POV-Ray : Newsgroups : povray.general : user_defined camera Server Time
17 Aug 2025 16:27:54 EDT (-0400)
  user_defined camera (Message 1 to 10 of 11)
Subject: user_defined camera
Date: 16 May 2019 03:20:01
Message: <web.5cdd0e3b187d86e7776fc67d0@news.povray.org>
Hi!
I'm trying to use the user_defined camera, but the explanation in the reference
and the examples I find around are still obscure to me. Is there any for-dummies
introduction? Is there anyone who can try to describe its use in different
words?
Thank you
igmar
Subject: Re: user_defined camera
Date: 16 May 2019 06:32:12
Message: <5cdd3c2c$1@news.povray.org>
On 5/16/19 3:16 AM, IGM wrote:
> Hi!
> words?
> Thank you
> igmar
Have you played with the v3.8 sample scene? It was aimed to be pretty
simple and has a defined perspective camera too so you can see - in a
more usual way - the shapes which the user_defined inward cylindrical
camera is 'viewing' as rays are defined in a rotating fashion around the
y axis from top to bottom.
<install location>/scenes/camera/user_defined.pov
or on github at:
https://github.com/POV-Ray/povray/tree/master/distribution/scenes/camera
The location block defines the origin of each ray. The direction block
the direction from each ray. Change, for example, the { y } in the
locations block of the example scene to { y+0.5 } and render the scene
anew. (The inward looking cylindrical set of rays now sits higher in y
relative to the shapes in the scene.)
Bill P.
Date: 18 May 2019 10:55:01
Message: <web.5ce01ba257450ea956a775350@news.povray.org>
Yes, but maybe I didn't spend enough time with it...
Thank you, I will give it another try.
igmar
Date: 18 May 2019 14:25:06
Message: <web.5ce04d7857450ea956a775350@news.povray.org>
After some testing, I've a question: with user_defined camera, camera
transformations (rotate and translate) won't work. Once created the three
functions{} (for direction and location) suitable to obtain a particular effect,
is there a way to "rotate" the whole camera? The insertion of translation is
very simple, but for rotation things seem more complicate..
Date: 18 May 2019 16:00:01
Message: <web.5ce063e257450ea956a775350@news.povray.org>
By the way, the second example found in
"http://wiki.povray.org/content/Reference:Camera#User_defined_projection"
uses "rotate", but it has no effect...:
// Only direction functions specified
#declare Camera01 = camera {
    user_defined
    direction {
      function { x }
      function { y }
      function { 1 }
    location  <0,0,-2>
    rotate    y*5
Where am I wrong?
igmar
Date: 20 May 2019 08:55:57
Message: <5ce2a3dd$1@news.povray.org>
>      user_defined
>      direction {
>        function { x }
>        function { y }
>        function { 1 }
>      location  <0,0,-2>
>      rotate    y*5
> Where am I wrong?
> igmar
I think your right the documentation doesn't match the functionality
with respect to camera modifiers. As to what should be or not, others
better know.
I've not thought about a functionally defined camera set up where the
functions enable later rotation. With functions suppose possible though
complicated. I'll let the idea rattle around my skull for a while.
I was involved in the original ODS work that led to creation of the
user_defined camera and I created the shipped sample scene. But, I've
never worked in the camera source code so I don't know it - specifically
how the modifiers get applied with cameras / or camera rays. Having that
functionality with user_defined cameras would be convenient.
I've used the user_defined camera extensively in my own work, but always
straight up never needing to transform the camera after the functional
definition. I have a vague recollection of someone else posting the
transform stuff didn't work for user_defined cameras (or 'maybe' some
other camera type) and an expert's reply. I had no luck turning it up in
a couple quick searches.
If you need some user defined, transform-able camera immediately, the
mesh camera is another kind of user defined camera where transforms -
applied to the mesh itself at least - should work fine. Unfortunately
the mesh camera's mesh load (parse time) tends to be expensive. And
don't forget Jerome's hgpovray38 has additional inbuilt cameras.
Bill P.
Date: 20 May 2019 13:00:00
Message: <web.5ce2dc7a57450ea956a775350@news.povray.org>
I'm following also the discussion
http://news.povray.org/povray.general/thread/%3CXnsA9E3A3F647A49seed7%40news.povray.org%3E/
The approach, in my opinion, is still far from being user friendly, but I
_think_ that the problem is similar to mine.
igmar
Date: 20 May 2019 13:50:07
Message: <web.5ce2e84e57450ea94eec112d0@news.povray.org>
> Hi,
> igmar
Yes, I recall briefly looking at that thread.
TOK has a very thorough understanding of a lot of the underlying math, and
excels in applying it and translating it into code.
Since this (in my mind) seems very similar to isosurfaces, you might take a look
at
http://www.econym.demon.co.uk/isotut/substitute.htm
to see how various transforms are implemented in functions.
As for rotations, I looked into the transforms for that a number of times.
There should be some useful links in this thread
http://news.povray.org/povray.general/thread/%3Cweb.5b9ed475f76fb4baa47873e10%40news.povray.org%3E/
as well as others to show you how to change the expressions for x, y, and z to
rotate the function you want to use.
Date: 27 May 2019 19:38:05
Message: <5cec74dd@news.povray.org>
On 5/20/19 12:57 PM, IGM wrote:
> Hi,
> igmar
See post today to povray.binaries.images with the title:
"Method to apply transforms to user_defined camera."
It's at least a start on something useful that works today.
Bill P.
Date: 4 Jun 2019 03:20:01
Message: <web.5cf61adb57450ea9d5f3e7360@news.povray.org>
> > Hi,
> > igmar
> Bill P.
I tried the macro by Olav, but I found an unexpected behaviour:
https://news.povray.org/povray.general/thread/%3CXnsA9E3A3F647A49seed7%40news.povray.org%3E/?mtop=427321&moff=10
igmar
