POV-Ray : Newsgroups : povray.newusers : Is there a function... Server Time
20 Jun 2026 04:36:37 EDT (-0400)
  Is there a function... (Message 1 to 7 of 7)
Subject: Is there a function...
Date: 9 Jul 2003 08:00:56
Message: <3f0c03f8@news.povray.org>
1.  ...that makes simple object "roundedged", so that all is looking more
realistic?
Be aware, i do NOT mean antialiasing. It's just the fact that nothin in
reality is as sharp-edged, as the results in povray are, what theoretically
is a good thing, because it has to be mathematically exact.
But if i am constructing p.e. an chair or a table, there is an enormous
effort for rounding the edges making it look like REAL wood, plastic, etc,
because real materials (except steel) are never as sharp, as they are in
pov, because they are not hard enough...
2.  ...that i can apply to make the light, shadows and surfaces look more
real?
This is based up on the fact, that all is looking a little bit plastic like,
equal if i add some finishes or not. Another thing is the sharpeness in
every depth, what a normal photo never is.
In other words: are there some very basic steps i can apply to my scene or
rendered picture that generally realisticalize it a little bit more??
Subject: Re: Is there a function...
Date: 9 Jul 2003 10:09:47
Message: <3f0c222b$1@news.povray.org>
1. Nope. Not a simple object.
You could try and construct your object with Christoph Hormanns
isoCSG, and try to blob the edges away a little, I've never done so
and don't have any experience with it, so I'm not even sure if
it'll work. But that's the only idea I can come up with, aside of modelling
with some other program than POV-Ray.
2. Light, shadows and surfaces
Well, for the light & shadows, use area_lights, fade_power, radiosity
and photons, and you've covered pretty much every realistic
effect possible (though nothing that resembles effects occuring with
different wavelengths, like bending around corners and such...).
For the sharpness of the image, look at focal blur, which covers
you're photographic "everything sharp" problem.
For surfaces, well, you've got to learn all tids and bits about finish,
normals and textures, but mostly probably about normals and
finishes, like reflections, brilliance, specular highlighting, fresnel
etc...
Tim Nikias v2.0
> realistic?
theoretically
> real?
like,
Version: 6.0.495 / Virus Database: 294 - Release Date: 30.06.2003
Date: 9 Jul 2003 11:53:29
Message: <3f0c3a79$1@news.povray.org>
Tim is right.  But once you add all of those features into your scene, don't
be surprised if render time goes from a few minutes to several hours or even
days.
Also, in regards to using the isoCSG library, I've used it quite a bit.  It
takes some getting used to doing everything in functions, but you can really
get some realistic effects with your objects that are just not possible in
any other way that I know of.  Isosurfaces are just plain better.  I wish
everything was an isosurface...
Slash
Date: 9 Jul 2003 12:51:59
Message: <cjameshuff-DC72B9.11490409072003@netplex.aussie.org>
In article <3f0c03f8@news.povray.org>,
> realistic?
No there isn't. But there are macros in shapes.inc for making rounded
versions of some common shapes...boxes, cylinders, cones.
> real?
    There are many separate features that combine for this. The first
thing you mention seems to be about surface imperfections...a flat
surface in POV appears perfectly flat, unlike most real-world surfaces.
You can use the normal feature to make them appear uneven or bumpy.
    Also, you need to use realistic lighting. Don't be afraid of using
light values greater than 1. Try designing your scene with an ambient of
0 for all non-glowing objects. The easiest way to do this is to put
"#default {finish {ambient 0 diffuse 1}}" at the beginning of your
scene. This improves contrast and the 3D look of your scene. A fill
light at the camera location can still provide illumination into
shadows, without the flatness of ambient lighting. Try radiosity as
well...radiosity simulates indirect lighting by light diffusely
reflecting off of nearby objects, like the glow from a sunlit spot in a
dark room. If you have highly reflective or transparent objects, photon
mapping can be a good idea. Photon mapping simulates specular
(mirror-like) reflective and refractive caustics, like light shining
through a colored glass. This can make a scene appear much more
realistic with little effort.
    Other things depend on your scene. An outdoor scene with far objects
will often show atmospheric haze. The fog feature is usually best for
this. For dense fog, scattering media may be better, as it will show
light beams and shadows that pass through it. As for the sharpness,
there is a focal blur feature.
http://tag.povray.org/
Date: 10 Jul 2003 04:59:21
Message: <3f0d2ae9$1@news.povray.org>
"Florian Rustedt" <flo### [at] rustedtde> wrote in message
news:3f0c03f8@news.povray.org...
> realistic?
Take a look at "superellipsoid" (6.5.1.11) for rounded boxes and cylinders (a
much under-used primitive imho).
Date: 10 Jul 2003 12:15:18
Message: <cjameshuff-DCCF96.11121210072003@netplex.aussie.org>
In article <3f0d2ae9$1@news.povray.org>,
    Two problems: 1) you can't specify a radius for the rounding, 2)
this is because it doesn't have one. The superellipsoid is incapable of
making a rounded cone or box, though it will make shapes that closely
resemble them. The round never transitions into a flat cylinder or box
edge...sometimes useful, but often undesired.
    Precise CSG with a superellipsoid is difficult, and CSG of
cylinders, spheres, toruses, and boxes is also more flexible. With a
superellipsoid, you always get rounded pseudo-cubes and cylinders with a
length of 2 units and a radius of 1. Uneven scaling gives you uneven
rounding, and positioning is inconvenient.
Date: 10 Jul 2003 17:05:35
Message: <3f0dd51f$1@news.povray.org>
Hi Florian,
I've written an includefile for creation of rounded objects. It is not
an automatic "rounder" of arbitrary objects and it can not create all
rounded shapes, but I can't live without it.
Basically, you can take the volume between two parallel planes, make
a closed cut (perpendicular to these planes) along straight lines and
circular segments, then round the corners lying in the planes.
Example picture:
   povray.binaries.images, 23rd and 26th January 2003
   "Round/bevel: include file demo [51 KB JPG]"
Include file and "slide show" demo:
   povray.binaries.scene-files, 23rd January
   "Round/bevel: Include file"
Tutorial:
   same thread, 26th January
   "Round/bevel: Mini-Tutorial; Test-Arena"
The include file has an additional short german introduction and comments.
   Sputnik
fr### [at] computermuseumfh-kielde
