POV-Ray : Newsgroups : povray.newusers : image on sphere is reversed. Server Time
20 Sep 2025 18:36:51 EDT (-0400)
  image on sphere is reversed. (Message 1 to 10 of 11)
Subject: image on sphere is reversed.
Date: 25 Aug 1999 14:25:12
Message: <37C43548.91588E8E@accn.org>
Help! The image I wrapped around a sphere is reversed, like it is being
seen in a mirror. How do I unreverse it?
Subject: Re: image on sphere is reversed.
Date: 25 Aug 1999 14:34:56
Message: <37C43791.2E853723@accn.org>
Note: the image is in the correct orientation. It is stored as a BMP in
the OS2 subformat (the only subformat I could get to work.)
Date: 25 Aug 1999 14:35:22
Message: <37C43734.596672BD@pacbell.net>
Could you provide us with the sphere statement along with the image_map
portion of the code. It is hard to second guess without an example to
work with. We don't need the image or the rest of the scene but a little
goes a long ways.
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 25 Aug 1999 14:39:55
Message: <37C438BC.100EE10A@accn.org>
Here is the pertinent code:
#version 3
global_settings
{assumed_gamma 1.0
#default {texture {pigment { color Red } } };
camera
  location  <0.0, 1.5, -6.0>
  direction 1.5*z
  right     4/3*x
  look_at   <1.0, 0.0,  0.0>
//Earth
sphere
{<0,0,0> 1
  texture  { pigment
      image_map
        sys "earthmap.bmp" // supports gif, tga, png, sys (bmp)
        map_type 1    // 1=spherical mapping
        //interpolate 2 // smooth it
        once          // don't tile image, just one copy
      // transform it to unit-size (-1 to +1)
//        translate <0,180,0>
//        scale .7              // make it unit-sized
        rotate<0,180,180>      //rotate on Y axis over n frames
    finish {ambient 0.3}
    scale 1
Date: 25 Aug 1999 14:48:52
Message: <37c43a94@news.povray.org>
Change the "rotate <0,180,180>", it's turning the whole thing upside
down and around. Try 'rotate <0,180,0> instead to see. Also be careful
of using multiple vector values in a rotation rather than multiple
individual rotations. You can't control the order otherwise.
Chuck Roberts <rob### [at] accnorg> wrote in message
news:37C438BC.100EE10A@accn.org...
> #version 3
> global_settings
> {assumed_gamma 1.0
> camera
>   direction 1.5*z
>   right     4/3*x
> file://Earth
> sphere
> {<0,0,0> 1
>   texture  { pigment
>       image_map
>         file://interpolate 2 // smooth it
>         rotate<0,180,180>      file://rotate on Y axis over n frames
>     scale 1
Date: 25 Aug 1999 14:50:41
Message: <37c43b01@news.povray.org>
Oh, and never mind that 'once' keyword for spherical 'map_type 1',
doesn't do anything.
Bob Hughes <inv### [at] aolcom> wrote in message
news:37c43a94@news.povray.org...
careful
> Bob
> > #version 3
> > global_settings
> > {assumed_gamma 1.0
> > camera
> >   direction 1.5*z
> >   right     4/3*x
> > file://Earth
> > sphere
> > {<0,0,0> 1
> >   texture  { pigment
> >       image_map
frames
> >     scale 1
Date: 25 Aug 1999 15:19:51
Message: <37C44216.30839564@accn.org>
That doesn't work. No matter how I rotate it, the image is still
mirrored.
Date: 25 Aug 1999 16:26:12
Message: <37C4512E.CE47BBAC@pacbell.net>
> mirrored.
I just tried this with an earthmap that I have and it worked for me. If you
are having a problem with the image you are using maybe you should try reversing
it in a paint program ?
//Earth
sphere {<0,0,0> 1
     pigment  {
      image_map { sys "earthmap.bmp"  map_type 1 interpolate 2 }
                  translate -.5
                  rotate<0,180,0>
    scale 1
Ken Tyler
Date: 25 Aug 1999 16:33:29
Message: <37c45319@news.povray.org>
Works all right here. Just making the rotate <0,180,0> change (and
removing the semicolon from the default texture line)
I see the comment talking of "n frames" if you plan to animate this
use: rotate <0,180*clock,0>  instead.
Sorry you aren't getting the expected result there. I can't think of
anything else besides artificially turning it around.
news:37C44216.30839564@accn.org...
upside
careful
> mirrored.
Date: 26 Aug 1999 03:44:10
Message: <37c4f04a@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: I just tried this with an earthmap that I have and it worked for me. If you
: are having a problem with the image you are using maybe you should try reversing
: it in a paint program ?
  Perhaps it's easier to apply a scale <-1,1,1> to the pigment?
