POV-Ray : Newsgroups : povray.newusers : some special kind of glass (sorry, I don't know the english word for it...ground glass?); Server Time
16 Mar 2026 12:08:32 EDT (-0400)
  some special kind of glass (sorry, I don't know the english word for it...ground glass?); (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: some special kind of glass (sorry, I don't know the english word for it...ground glass?);
Date: 25 Apr 2000 19:42:56
Message: <chrishuff_99-16FADB.18455525042000@news.povray.org>
In article <39062a35@news.povray.org>, "Bob Hughes"
<per### [at] aolcom?subject=PoV-News:> wrote:
> Using a low enough filter value along with a little transmit can do
> okay along with the normal (I almost always use granite for that) so
> long as the pigment color is white enough.  Can even go over rgb 1 as
> in rgbft <1.5,1.5,1.5,0.25,0.125> for example. Then of course for the
> normal to do it's stuff you need a ior and specular highlight. You'll
> certainly find that things will change dramatically when the camera
> and/or light are moved. So it can often be a case of adjusting for
> one viewpoint.
I did this a while ago, I posted some images to povray.binaries.images.
While I used a blurred transparency patch, the same thing could be done
with finely scaled normals.
I used a white pigment with about half transparency, ambient 0, some
reflection, and a diffuse value which added up with reflection to equal
1.(I usually try to design my textures so diffuse+ambient+reflection <=
1) I also added double_illuminate, so the glass is lit on both sides.(of
course, the last one requires MegaPOV)
Media should also work, I don't see why it would be "prone to failure".
It could be hard to adjust though...and probably slower than any other
option(unless you use MegaPOV and media method 2 or 3).
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Date: 25 Apr 2000 19:50:55
Message: <39062EF7.1EFF9133@pacbell.net>
Using media densities is really not that slow in the official version.
It's when you use scattering media that things slow way down.
Date: 25 Apr 2000 20:13:08
Message: <chrishuff_99-952867.19160725042000@news.povray.org>
In article <39062EF7.1EFF9133@pacbell.net>, lin### [at] povrayorg
You would have to use scattering media to get ground or frosted glass to
work right. Emitting media might fake it under some special conditions,
but it would be limited, and I think absorbing media would be useless
for this.
Date: 25 Apr 2000 21:59:10
Message: <39063FAD.E35A80DC@peak.edu.ee>
You can get the effect with scattering media in the lamp shade. It does require
a bit of tweaking, though. The render time will be somewhat high if you desire
smooth results. Alternatively you might want to try using MegaPOV, which has a
different method for rendering media. It will give smooth results at lower
settings and thus render faster.
I'll post an example scene to povray.binaries.scene-files; perhaps you can use
it as a basis.
Margus Ramst
Date: 26 Apr 2000 08:07:03
Message: <3906dbe7@news.povray.org>
erm... and what does this mean? Could you show me some scene-code?
Ron Parker <ron### [at] povrayorg> schrieb in im Newsbeitrag:
slr### [at] linuxparkerrfwicom...
> On Tue, 25 Apr 2000 21:30:49 +0200, Wolfgang Illmeyer wrote:
> >I'd like to produce some kind of street lamp, but it has some special
kind
> >of glass (somebody said 'ground glass', but I'm still not sure, if it's
the
> >right name), I can't produce...
> 'round here, we call that frosted glass.  It's not that easy to get right
> in POV, but you can fake it with either media (tricky, and prone to
failure)
> or a very small normal pattern with heavy nonadaptive antialiasing.  Your
> render times will go through the roof, though.
> Ron Parker   http://www2.fwi.com/~parkerr/traces.html
> These are my opinions.  I do NOT speak for the POV-Team.
Date: 26 Apr 2000 08:43:26
Message: <3906e46e@news.povray.org>
Chris Huff <chr### [at] yahoocom> schrieb in im Newsbeitrag:
chrishuff_99-16FADB.18455525042000@news.povray.org...
I'm sorry, I can't find this, because my newsreader-program crashes after
about 3000 messages ;)
Date: 26 Apr 2000 11:46:18
Message: <39070f4a@news.povray.org>
Something like this perhaps might do okay.
box {-1,1 scale <4,3,.1>
  pigment { rgbft <1.5,1.5,1.5,.25,.125>}
   normal {granite .15 scale .005}
    finish {ambient .05 diffuse .5 specular .8 roughness .01 reflection .15}
  scale 2 // scale texture to suit object/scene size
  interior {ior 1.5 caustics 1}
sphere {<0,0,1.5>,1 pigment {color red 1}}
light_source { <-.5,1.25,-1.5> color rgb <1,.95,.9>
  location  <1,.75,-2>
  angle 65
  look_at   <0, 0, 0>
"Wolfgang Illmeyer" <wol### [at] gmxnet> wrote in message
news:3906dbe7@news.povray.org...
| kind
| the
| failure)
Date: 27 Apr 2000 00:48:15
Message: <3907c68f@news.povray.org>
Hmm... this is not exactly what I thought of... I wanted WHITE glass with a
smooth surface... You should not be able to look through it, so this sphere
should actually only appear as a shadow (if the light source is behind
it...) and never as a red circle....
Bob Hughes <per### [at] aolcom?subject=PoV-News:> schrieb in im
Newsbeitrag: 39070f4a@news.povray.org...
>  texture {
.15}
> camera {
>   location  <1,.75,-2>
>   angle 65
>   look_at   <0, 0, 0>
> Bob
Date: 27 Apr 2000 00:49:50
Message: <3907c6ee@news.povray.org>
Could you please show me some code?
Wolfgang
chrishuff_99-952867.19160725042000@news.povray.org...
> for this.
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> TAG Web page: http://tag.povray.org/
Date: 28 Apr 2000 22:49:03
Message: <390A4CB0.18F560DF@global2000.net>
I have posted images of modified versions of Bob's glass spheres in pbi.
Brendan Ryan
> Hi, people.
> I already posted this in povray.programming, but they told me to post it
> here
> I'd like to produce some kind of street lamp, but it has some special kind
> of glass (somebody said 'ground glass', but I'm still not sure, if it's the
> You should not be able to look through it, it should have a white color, and
> it should let the light through. And if there's light on the other side of
> the glass shining in the camera's direction, it should be visible on the
> glass....
> (This glass is used in these detective-films, for example; maybe you know
> these office-doors with the white glass and the black text on it....)
> Please help me
> Thanks in advance
> Wolfgang
