POV-Ray : Newsgroups : povray.general : povray vs uberpov am3 Server Time
28 May 2024 14:08:04 EDT (-0400)
  povray vs uberpov am3 (Message 14 to 23 of 33)
Subject: Re: povray vs uberpov am3
Date: 18 Sep 2020 07:22:17
Message: <5f649869$1@news.povray.org>
On 9/18/20 6:36 AM, William F Pokorny wrote:
> I don't think we have a fat rabbit to chase here.
> Of course run time improvements with am3 would be welcome. I have on my
> list to do some profiling with parametrics. Might take a side look at
> am3 too while I've got those compiles about. I've got the color shift
> issue to replicate and run down someday too. Hmm, wonder if I can
> trigger it with your simpler test cast Ton.
We can indeed! All one needs do is change:
background { color srgb <0, 0, 0> }
to:
#declare Acajou = srgb <0.29804,0.18431,0.15294>;
background { color Acajou }
and the cpu time jumps.
16.918 -> 3443.029 ---> 20251.28%
Plus the results are to my eye not as good.
Does uberpov has the same behavior:
16.172 -> 3512.926 ---> 21622.27%
A fat rabbit.
Bill P.
Bill P.
Date: 18 Sep 2020 08:00:01
Message: <web.5f64a081aa461a8cd98418910@news.povray.org>
> to:
WOW! That's incredible. Excellent detective work, Bill.
Date: 18 Sep 2020 10:50:01
Message: <web.5f64c87aaa461a8cd98418910@news.povray.org>
"Ton" <ton### [at] gmailcom> wrote:
> My version of uberpov is from https://github.com/UberPOV/UberPOV, the last
> version, dated 10 February 2015.
OK. I downloaded the Windows 64-bit version of this-- I *think* it's the correct
'stand-alone' version-- dated one day earlier on the Github page: UberPOV
v1.37.1.0.beta10
> Povray 3.7 doesn't have the stochastic rendering mode am3, that's probably why
> your plugin on version 3.7.0 doesn't work...
Apparently you're correct; this earlier(!) version of UberPOV DOES recognize the
"+ac0.9" command. That seems strange to me; I would have thought that the
(later) piggyback version for 3.7.0 would also have that ability already
built-in to its binary, thus 'overriding' 3.7.0's limitation. Anyway, it does
work. Thanks.
[William wrote...}
> Hmm, wonder if I can trigger it with your simpler test cast Ton.
> to:
> and the cpu time jumps...
[snip]
In the Windows version of UberPOV beta 10 (the version I downloaded, as above),
the render times for Ton's scene are identical, with or without this
background/color change-- a quick 4 seconds at 800X600. But the visual results
indicate that AA is not working at all, or very minimally. And, as you mentioned
earlier, the render statistics say:
Antialiasing...on (Method 3, Threshold 0.100, Depth 6, Jitter 1.00, Gamma 2.50)
samples: 0   Smpls/Pxl: 0.00
[off-topic]
This UberPOV beta 10 'stand-alone'(?) installation was an interesting
experience. Unpacking it in 7-zip, it unzips as a 'application'. I thought this
would be an 'installer'-- but no, clicking on it launches UberPOV itself...with
scenes present that I had already opened in some other version of POV-ray. It
makes me wonder what assets this version is automatically using; maybe from
within my 3.7.0 folder(s)?
Another odd thing:
Running Ton's test scene the first time in this version, there was a fatal
error... in his camera declaration, of all places!
camera
   location <25, 8, 0>
   right <image_width / image_height, 0, 0>
   look_at <12, 0, 0>
The fatal error was at the 2nd line-- ""Expected numneric expression,  /  found
instead". Huh?!
So I changed that line to the more standard syntax,
..... but that triggered a *different* fatal error...
"No matching } in 'camera', * found instead". Huh?!
I finally got it to work by using
     right <1.3333,0,0>
Very strange...especially since my own more complex scenes run perfectly OK with
the 'problem' syntax. (Although, in my scenes, I never put the camera
declaration as the last item. Maybe that's the culprit?)
It's a good thing that I have a sense of humor; otherwise, these crazy errors
would drive me insane ;-)
Date: 18 Sep 2020 10:57:36
Message: <5f64cae0$1@news.povray.org>
>> my list to do some profiling with parametrics. Might take a side look
>> at am3 too while I've got those compiles about. I've got the color
>> shift issue to replicate and run down someday too. Hmm, wonder if I
> to:
> A fat rabbit.
> Bill P.
tried changing my am3 test file like above ... cannot duplicate issue
Date: 18 Sep 2020 11:11:35
Message: <5f64ce27$1@news.povray.org>
> v1.37.1.0.beta10
> work. Thanks.
> [William wrote...}
>> to:
> [snip]
> [off-topic]
> Another odd thing:
> camera
>     location <25, 8, 0>
>     look_at <12, 0, 0>
> instead". Huh?!
>       right <1.3333,0,0>
i've not followed uber for a bit now ... but in version povray
3.8.0-alpha.10064268 you don't even have to set the right vector
anymore: http://wiki.povray.org/content/Reference:Camera#Aspect_Ratio
... so i'm not sure where the uber you're using is at ... just a thought.
Date: 18 Sep 2020 14:25:00
Message: <web.5f64fadcaa461a8cd98418910@news.povray.org>
Thanks; I didn't know about that change.
All of the versions that I could find are here:
https://github.com/UberPOV/UberPOV/releases
Date: 18 Sep 2020 16:15:01
Message: <web.5f651473aa461a8c4d00143e0@news.povray.org>
hi,
> > to:
> > A fat rabbit.
> > Bill P.
fwiw, same here, also alpha.10064268.  in fact the coloured bg version is
faster,
edited transcript:
Script started on Fri 18 Sep 2020 20:58:43 BST
jr@crow:1:tmp$ c### [at] ngtonpov
#version 3.8;
global_settings {
    assumed_gamma 1
    noise_generator 2
#ifndef (global.N)
  #declare N = 0;
#if (N)
background {color srgb <.29804,.18431,.15294>}
#else
background {color srgb 0}
union {
    #for (I, -25, 25, 1)
        cylinder {
            <-20, 0, 0>, <20, 0, I>, 0.01
        color srgb<1, 1, 1>
light_source {
    <25, 8, 0>, rgb<1, 1, 1>
    location <25, 8, 0>
    look_at <12, 0, 0>
jr@crow:2:tmp$ pov38 ngton.pov +d +p +q9 +am3 +a0.1 +ac0.9 +r6
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10064268.unofficial
 (g++ 4.8.2 @ x86_64-slackware-linux-gnu)
Support libraries used by POV-Ray:
  ZLib 1.2.8, Copyright 1995-2012 Jean-loup Gailly and Mark Adler
  LibPNG 1.4.20, Copyright 1998-2012 Glenn Randers-Pehrson
  LibJPEG 8, Copyright 1991-2016 Thomas G. Lane, Guido Vollbeding
  LibTIFF 3.9.7, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
  Boost 1.54, http://www.boost.org/
  OpenEXR 1.7.1 and IlmBase 1.0.3, Copyright (c) 2002-2011 Industrial Light &
 Magic.
Dynamic optimizations:
  CPU detected: Intel,SSE2,AVX
  Noise generator: avx-intel (hand-optimized by Intel)
Parser Options
  Input file: ngton.pov
  Remove bounds........On
  Split unions.........Off
  Library paths:
    /home/jr/.local/povray/include
    /usr/local/share/povray-3.8/extra
    /usr/local/share/povray-3.8/include
    /usr/share/fonts/local
  Clock value:    0.000  (Animation off)
Image Output Options
  Image resolution.....960 by 720 (rows 1 to 720, columns 1 to 960).
  Output file..........ngton.png, 24 bpp PNG
  Dithering............Off
  Graphic display......On  (gamma: sRGB transfer function)
  Mosaic preview.......Off
  Continued trace......Off
Information Output Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
==== [Parsing...] ==========================================================
Parser Statistics
Finite Objects:           51
Infinite Objects:          0
Light Sources:             1
Total:                    52
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.001 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 3, Threshold 0.100, Depth 6, Jitter 1.00,
 Gamma 2.50)
==== [Rendering... Press p to pause, q to quit] ============================
Render Statistics
Image Resolution 960 x 720
Pixels:           691200   Samples:               0   Smpls/Pxl: 0.00
Rays:            5249224   Saved:                 0   Max Level: 1/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                123247827         1250084      1.01
Bounding Box                 187640060       147701275     78.72
Shadow Ray Tests:           1226634   Succeeded:                     0
Render Time:
  Photon Time:      No photons
  Radiosity Time:   No radiosity
  Trace Time:       0 hours  0 minutes 11 seconds (11.444 seconds)
              using 2 thread(s) with 22.876 CPU-seconds total
==== [Paused... Press p to resume] =========================================
Press p, q, enter or click the display to continue...
POV-Ray finished
jr@crow:3:tmp$ pov38 ngton.pov +d +p +q9 +am3 +a0.1 +ac0.9 +r6 declare=N=1
Render Statistics
Rays:            2283041   Saved:                 0   Max Level: 1/5
Cone/Cylinder                 51037867          472363      0.93
Bounding Box                  77941671        61111153     78.41
Shadow Ray Tests:            463586   Succeeded:                     0
Render Time:
  Trace Time:       0 hours  0 minutes  5 seconds (5.006 seconds)
              using 2 thread(s) with 9.995 CPU-seconds total
POV-Ray finished
'pov38' is a BASH alias for 'nice -n 19 povray'.
regards, jr.
Date: 18 Sep 2020 20:25:01
Message: <web.5f654f09aa461a8c4d00143e0@news.povray.org>
> fwiw, ...
no sleep.  :-(  so, if you (WFP)/anyone is interested, I can add to the ..
mystery.
I have the same alpha.10064268 installed on two machines, and I mean the same.
both built from the same tarball using nearly identical package build scripts.
on one machine, as posted, I see a decrease in time by (just) better than 50%
for the coloured background.  on the other, the alpha behaves as you describe,
time up from seconds to over a quarter of an hour.  wow.  I also tried two older
3.8.0-alphas (9893777 and 9945627) on a third box, they too run faster by around
50% when colour is used.  one thing I noticed is that where time decreases, on
the older boxes, the "CPU detected" reads "Intel,SSE2,AVX", whereas for the ..
misbehaving alpha (newer box) it's "Intel,SSE,AVX,AVX2,FMA3".  no idea whether
that is relevant, still, it'd be interesting to know what CPU flags others see.
anyway, as Kenneth intimated, computing, eh? -- all good fun.
regards, jr.
Date: 19 Sep 2020 08:22:46
Message: <5f65f816$1@news.povray.org>
> mystery.
Jim, and all thanks for the data. And jr, especially, for picking up the
"Intel,SSE,AVX,AVX2,FMA3" bit. It is what I see here for run time
optimization. I've hit a few other cases where - for whatever reasons -
that run time CPU optimization isn't faster for me, though usually it
is. Nothing previously was anywhere as dramatic a slow down.
I've never looked over Christoph's am3 code. Guess I'll go take a peek.
Bill P.
Date: 19 Sep 2020 10:08:46
Message: <5f6610ee$1@news.povray.org>
Hey jr, Given you have machine which shows the slow down and one which
does not, would you be willing to add the following test in compiles for
both machines? Then try white/black and white/color renders on both?
In tracetask.cpp, at about line 764, insert code so things look like:
double cf = confidenceFactor[neighborSamples-1];
PreciseRGBTColour sqrtvar = Sqrt(variance);
if (variance.red()<0)
     throw POV_EXCEPTION_STRING("kaboom");
PreciseRGBTColour confidenceDelta = sqrtvar * cf;
I think in povr I've fixed the stats - so your line counts might be a
little different.
I hacked the up front confidence array (as vector) to something simpler
so my b/w runs in about 2 seconds and my color one in 34s. Stats now
show for the two renders:
Pixels: 360000   Samples:  609399 Smpls/Pxl: 1.69
and
Pixels: 360000   Samples: 9511337 Smpls/Pxl: 26.42
Bill P.
