POV-Ray : Newsgroups : povray.newusers : text on a cylinder Server Time
29 Jun 2026 02:07:50 EDT (-0400)
  text on a cylinder (Message 11 to 20 of 20)
Subject: Re: text on a cylinder
Date: 3 Nov 2002 23:04:09
Message: <chrishuff-BE233B.22565603112002@netplex.aussie.org>
In article <3dc568ae$1@news.povray.org>,
> 1. create your cylinder
> 2. create a second cylinder with r=r1+0.0001
> 3. create your text on the right position
> 4. put your text and the cylinder from 2. together
>    with intersection{}
This is actually a very clumsy, limited, and unnecessarily slow way of
doing it. Just use the object pattern.
http://tag.povray.org/
Date: 3 Nov 2002 23:05:20
Message: <chrishuff-F89524.22580703112002@netplex.aussie.org>
In article <3dc57d2f@news.povray.org>,
 "J Tellings" <j_t### [at] hotmailcom> wrote:
> Thanks, but ive already got the solution from anyone else.
That "solution" was about as close to the "wrong way" to do it as you
can get. Use the object pattern, it was designed for this.
Date: 4 Nov 2002 10:14:50
Message: <3dc68eea$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
I can get flat text on a cylinder with object pattern, but I can't do it
with 3D-text. I am a beginner, and this is my first image, so can anyone
give more info please.
THanks!
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 4 Nov 2002 11:12:27
Message: <3dc69c6b$1@news.povray.org>
"J Tellings" <j_t### [at] hotmailcom> wrote in message
news:3dc68eea$1@news.povray.org...
> THanks!
You could try something like:
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -4.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#macro RotText(Letter, RotY)
  text {
    ttf
    "arial.ttf",
    Letter,
    2,
    0
    pigment{Yellow}
    scale 0.25
    translate z*-1.1
    rotate y*RotY
cylinder { <0, -1, 0>, <0, 1, 0>, 1 pigment{Red}}
intersection{
  union{
    RotText("A",40)
    RotText("B",30)
    RotText("C",20)
    RotText("D",10)
    RotText("E",0)
    RotText("F",-10)
    RotText("G",-20)
    RotText("H",-30)
    RotText("I",-40)
  cylinder{<0,-1,0>,<0,1,0>,1.05}
  pigment{Yellow}
The intersection is to give the front of the letters a curve to match the
cylinder. The main drawback of this approach is that the letters themselves
aren't curved. You would only really notice this problem if you were using
relatively large letters.
BTW - keep checking back, I'm sure this method is pretty crappy, but there's
nothing like someone posting a crap way of doing something to provoke some
decent suggestions ;)
Apart from anything else, the macro could be better, in that it should allow you
to input a whole string, rather than having to call it one time for each letter,
but at least this version is easily comprehensible (I hope).
Date: 4 Nov 2002 12:02:16
Message: <3dc6a818@news.povray.org>
> allow you to input a whole string, rather than having to call it one time
> for each letter, but at least this version is easily comprehensible (I
> hope).
Hmm, using the min_extent and max_extent functions and a little
trigonometry it should be possible to handle even variable-width fonts
automatically... Heh, I just noticed that it is actually already done and
is part of the POV 3.5 standard library - the Circle_Text macro in
shapes.inc. Only problem is that it rotates around the wrong axis, z
instead of y, but it should be possible to modify it relatively easily.
Date: 4 Nov 2002 14:13:53
Message: <chrishuff-8B6F7E.14052904112002@netplex.aussie.org>
In article <3dc68eea$1@news.povray.org>,
Ah, you want a circular text object...well, shapes.inc includes a
Circle_Text() macro, but it makes a circle in the plane of the text. It
shouldn't be hard to modify to wrap text in this way, though.
The text object is pretty limited though, you might want to just make
your own text from CSG or use a third party mesh editor.
Date: 4 Nov 2002 15:05:55
Message: <3dc6d323@news.povray.org>
> with 3D-text.
  Oh, I thought you just wanted to apply text to a cylinder (like if it
was an image map). I didn't understand that you really wanted 3D letters.
  In that case the only(?) way would be to rotate and translate individual
letters. This can be pretty much automatized, as can be seen in the
already-mentioned Circle_Text() macro. Looking at how this macro is
done should help you.
Date: 6 Nov 2002 11:24:13
Message: <3dc9422d@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3dc6d323@news.povray.org...
> letters.
As there are letters in the  IsoCSG Library, it would be possible to bend
the full text, including the letters, not just rotate and translate them.
That would be the "right way", but it is of course overkill to use
isosurfaces for the average 3D text on a cylinder.
Just an answer to the (?) :-).
Marc-Hendrik
Date: 7 Nov 2002 10:09:00
Message: <3dca820c@news.povray.org>
  Calculating the intersection of the (already rotated+translated) letters
and a cylinder will give a cylindrical surface to them, which should work
rather well inside a specific range (meaning that the angle between adjacent
letter should not be too high, or else the will be some kind of ugly
distortion, as this is not true bending, but just "carving" the outer
part of the letter to be round).
  Btw, is it more efficient to calculate the intersection of a cylinder
and the union of the letters, or making a union with the intersections of
individual letters with (identical) cylinders?
Date: 8 Nov 2002 05:41:49
Message: <355nsusbnau05mvq1hgttdgvs01nj0a51d@4ax.com>
The latter proves to be faster in 99% of the cases, since the
resulting bounding boxes are smaller. , The text object is in its own
right quite slow in CSG, so using single letters reduces the strain a
lot.
Peter Popov ICQ : 15002700
