POV-Ray : Newsgroups : povray.newusers : Making a light source in a building... Server Time
11 Apr 2026 10:53:43 EDT (-0400)
  Making a light source in a building... (Message 1 to 6 of 6)
Subject: Making a light source in a building...
Date: 10 Jul 2000 02:45:47
Message: <39696E4E.6971BF0C@aol.com>
Lets say I have a box that has a smaller box cut out of it, I.E. a room.
The room also has a window. But when I put a light in the room, it does
not show through the window. But it does seem to go through walls. What
is wrong? Could some one post some code for me to paste in?
"Yub-Yub!" Lt. Kettch
Subject: Re: Making a light source in a building...
Date: 10 Jul 2000 12:06:21
Message: <3969f47d@news.povray.org>
Here ya go Lt.  The code could be better documented but you should be able
to follow it.  Its a garage  with a light upstairs and one downstairs.
Hope this helps
Wil Hale
SAIC
wil### [at] cal-businesscom
Lt. Kettch <AKK### [at] aolcom> wrote in message
news:39696E4E.6971BF0C@aol.com...
Date: 10 Jul 2000 12:07:54
Message: <3969f4da@news.povray.org>
It helps if I include the code...Sorry
Wil Hale
SAIC
#version 3.1
file://scale  1 unit = 1 foot
global_settings
  assumed_gamma 1.0
camera
  location  <-30.0, 16, -50.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 10.0,  0.0>
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source                                                   //  Upstairs
Light
  0*x // light's position (translated below)                   //
  color red 1.0  green 1.0  blue 1.0  // light's color         //
  translate <-0, 15, -0>
plane { y, -0 pigment {color rgb <0.7,0.5,0.3>}}
file://Floor
// create a box that extends between the 2 specified points
box
  <-12, -0.2, -12>  // one corner position <X1 Y1 Z1>
  < 12,  0.2,  12>  // other corner position <X2 Y2 Z2>
pigment { rgb <0,1,0>}}
file://left wall
difference{
box
  <-12, 0.2, -12>  // one corner position <X1 Y1 Z1>
  < -11.6,  10,  12>  // other corner position <X2 Y2 Z2>
texture{ pigment {rgb <1,1,0>}
// texture pigment {} attribute
// create a texture that lays an image's colors onto a surface
// image maps into X-Y plane from <0,0,0> to <1,1,0>
normal{
bumps 5 }scale 20
rotate y*90} // image_map
file://window
box
  <-12.2, 4, -3>  // one corner position <X1 Y1 Z1>
  < -11.2,  6,  0>  // other corner position <X2 Y2 Z2>
pigment { rgb <1,1,0>}}
box
  <-12.2, 4, 0.1>  // one corner position <X1 Y1 Z1>
  < -11.2,  6,  3>  // other corner position <X2 Y2 Z2>
box
  <-12.2, 6.1, -3>  // one corner position <X1 Y1 Z1>
  < -11.2,  8,  0>  // other corner position <X2 Y2 Z2>
box
  <-12.2, 6.1, 0.1>  // one corner position <X1 Y1 Z1>
  < -11.2,  8,  3>  // other corner position <X2 Y2 Z2>
file://right wall
box
  <12, 0.2, -12>  // one corner position <X1 Y1 Z1>
  < 11.6,  10,  12>  // other corner position <X2 Y2 Z2>
file://***************************back wall and doorways
difference{
box
  <-12, 0.2, 12>  // one corner position <X1 Y1 Z1>
  < 12,  10, 11.6>  // other corner position <X2 Y2 Z2>
file://back door doorway
box
  <-10, 0.1, 12.2>  // one corner position <X1 Y1 Z1>
  < -7,  8, 11.2>  // other corner position <X2 Y2 Z2>
pigment { rgb <1,1,0>}}  }
file://****************************Front wall and doorways
file://front wall
difference{
box
  < 12,  10, -11.6>  // other corner position <X2 Y2 Z2>
file://left doorway
box
  <-10, 0.1, -12.2>  // one corner position <X1 Y1 Z1>
  < -2,  8, -11.2>  // other corner position <X2 Y2 Z2>
file://right doorway
box
  <10, 0.1, -12.2>  // one corner position <X1 Y1 Z1>
  < 2,  8, -11.2>  // other corner position <X2 Y2 Z2>
file://**************************************************end front wall
file://Ceiling
box
  <-12, 9.8, -12>  // one corner position <X1 Y1 Z1>
  < 12,  10.2,  12>  // other corner position <X2 Y2 Z2>
// create a regular point light source                                //
Downstairs Light
light_source                                                          //
  translate <-0, 9, -0>
file://******************************************************************sec
ond story
file://left wall
difference{
box
  <-12, 10.2, -12>  // one corner position <X1 Y1 Z1>
  < -11.6,  18,  12>  // other corner position <X2 Y2 Z2>
box
  <-122, 12, -9>  // one corner position <X1 Y1 Z1>
  < -11.4,  16,  9>  // other corner position <X2 Y2 Z2>
pigment { rgb <1,1,0>}}}
file://right wall
box
  <12, 10.2, -12>  // one corner position <X1 Y1 Z1>
  < 11.6,  18,  12>  // other corner position <X2 Y2 Z2>
file://back wall
box
  <-12, 10.2, 12>  // one corner position <X1 Y1 Z1>
  < 12,  18, 11.6>  // other corner position <X2 Y2 Z2>
file://front wall
difference{
box
  < 12,  18, -11.6>  // other corner position <X2 Y2 Z2>
box
  <-8, 12, -12.2>  // one corner position <X1 Y1 Z1>
  < 8,  16, -11.4>  // other corner position <X2 Y2 Z2>
file://************************************roof
difference{
box
  <-9, -9, -12>  // one corner position <X1 Y1 Z1>
  < 9,  9, 12>  // other corner position <X2 Y2 Z2>
file://rotate x*90
rotate z*45}
box
  <-14, -14, -12.2>  // one corner position <X1 Y1 Z1>
  < 14,  14, 12.2>  // other corner position <X2 Y2 Z2>
translate -y*14}
box
  <-8.8, -8.8, -12>  // one corner position <X1 Y1 Z1>
  < 8.8,  8.8, 12>  // other corner position <X2 Y2 Z2>
file://rotate x*90
rotate z*45}
file://skylight
box
  <-18.8, 5, -1>  // one corner position <X1 Y1 Z1>
  < 18.8,  9.5, 1>  // other corner position <X2 Y2 Z2>
translate y*18}
Date: 10 Jul 2000 17:02:33
Message: <396a39e9@news.povray.org>
Lt. Kettch <AKK### [at] aolcom> wrote:
: Lets say I have a box that has a smaller box cut out of it, I.E. a room.
: The room also has a window. But when I put a light in the room, it does
: not show through the window. But it does seem to go through walls.
  Sorry, I don't understand what you mean.
Date: 10 Jul 2000 17:59:01
Message: <slrn8mk3qc.va6.steve@zero-pps.localdomain>
You could try a media container the same size as the box that you used to
take the middle out of the room, or you could use a high ambient/diffuse value
on the window material.  I used ambient and diffuse on my trafficlights macro
to get that type of effect.  something like:
 object{GlassInWindow
             pigment{rgbf <1,0,0,0.85>}
             finish{ambient 5
                    diffuse 5
                    phong 0.8
                    reflection 0.2
                    specular 0.01
                    roughness 0.001
Not sure of the exact values I used, just play around with the diffuse and
ambient values.
  6:51pm  up 11 days, 18:32,  2 users,  load average: 1.15, 1.05, 1.01
Date: 11 Jul 2000 05:35:49
Message: <396AE695.3A0F77DD@aol.com>
I don't quite get it. Where is the light source? That's what I'm really
looking for. And thanks for trying to help... doing this for fan art of an
online comic...
> Hope this helps
> Wil Hale
> SAIC
