POV-Ray : Newsgroups : povray.newusers : image maps with vectorial graphics, not bitmaps? Server Time
18 Sep 2025 18:34:12 EDT (-0400)
  image maps with vectorial graphics, not bitmaps? (Message 1 to 4 of 4)
Subject: image maps with vectorial graphics, not bitmaps?
Date: 22 Apr 2003 08:20:44
Message: <3ea5339c$1@news.povray.org>
I would like to use an image as texture for an object, but not a typical
BMP. Is it possible to use something vectorial, like postcript, or EPS?
Thanks in advance.
Subject: Re: image maps with vectorial graphics, not bitmaps?
Date: 22 Apr 2003 08:25:20
Message: <sucaavcoebsf4h9gh7ha2uggt4d1jfcbvf@4ax.com>
On Tue, 22 Apr 2003 14:16:33 +0200, "Miguel Garcia" <mig### [at] telefonicanet>
You can convert vector graphic to syntax understable in POV (polygon, spline,
prism, heighfield) and then use pattern based on this object.
ABX
Date: 22 Apr 2003 09:33:24
Message: <3ea544a4$1@news.povray.org>
spline,
Ok, but using a (planar) object as pattern for another object is exactly
what I don't know how to do. I wanted to generate a PS just to avoid this
problem! How can it be done??
Thanks!
Date: 22 Apr 2003 09:41:40
Message: <m6haav0scts5cej8eivpl29c9nr2nj161e@4ax.com>
To convert eps to pov as prism{} object you can use tool mentioned at
http://news.povray.org/povray.binaries.utilities/30771/ . I have no windows
version of it but iirc there is solution for windows users mentioned.
To make prism{} as base of pigment you have to read chapter "6.7.11.23
Object-pattern" in manual.
ABX
