POV-Ray : Newsgroups : povray.newusers : How can I distort a cube? Server Time
18 Sep 2025 22:52:10 EDT (-0400)
  How can I distort a cube? (Message 1 to 6 of 6)
Subject: How can I distort a cube?
Date: 6 Mar 2003 08:01:31
Message: <1frehcv.jpygmt1hkz557N%kaveh@delete_this.focalimage.com>
Suppose I have a perfect cube, which is then distorted. I can define the
distortion by giving the coordinates of the corners, the midpoints of
the edges, and the centers of the faces. How can I draw this new shape,
with smooth faces going through the points?
I have looked at mesh2, but there you have to define the control points.
I don't know the control points, but just the points the surfaces must
intersect.
Thanks in advance for any pointers.
Kaveh
Subject: Re: How can I distort a cube?
Date: 6 Mar 2003 08:27:32
Message: <3e674cc3@news.povray.org>
You could use bicubic patches with 1 or 4 patches per side (see section
3.4.5). If you use 4 of them you can easily fullfill the point
interpolation criterion but you have some freedom left in the control
points. If you use olny 1 per side it gets difficult to have the patch
interpolate the midpoints and center points.
But all the same bicubic patches might be the right thing to chose.
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 6 Mar 2003 08:42:33
Message: <pmje6vo4kc92to4n64qf5frg2k5lc4lklv@4ax.com>
On Thu, 6 Mar 2003 13:01:32 +0000, kav### [at] delete_thisfocalimagecom (Kaveh)
This can be done with bicubic patches as Micha Riser suggested. But there
are other soultions. For some distortions you can use isosurfaces. Just have
to define function of distortion. It is rather complicated and possible only
for "function expressable" deformations (is this acceptable term?). If you
can define your edges as splines you can use macro to fill area enclosed in
splines - take a look at MMMM macros by Ingo
http://members.home.nl/seedseven/
ABX
Date: 7 Mar 2003 10:41:46
Message: <1frgjef.ubpfxvybgt50N%kaveh@delete_this.focalimage.com>
Thanks Micha. Look like 4 patches is the right way to go. But a question
here:
- Seems I have to define all pionts, including control points, when the
shapes distort. What I want is to give the changes for the corner
points, which the patch must go through, and let the control points be
chosen automatically so as to create a smooth shape. Is this possible?
If not, how can I calculate those control points?
Kaveh
Date: 7 Mar 2003 20:21:56
Message: <3e6945b3@news.povray.org>
  There's a tutorial in the POV-Ray documentation about how to join
two patches together seamlessly. This happens by arranging the control
points in the right way (which can be done mathematically).
  You should be able to create the control points with a little work.
Date: 8 Mar 2003 04:39:22
Message: <1frhxf3.w8h514ep0hs5N%kaveh@delete_this.focalimage.com>
I just discovered "multispline.inc" on a tutorial page by Josh:
http://www.spiritone.com/~english/cyclopedia/patches.html
Seems to do exactly this, i.e. to find control points from corner
points. Going through it now. Thanks.
Kaveh
