POV-Ray : Newsgroups : povray.newusers : Which is he best way to model the sun? Server Time
10 Apr 2026 00:07:56 EDT (-0400)
  Which is he best way to model the sun? (Message 1 to 5 of 5)
Subject: Which is he best way to model the sun?
Date: 15 Dec 2003 16:03:12
Message: <3FDE20D9.1080200@earthlink.net>
The subject line says it all. Which is the best way to model the sun?
Ideally, I would like to be able to model the sun in the IR, visible, UV
and X-ray. Eventually, I would like to morph between these wavelengths
in an animation. Here is an example photo:
http://antwrp.gsfc.nasa.gov/apod/ap010419.html
I also noticed this orrery:
http://news.povray.org/povray.binaries.images/33847/
I checked the archives. Someone had previously asked for the source code
for the sun in the orrery but I couldn't find any follow up and do not
believe one was posted. (Unless I missed it.)
Any advice on the best approach? (For example, how would I do magnetic
field lines using media?)
Thanks in advance for all suggestions and warnings of what doesn't work
well.
Apollo16
Subject: Re: Which is he best way to model the sun?
Date: 16 Dec 2003 09:21:07
Message: <3fdf14d3$1@news.povray.org>
"Apollo16" <kki### [at] earthlinknet> wrote in message
news:3FD### [at] earthlinknet...
All pov images output UV and X-rays - this is why you have to confirm "I am not
a pregnant woman" before installing...
Seriously though, pov cannot model a 'sun' - i.e. you can't construct an object
using atomic physics - all you can do is create something that looks like a sun.
So, ignoring the stuff about animating the scene, and also the stuff about
magnetic field lines for a later date....
Sun surface - well you could use media, but essentially the visible surface can
be rendered as a texture
Sun corona - for this you will want to use media.
Try playing around with something like this:
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.0, -3.0>
  look_at   <0.0, 0.0,  0.0>
#declare SPig1_1 =
pigment{
  granite scale 1/8
  pigment_map{
    [0.0 rgb<164/255,20/255,0/255>]
    [0.3 rgb<150/255,10/255,0/255>]
    [0.8 rgb<150/255,10/255,0/255>]
    [1.0 rgb<164/255,20/255,0/255>]
#declare SPig1_2 =
pigment{
  granite scale 1/8
  pigment_map{
    [0.0 rgb<194/255,50/255,0/255>]
    [0.4 rgb<241/255,86/255,4/255>]
    [0.7 rgb<255/255,155/255,37/255>]
    [1.0 rgb<194/255,50/255,0/255>]
#declare SPig1_3 =
pigment{
  granite scale 1/8
  pigment_map{
    [0.0 rgb<241/255,86/255,4/255>]
    [0.5 rgb<255/255,155/255,37/255>]
    [1.0 rgb<241/255,86/255,4/255>]
#declare SPig1 =
pigment{
  granite scale 1
  pigment_map{
    [0.2 SPig1_1]
    [0.5 SPig1_2]
    [0.7 SPig1_3]
    [0.8 rgb<255/255,244/255,230/255>]
#declare STex1 =
texture{
  pigment{
    SPig1
  finish{ambient 1}
// sun surface object
sphere{
  0, 1
  texture{
    STex1
#declare SInt1 =
interior{
  media{
    method 3
    emission rgb<1.00,0.1,0.0>*5
    density{spherical scale 1.25 turbulence 0.1}
    density{agate scale 0.25 color_map{[0.8 rgb 0][0.9 rgb 1]}}
  media{
    method 3
    emission rgb<1.00,0.1,0.0>*1
    density{spherical scale 1.15 turbulence 0.0}
// corona object
sphere{
  0,1.5
  hollow
  pigment{rgbf 1}
  interior{SInt1}
Date: 16 Dec 2003 11:53:17
Message: <3FDF37C4.9090502@earthlink.net>
Sorry... I should have used the word render... I am not really modeling
the sun in the astrophysical sense of the word. (That was part of my
thesis and I am finished with that my friend... I am finished with it!)
What I am looking to do is "render" the sun so that I can use this as a
demo in my undergraduate courses.
Thus... what you have started me off with is great! Just what I wanted.
Your version needs a shave but... Now that you have given me a great
start, I should be able to whip a good example together in no time!
Thanks again!
Apollo16
P.S. When I render the sun, I'll be sure to wear a sunscreen with an spf
of 5000!
Date: 16 Dec 2003 12:01:22
Message: <3fdf3a62$1@news.povray.org>
No worries - repost a request when you're ready to animate it....
Date: 25 Jan 2004 23:53:43
Message: <40149d57@news.povray.org>
I know this isn't specifically what he's asking, yet I thought I'd share my
little Sun1 Macro:
// a is angle across the sky.
#macro sun (a)
 light_source
  <0, 0, 1000>
  color rgb <1, 1, 0.97>
  parallel
  area_light
  <40, 0, 0> <0, 0, 40>
  4, 4
  adaptive 0
  jitter
  circular
  orient
  looks_like
   union
    sphere
     <0, 0, 0>, 1
     hollow
     pigment { color rgbft <1, 1, 1, 1, 0> }
     interior
      media
       emission 0.05
       density
        spherical
        poly_wave
        density_map
         [ 0  rgbt <0, 0, 0, 0> ]
         [ 30 rgbt <1, 1, 1, 0> ]
         [ 60  rgbt <1, 1, 1, 0> ]
     scale <200, 200, 200>
  rotate -a*x
