POV-Ray : Newsgroups : povray.newusers : How to make heat flickering? Server Time
20 Sep 2025 11:27:41 EDT (-0400)
  How to make heat flickering? (Message 1 to 4 of 4)
Subject: How to make heat flickering?
Date: 5 Jul 2000 08:27:33
Message: <396329b5@news.povray.org>
Hi again,
is it possible to make or fake some heat flickering in pov? I think in real
life the flickering happens because of different IORs of the 'surfaces'
between air at different temperatures - that is probably not possible in
pov, is it?
So, how to fake this? I tried already a normal on an object with filter 1,
but nothing appeared ...
Thanks,
Marc-Hendrik
Subject: Re: How to make heat flickering?
Date: 5 Jul 2000 09:30:12
Message: <chrishuff-E56F5B.08302505072000@news.povray.org>
In article <396329b5@news.povray.org>, "Marc-Hendrik Bremer"
> in real life the flickering happens because of different IORs of the
> 'surfaces' between air at different temperatures - that is probably
> not possible in pov, is it?
No, it isn't. And although it isn't impossible to do, getting it to work
in POV would probably be difficult.
> filter 1, but nothing appeared ...
Did you remember to give the object an ior in the interior statement?
You are on the right track, some people have simulated the "mirage"
effect with multiple layers of objects with different ior's, a single
object with a normal should be sufficient for many situations.
Date: 6 Jul 2000 09:25:03
Message: <396488af$1@news.povray.org>
Thanks Chris!
Chris Huff schrieb in Nachricht ...
No, I didn't. now I get good effects, but ist is quite difficult to tweak
them to look convincing or at least somewhat good. Lot's of try and error.
I use now a disc for this purpose, because my previous cone reflected parts
of the scene at the edges - thta's the effect you get when you look over a
hot street, isn't it? But the disc works well, even if it is not as flexible
and it has to be oriented to the camera. Doesn't matter since I don't plan
to make a animation anyway.
Marc-Hendrik
Date: 7 Jul 2000 22:29:20
Message: <B58BDFEE.13C5%davidmccabe@mac.com>
Hmm...if the heat is in you whole scene file (not just one place), you could
put a normal in the camera.
                               David McCabe
                          dav### [at] maccom
> From: "Marc-Hendrik Bremer" <Mar### [at] t-onlinede>
> Newsgroups: povray.newusers
> Date: Thu, 6 Jul 2000 15:23:36 +0200
> Thanks Chris!
> Marc-Hendrik
