom says...
> says...
> will
> rendering,
> texture.
> my PC.
>     ~Steve~
It is supposed to render which ever ones you have selected in order to
generate its internal thumbnail list. It uses some sort of
special database to store this stuff, so I don't think you can simply
take the needed POV file, render it and then try to tell the texture
viewer to import that image. Instead it appears that it is supposed to
work like the preview function that Moray has for textures. Otherwise,
there is really no point at all for it to use a .pge to link the two
together. After all, it can't directly import the text for the texture
anyway, you have to cut and paste it.
Something must have inadvertently been changed in POV-Ray 3.5 that
interferes with this plugin talking to POV-Ray correctly. :( I do
remember it worked right using 3.1 back when I had both programs
installed on my old 486. I 'could' try setting it to use the version of
3.1 I still have installed, but there are new things in 3.5 that you
still couldn't render a thumbnail for in 3.1. :p
Hmm. Trying to remember, was there a source code file for the viewer in
the site? Maybe someone could track down the issue and fix it if so, but
since my eyes cross every time I look at the plugin interface code, I
would prefer it to be someone that knows what they are doing. ;) lol
void main () {
  else
Date: 11 Aug 2003 21:35:21
Message: <3F3845CC.B20545F0@pacbell.net>
You could always try contacting the author of the program :)
mailto:web### [at] friedemann-schmidtcom
I am pretty sure that his last update was for POV-Ray v3.1g and he may not
have gotten around to adapting it to v3.5.
Ken Tyler
Date: 12 Aug 2003 15:52:16
Message: <MPG.19a1bb17ca8e7a91989858@news.povray.org>
Just tested it. 3.1g renders the thumbnail correctly. So something got
changed in 3.5 or something that stops this from working right... This is
not good imho, since the plugin stuff is complicated enough to figure out
with minimal examples, without it turning out that in some cases it may
no longer even work at all. :( Of course it is possible that something in
the texture viewer is at fault, but since it appears to suffer from what
you would normally expect if a COM interface hung and then timed out,
this seems to me unlikely.
void main () {
  else
Date: 12 Aug 2003 16:26:05
Message: <MPG.19a2fa364a248f898985b@news.povray.org>
In article <3F3845CC.B20545F0@pacbell.net>, tyl### [at] pacbellnet says...
True enough, but as far as I was aware, there where no changes to the
code involving the plugins in 3.5, so it 'should' work anyway. Otherwise
older versions of Moray, which use much the same interface, would stop
working right as well. It seems really odd, but I guess contacting him is
probably best.
void main () {
  else
