POV-Ray : Newsgroups : povray.newusers : Wavelength to RGB converter? Server Time
18 Mar 2026 07:15:50 EDT (-0400)
  Wavelength to RGB converter? (Message 19 to 28 of 38)
Subject: Re: Wavelength to RGB converter?
Date: 4 Mar 2003 14:50:56
Message: <20030304205055.6fa081aa.jaimevives@ignorancia.org>
On Tue, 4 Mar 2003 17:55:53 +0000
kav### [at] delete_thisfocalimagecom (Kaveh) wrote:
> Well, I put aliases to these files in the include directory, so as to
> keep the files organized and separate. There was no error when reading
> the 'include' command, so it saw the file, but did not *really* read
> it, i.e. the declarations were not made. When I put in the files
> directly into 'include', it worked.
  Ah! I see.. That explains it all. POV reads the link file, and not
follows the link to the real files... hmmm... I've never used links
with POV: let me try.. It works fine here with the Linux version.
Perhaps a problem with your custom compile?
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 4 Mar 2003 18:47:32
Message: <cjameshuff-BED34A.18473304032003@netplex.aussie.org>
In article <3e64aa31$1@news.povray.org>,
 "Thorsten Froehlich" <tho### [at] trfde> wrote:
> What is more relevant what comes out in the end, not what some fuzzy CPU
> usage indicator suggests is going on.  As you know, there is no way to tell
> a "while(1) { }" from an actual computation...
Well, it is doing something, and I don't think it is looping. Renders
also finish faster. I haven't checked how much having the preview up
affects this, though. It certainly is possible that MegaPOV is really
wasting that extra CPU power and rendering faster for some other reason.
http://tag.povray.org/
Date: 4 Mar 2003 20:31:47
Message: <3e655383$1@news.povray.org>
Thorsten Froehlich's furious key-hammering produced this:
>> (hint: use MacMegaPOV...the
>> official 3.5 doesn't use all the CPU power in OS X)
> This isn't true.  This is only a rumor created by Chris Huff.
Right...that's why it's reproducable on my system (and yes, MacMegaPOV works
fine).  I haven't tried the 3.5.1 preview yet, so I can't say anything about
that.
Followups set to povray.macintosh.
/*^*/light_source{100*<-5,2,-5>2}#macro I(i,n)#while(strlen(i)>=n)#local A=asc(
substr(i,n,1));#local a=asc(substr(i,n+1,1));cylinder{<div(A,8)-12,mod(A,8)-4,4
><div(a,8)-12,mod(a,8)-4,4>,0.1pigment{rgb z}}#local n=n+2;#end#end I("ScUe[]"1
/*<*/)I("mkmtlttk"1)//@_$#!,:<"Thhis polysig brought to you by Ian Burgmyer :)"
Date: 4 Mar 2003 20:34:56
Message: <3e655440@news.povray.org>
Jaime Vives Piqueres's furious key-hammering produced this:
Aliases in Mac OS might be implemented differently than symbolic links in Linux
and Windows NT.  Maybe one of the Mac OS developers around here can answer
that... *nudges Chris and Thorsten* ;)
Date: 4 Mar 2003 21:11:05
Message: <cjameshuff-2FB581.21110704032003@netplex.aussie.org>
In article <3e655440@news.povray.org>,
> links in Linux and Windows NT.  Maybe one of the Mac OS developers
> around here can answer that... *nudges Chris and Thorsten* ;)
They are different, not quite like either symbolic or hard links. I
think they work this way: they contain a link to the actual file, so if
the file gets moved around, they stay attached to it. They also contain
the last location of the file, so if it gets deleted and replaced with
another, the alias points to the replacement. That way, aliases don't
break when files move around, and generally do what the user wants to do.
I don't know if/how POV handles them, though.
Date: 5 Mar 2003 03:36:34
Message: <3e65b712$1@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
Unlike in Windos, in Mac OS and Unix, links (or aliases) are completely
transparent for applications.  Thus there is no difference between them.  Of
course, links (or aliases) can break.  So it does make sense to check if
tehy are really valid.  A user can do so using the Finder.
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Mar 2003 07:26:53
Message: <1frbj3u.sqlop61bczl34N%kaveh@delete_this.focalimage.com>
Could be. I don't know enough about the workings. My Linux friends
compiled it so everything works (except this maybe). Now I understand.
It doesn't understand the Mac alias pointing to the real file.
Kaveh
Date: 5 Mar 2003 07:59:31
Message: <3e65f4b3$1@news.povray.org>
"Kaveh" <kav### [at] delete_thisfocalimagecom> wrote in message
news:1frbj3u.sqlop61bczl34N%kaveh@delete_this.focalimage.com...
I'm missing something - I thought Mac used Linux now? (or do they use some
proprietary method to handle alias's? Why?)
Date: 5 Mar 2003 09:09:02
Message: <20030305150859.655281b3.jaimevives@ignorancia.org>
On Wed, 5 Mar 2003 12:59:32 -0000
> some proprietary method to handle alias's? Why?)
  No, Apple uses now a Unix-based kernel (BSD). Linux is a Unix-like
system, wich is not exactly the same. I think they don't use clasic unix
links, but I'm still on my "first encounters" with Mac OS X, so I don't
know for sure.
Date: 5 Mar 2003 14:27:48
Message: <cjameshuff-DE9BE5.14274705032003@netplex.aussie.org>
In article <3e65f4b3$1@news.povray.org>,
No, OS X is based on BSD.
> (or do they use some proprietary method to handle alias's?
Not really...they are the only ones who handle aliases. They serve a
similar purpose to links, but are not links.
> Why?)
Because they work better. There are web pages out there that go into far
more detail on this than I could.
