POV-Ray : Newsgroups : povray.newusers : I don't understand how media scales Server Time
18 Jun 2026 07:27:19 EDT (-0400)
  I don't understand how media scales (Message 1 to 8 of 8)
Subject: I don't understand how media scales
Date: 4 Apr 2003 21:34:37
Message: <3e8e40bd$1@news.povray.org>
//--- povray 3.5 SD file-------------
// the variable casey switches the scene between two scenarios:
// casey=0:  a unit radius sphere seen through tiny camera angle;
// casey=1;  a "big" sphere seen through a normal camera angle;
#declare casey=0;
//declare casey=1;
#declare sun_radius=array[2]{1,15000};
#declare camera_angle=array[2]{.0009,45};
#declare sun_position= <-0.25, 0.10, 0.83>*150000;
background{rgb 0}
sphere{0, sun_radius[casey]
pigment{rgbft 1}
hollow
interior{
        media{
                emission 0.75
                scattering {1, 0.5}
                density { spherical
                        color_map {
                                [0.0 rgb <0,0,0.5>]
                                [0.5 rgb <0.8, 0.8, 0.4>]
                                [1.0 rgb <1,1,1>]
                //scale 0.5*sun_radius[casey]
translate sun_position}
   location  <0, 10,-50>
   look_at   sun_position
   angle    camera_angle[casey]
Subject: Re: I don't understand how media scales
Date: 5 Apr 2003 02:43:15
Message: <Xns9354634F4A788seed7@povray.org>
in news:3e8e40bd$1@news.povray.org Greg M. Johnson wrote:
Does this help? "6.6.3  Scaling objects with an interior."
Ingo
Date: 5 Apr 2003 16:12:08
Message: <3e8f46a8$1@news.povray.org>
Yes it does.
Now say I want to make it look like "flames" on the surface of a sun, but
still have a basically round surface.  When I do turbulence, it squashes it
completely.  What feature ought I try?
Date: 5 Apr 2003 17:39:21
Message: <3e8f5b19@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:3e8f46a8$1@news.povray.org...
it
density_map
You pretty much have to create different density patterns and combine them
in the final density used for the media. That way you have at least one
pattern for the flaming surface and another for the sphere, still using that
spherical pattern overall which you already had, of course. Just replace the
rgb's with predeclared densities having patterns too. Hopefully you get the
idea.
Date: 6 Apr 2003 06:44:46
Message: <3e90051e@news.povray.org>
> Yes it does.
Try warps:
sphere{0, 1
pigment{rgbft 1}
hollow
interior{
         media{
                 emission 0.75/5
                 density { spherical
             warp{black_hole 0,1 strength 1.3 falloff 2 inverse}
             scale 10 warp{turbulence 0.2} scale 1/10
             scale 20 warp{turbulence 0.3} scale 1/20
             scale 50 warp{turbulence 0.5} scale 1/50
             scale 100 warp{turbulence 0.9} scale 1/100
             warp{black_hole 0,1 strength 1.3 falloff 2}
                         color_map {
                                 [0.0 rgb <0,0,0>]
                 [0.1 rgb <0,0,0.3>]
                                 [1.0 rgb <1,1,1>]
             scale 0.5
scale 10}
    location  <0, 10,-50>/3
    look_at   <0,0,0>
    angle    45
Date: 6 Apr 2003 09:36:12
Message: <3e902d4c$1@news.povray.org>
That's a great effect, Simon. Something I hadn't seen done before. I ought
to try warps more often.
Date: 7 Apr 2003 08:33:24
Message: <3e917014$1@news.povray.org>
That is amazing. But why did you write, for example,
Isn't this really
warp{turbulence 0.2} scale 1/10     scale 20   // or scale 2 ?
warp{turbulence 0.3} scale 1/20    scale 50   // or scale 2.5?
instead of
"Simon Adameit" <sim### [at] gaussschule-bsde> wrote in message
news:3e90051e@news.povray.org...
> > Yes it does.
but
it
> Try warps:
> sphere{0, 1
> pigment{rgbft 1}
> hollow
> interior{
>          media{
>                  emission 0.75/5
>                  density { spherical
>                          color_map {
>                                  [0.0 rgb <0,0,0>]
>                  [0.1 rgb <0,0,0.3>]
>                                  [1.0 rgb <1,1,1>]
>              scale 0.5
> scale 10}
> camera {
>     look_at   <0,0,0>
>     angle    45
Date: 7 Apr 2003 12:02:13
Message: <3e91a105$1@news.povray.org>
I scale the object before applying turbulence and then rescale it to its
original size. This has the effect of scaling the turbulence and could
also be archieved with octaves but this way I am also able to scale non
linearly and to apply other transformations like rotating before
scaling. The black_hole warp is used stretch the turbulence spherical.
> Isn't this really
This would have an effect on the size of the object, while
scale x ... do something ... scale 1/x   has not and it would not scale
the turbulence.
