POV-Ray : Newsgroups : povray.newusers : old version... Server Time
11 Apr 2026 05:28:18 EDT (-0400)
  old version... (Message 1 to 8 of 8)
Subject: old version...
Date: 1 Mar 2001 14:31:41
Message: <3a9ea39d$1@news.povray.org>
I want to translate this scene script. Someone can help me ?
Thanks.
#include "textures.inc"
    location < 0, 0, -8>
    look_at < 0, 0, 0>
light_source {
    < 6, 10, -4>
    color White
sphere {
    < 0, 1, 0>, 2
        color rgbt < 1, 1, 1, 1>
    halo {
        emitting
        spherical_mapping
        linear
        turbulence 1.5
        color_map {
            [ 0.0 color rgbt < 1, 0, 0, 1> ]
            [ 1.0 color rgbt < 1, 1, 0, -1> ]
        samples 20
    hollow
Subject: Re: old version...
Date: 1 Mar 2001 23:54:33
Message: <3a9f2789@news.povray.org>
To be blunt, it's not a straight changeover going from halo to media, it can
take a lot of adjustment and still might not be exactly reproduced.
The following might be about what you had before, I couldn't check since
this PC doesn't have POV-Ray 3.0 on it.  Looks about like what you might
have intended.
Bob H.
sphere {
    < 0, 1, 0>, 2
    interior {
     media {
        intervals 5 samples 10, 20
        emission <2,1,1> // color adjust here or use scattering {}
         density {
        spherical
        turbulence 1.5
           density_map {
            [ 0.0 rgb < 0.01, 0, 0> ] // less fades
            [ 1.0 rgb < 1, 1, 0> ] // more is denser
         } // density_map
         } // density
     } // media
     } // interior
    hollow
Date: 2 Mar 2001 05:18:05
Message: <3a9f735d@news.povray.org>
Thanks a lot !
3a9f2789@news.povray.org...
can
> have intended.
> Bob H.
> sphere {
>     < 0, 1, 0>, 2
>     pigment {
>     interior {
>      media {
>          density {
>         spherical
>         turbulence 1.5
>            density_map {
>          } // density_map
>          } // density
>      } // media
>      } // interior
>     hollow
Date: 5 Mar 2001 05:02:23
Message: <3aa3642f@news.povray.org>
If you are using MegaPov, add "method 3" into the media block. You'll
like it.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 10 Mar 2001 22:01:22
Message: <3aaaea82$1@news.povray.org>
Too bad there is no easy way to translate it.  There should at least be
rules of thumb, and guidelines like how to get a similar effect, what
parameters make it "tighter" or "fuzzier" etc.
--John
"Bob H." <omn### [at] msncom> wrote in message
news:3a9f2789@news.povray.org...
can
> have intended.
> Bob H.
> sphere {
>     < 0, 1, 0>, 2
>     pigment {
>     interior {
>      media {
>          density {
>         spherical
>         turbulence 1.5
>            density_map {
>          } // density_map
>          } // density
>      } // media
>      } // interior
>     hollow
Date: 10 Mar 2001 22:38:30
Message: <3aaaf336$1@news.povray.org>
"John M. Dlugosz" <joh### [at] dlugoszcom> wrote in message
news:3aaaea82$1@news.povray.org...
It basically amounts to using density and density_map as the pigment and
color_map replacement, except now it's just the rgb vector instead of the 4
or 5 rgbf or rgbft.  To get more transparency the density must be low, and
higher for more solid.
Bob H.
Date: 11 Mar 2001 14:12:18
Message: <3aabce12$1@news.povray.org>
4
You mean light colors in the map are more transparant, and dark colors more
opaque?
In the translation from
         halo {
            emitting
            spherical_mapping
            linear
            color_map {
              [ 0.0 color rgbt <1, 1, 0, .999999> ]
              [ 0.5 color rgbt <1, 1, 0, 0.5> ]
              [ 0.8 color rgbt <1, 1, 1, 0> ]
              [ 1.0 color rgbt <1, 1, 1, 0> ]
to
            media {
               emission <1,1,0>
               density {
                  spherical
                  density_map {
                     [0 rgb<1,1,0>*0*D]
                     [.5 rgb<1,1,0>*.5*D]
                     [.8 rgb<1,1,1>*D]
                     [1 rgb<1,1,1>*D]
the result was both too opaque =and= too light in color.
--John
Date: 11 Mar 2001 15:12:02
Message: <3aabdc12@news.povray.org>
news:3aabce12$1@news.povray.org...
more
> opaque?
No, just the opposite.  What it's really saying is that <0,0,0> has no
density at all, equivalent to rgbf <1,1,1,1> in a halo.  And so rgb 1 is
actually a unit of media density, or saturation, although any real number
can be used.
The main difference being that filtered or transmitted color is null and
void when tried in media.
I looked at your scene again and found that the ior and caustics when used
the 3.1 way, in a interior statement, all is fine with the glass and shadow.
#declare Glass =
material {
    pigment { color rgbf <0.98, 0.98, 0.98, 0.9> }
 finish  {
    ambient 0.1
    diffuse 0.1
    reflection 0.1
    specular 0.8
    roughness 0.003
    phong 1
    phong_size 400
 interior {
    ior 1.45
    caustics 1.0
Then apply it as material {Glass} instead of only texture {Glass}.
I also tried adding absorption <0,0,1>*.25 in the media as well as lowering
both the emission and density D variable.  It's all a matter of tweaks, I
don't know of any straight conversion.
Oh, and to get rid of the faint artifact crossing left to right on the back
wall put the keyword sturm into your quartic.
Bob H.
