POV-Ray : Newsgroups : povray.newusers : MegaPov slope-dependent textures Server Time
11 Apr 2026 07:15:53 EDT (-0400)
  MegaPov slope-dependent textures (Message 1 to 7 of 7)
Subject: MegaPov slope-dependent textures
Date: 13 Jan 2001 06:55:28
Message: <3a604230@news.povray.org>
Hi!
I want to texture the part of an object that is  under an "overhang"
differently from the rest. I.e. I would like to use a slope y (or was
it -y?) and when it is negative, I want to give the part in -y-direction a
different pigment even if the slope is positive again.
Is it possible in MegaPov itself?
Hope I was clear enough ;-),
Marc-Hendrik
Subject: Re: MegaPov slope-dependent textures
Date: 13 Jan 2001 08:06:13
Message: <3A6052C4.57639B46@gmx.de>
Marc-Hendrik Bremer wrote:
> Hi!
Sounds tricky, if i understand it right it should look like an object
covered by a thin layer of snow (which would not reach the parts covered
by overhangs).
I posted a simple snowing macro some time ago, but it would be slow and
also modifies the geometry (you could use the object pattern to avoid
this)
If your object is an isosurface or another simple mathematical shape, you
could try to construct a function pattern for that, but it seems quite
difficult to me.
Anyway it would be quite possible to add this as a new internal pattern to
povray.
Date: 13 Jan 2001 08:55:15
Message: <3a605e43@news.povray.org>
Christoph Hormann schrieb in Nachricht <3A6052C4.57639B46@gmx.de>...
>by overhangs).
Hm yes, I thought the other way round, but that doesn't matter.
>this)
I've found the macro and remember the related image. But if there is another
sulotion, I would prefer not to use trace() for this problem. The Object i'm
thinking of is quite complicate and I would have to call trace more than
once for every "row". Seems quite slow to me (and I never used it before
>difficult to me.
Well, it's made out of some Isos, but I wouldn't want to try to make one
single function out of them.
>povray.
If there is no other easy way, that would be quite usefull IMHO.  If it
would be possible to specify a "delay" for the slope dependent texture that
would suffice, I think. There should be a way to specify what should be
delayed (positiv/nagative or no slope), too. But I'm no programmer (at least
not in C), so I'll have to wait and see ....
Thanks,
Marc-Hendrik
Date: 13 Jan 2001 09:29:03
Message: <3A60662D.FBDFCBE5@gmx.de>
I'm not sure what you mean by "delay".  The internal version i thought of
could just test, whether there is some part of the object 'above' a point
and select the right texture.
I don't know how your object is shaped, but if there is only 'one layer of
overhangs', you could use a translated object pattern to simulate it.
Date: 13 Jan 2001 10:38:24
Message: <3a607670@news.povray.org>
Christoph Hormann schrieb in Nachricht <3A60662D.FBDFCBE5@gmx.de>...
I thought in the directon that all neccessary (for my problem) info is given
with the slope - but not at the right place.
I'm working on a building and want to "age" it. But under the overhanging
roof and some beams it would be cleaner then further "down". If the Info of
the slope could be holded while the pattern "moves further down" (nothing is
moving - I know), then I could design the textures accordingly. "delay" was
probably not right.
But your suggestion is as good as mine, if one could freely determine where
"above" is.
It would be also great, if one could #declare the "slope-pigment" of one
object for use as a texture_map on another one .
In this case it is the above mentioned building. In wich way is the
information if one point is inside or outside an object usefull for this
case?
Marc-Hendrik
Date: 13 Jan 2001 14:00:14
Message: <chrishuff-CA96B4.14014213012001@news.povray.org>
In article <3a604230@news.povray.org>, "Marc-Hendrik Bremer"
I'm not sure what you mean..."when it is negative...", "...even if the
slope is positive again."
The slope is either negative or positive (actually, it goes from 0 to
1). Do you want a texture that covers the downward facing area as well
as part of the upward-facing area? That should be easy to do simply by
making your blend map partially solid. For example:
slope y
*_map {
    [0 Bottom]
    [0.5 Bottom]
    [0.6 Top]
    [1 Top]
Just remember that slope varies "between (and including) 0.0 and 1.0,
where 0.0 is most negative slope (surface normal points in negative
vector direction), 0.5 corresponds to a vertical slope (surface normal
and slope vector form 90 degree angle) and 1.0 is horizontal with
respect to the slope vector (surface normal parallel to slope vector)".
Christopher James Huff
Date: 13 Jan 2001 15:54:30
Message: <3A60C083.8318BB09@gmx.de>
> probably not right.
That makes it much clearer.
> case?
For example if the building has a flat roof of any shape, you can use the
object pattern in the height of the roof to determine whether something is
covered by the roof or not.
I posted a picture of some new pattern i made to p.b.i.  Combined with
regular slope pattern it could meet your purpose.
