POV-Ray : Newsgroups : povray.newusers : Shell-out to OS? Server Time
12 Jul 2026 15:36:54 EDT (-0400)
  Shell-out to OS? (Message 1 to 10 of 10)
Subject: Shell-out to OS?
Date: 15 Oct 2002 15:01:53
Message: <3dac6621$1@news.povray.org>
This should be simple...
I have an INI file I'm using for my scene, and I've added the following two
lines:
Pre_Scene_Command=foobar
Pre_Scene_Return=F
However, while the other settings in the INI file are read, nothing seems to
happen with these two lines.  My naive understanding is that POV-Ray should
attempt to shell to the OS with the command listed in Pre-Scene_Command, and
when the program is finished, continue.
However, I can run the above two lines, exactly as they appear, and I do not
seem to generate an error message (as I would expect, since I have no
program named 'foobar').  It also won't start an existing executable if I
supply the proper name, instead.
So my question is two-fold:
1) What silly mistake is preventing me from understanding the proper use of
these keywords.
2) What is the syntax to include in the INI file that allows an executable
to run prior to parsing my scene?
- How
Subject: Re: Shell-out to OS?
Date: 15 Oct 2002 15:58:03
Message: <3dac734b@news.povray.org>
"How Camp" <kro### [at] hotmailcom> wrote in message
news:3dac6621$1@news.povray.org...
> Pre_Scene_Return=F
to
of
> these keywords.
Check for paths. For example, you should be able to call up Windows
Notepad.exe but not a C:\Nowhere\Nopad.exe, so I think as long as there's a
valid path (and PATH variable is set) then it should work okay.
Been a long time since I used INI for that. To use DOS commands you have to
run the command-line interpreter, which might be either command.com or
cmd.com.
Pre_Scene_Return=F should signify to POV that if a shell-out program/action
fails that POV aborts also. You'd need to be sure that causes an error code
though or it wouldn't have an effect, I believe.
Date: 15 Oct 2002 16:05:00
Message: <3dac74ec$1@news.povray.org>
Sorry, I meant cmd.exe not cmd.com... anyway, that's the idea. You ought to
be able to run things either in DOS or Windows. I don't know about the other
OS platforms.
Date: 15 Oct 2002 16:12:00
Message: <3dac7690@news.povray.org>
"hughes, b." <omn### [at] charternet> wrote in message
news:3dac734b@news.povray.org...
a
Hmm.  So I tried the following INI setting (on win2k):
Pre_Scene_Command=c:\WINNT\system32\notepad.exe
I've also checked the I/O options to make sure that 'disable starting other
programs' is not checked.
Alas, notepad.exe is not started, as I would expect.
program/action
code
Really?  So, the output from the shell program must somehow generate the
proper error code for POV to understand?  The manual talks about returning a
non-zero codes, but not what they should be (other than POV generating 0, 1,
or 2 itself).
- How
Date: 17 Oct 2002 09:18:51
Message: <Xns92AA9B8C8870EPhiLho@204.213.191.226>
news:3dac7690@news.povray.org:
> other programs' is not checked.
I tried on WinNT4 the following line:
Pre_Scene_Command=D:\Programmes\USons\MicroWav.exe
D:\Programmes\USons\BELL.WAV
where MicroWav is a small program that play a wav file and exit.
I hear the sound before the scene rendering... So basically, it is working
fine, you should check your settings, etc.
OK, to be sure, I also tried:
Pre_Scene_Command=D:\Programmes\USons\Tom's MIDI Player.exe
D:\Programmes\USons\Addams Family.mid
where Tom's MIDI Player as a GUI. Same here, I didn't even had to put
quotes around the path which has spaces...
I have put the first command as Post_Scene_Command and the second one as
is, and it still works... Of course, you have to close the GUI before the
rendering goes.
> the proper error code for POV to understand?  The manual talks about
> returning a non-zero codes, but not what they should be (other than
> POV generating 0, 1, or 2 itself).
In Dos lingo, the error code is called errorlevel. That's a code returned
(return n in main() or exit(n) elsewhere, or Windows API equivalent:
ExitProcess(n)) by any well behaved program.
By tradition, or standards, 0 means OK, no problem, any other values mean
there is a problem, the value usually carrying some information, depending
on the program itself. No standard here.
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 17 Oct 2002 10:50:53
Message: <3daece4d@news.povray.org>
Have you checked that the security permissions permit executing
pre/post-scene commands?
Date: 17 Oct 2002 16:05:32
Message: <3daf180c$1@news.povray.org>
news:3daece4d@news.povray.org...
M()}}
Warp -
Er, yes.  As explained in my last post:
It doesn't seem to make a difference.
Date: 17 Oct 2002 16:21:27
Message: <3daf1bc7$1@news.povray.org>
"Philippe Lhoste" <Phi### [at] GMXnet> wrote in message
Hmm.  I must be doing something very silly.  I've tried this on a win2k
machine, and now on my win98 machine, neither of which seem to function.
Here's my exact .INI file:
[Shell Test]
Width=320
Height=240
Antialias=Off
 Pre_Scene_Command=c:\windows\notepad.exe
 Pre_Scene_Return=F
So, I select the .INI file (clicking on the INI button and 'set, but don't
render'), and render my scene.  The scene file consists of nothing more than
the basic scene template - and it immediately renders without attempting to
load notepad.exe.
At first, I figured I had forgotten to allow POV the proper permissions to
shell to an external program (just as Warp wondered).  I have 'no
restrictions' set in the 'options --> Script I/O Restrictions' menu, as well
as 'Permit read/write in current directory' checked.  The 'disable starting
other programs' is NOT checked.
...Are there other settings I may have overlooked?
> rendering goes.
And this is the behavior I had hoped for.  So, once I find my mistake, I'll
be a happy camper.  Sorry for the newbie trouble.
- How
Date: 18 Oct 2002 06:46:50
Message: <Xns92AB81C6AB144PhiLho@204.213.191.226>
news:3daf1bc7$1@news.povray.org:
> win2k machine, and now on my win98 machine, neither of which seem to
> function. Here's my exact .INI file:
> [Shell Test]
> Width=320
> Height=240
> Antialias=Off
>  Pre_Scene_Return=F
I see several problems (after trying out, I am not very familiar with
these .ini files, but I am familiar with debugging processes :-)
Let's see...
1) When I use your .ini file as given (just replacing Notepad call), I get
this error in the Messages pane:
Warning: Never found section '' in file 'E:\_PhiLho\Images\POV-
Ray\sources\LuaLogo.ini'.
Command Line Error: Problem with command line or INI file.
Returned from renderer with error status
So I removed the section [Shell Test] which obviously is not only
necessary, but seems to be interfering... POV-Ray's .ini files are not
exactly Windows' .ini files, as stated in the manual. See also example
.ini files in the scenes\portfolio directory.
2) After removing this section, I got another error. Snipped from the
Parsing Options
  Input file: OBJECT.POV (compatible to version 3.5)
POV-Ray is creating another process
  D:\Programmes\USons\MicroWav.exe D:\Programmes\USons\BELL.WAV
Possible Scene File Parser Initialization Error: Could not find file
'OBJECT.POV'
Scene File Parser Initialization Error: Cannot open input file.
Obviously, POV-Ray tries to render the default scene OBJECT.POV...
You must add a line like: Input_File_Name=<Your Scene>.pov
After adding it, I heard the sound... Well, almost, I cheated...
I disabled the Pre_Scene_Return=F line.
If I put it back, the program is no longer executed. ?!? A bug?
Oooh, if I put the Return line *before* the Command one, it works!
A quick browse of the manual shows nothing on this behavior...
Oh, well, at least you should be able to do what you wanted now :-)
Date: 21 Oct 2002 13:03:29
Message: <3db43361$1@news.povray.org>
> Let's see...
Hmm, I don't see any of these errors you're referring to.  I agree, the need
for [...] is not necessary, but sure makes life easier when you're doing
test renders at various qualities, etc.
Since this works in other INI files (without shelling), I don't think this
is the problem.
> messages:
This appears to be the problem.  I can use this INI file:
[TestIt]
Pre_Scene_Return=F
Pre_Scene_Command=notepad.exe
...But not this one:
[TestIt]
Pre_Scene_Return=F
Strange.  As you also pointed out, it doesn't appear in the docs anywhere.
But if you either leave out the Pre_Scene_Return line, or include it prior
to the Pre_Scene_Command line, things work fine.  You can even use the [...]
headers, too.
Finally, yes.  Thanks for the help!
- How
