POV-Ray : Newsgroups : povray.general : POVRay uses just half of many cores Server Time
5 Mar 2026 02:20:40 EST (-0500)
  POVRay uses just half of many cores (Message 1 to 10 of 12)
Subject: POVRay uses just half of many cores
Date: 7 Dec 2018 13:55:00
Message: <web.5c0ac10623560652ee75e2ca0@news.povray.org>
Hello everybody,
today I got a new toy: a server with two sockets, each equipped with an AMD EPYC
7451 24-core processor with 2-way multithreading. It's running on Windows Server
2019. As a benchmark I installed the most current stable version of POVRay
(3.7.0.msvc10.win64). Unfortunately I had to notice that POVRay just uses the
first half of all virtual processors (48 instead of 96). Even starting two
instances of POVRay and letting it run crams all processes to just the first
half shown in the task manager. Also increasing the number of threads from 48
(default) to 96 doesn't occupy all virtual processors, but again just half of
them.
Do you have any idea, how to solve that issue?
Subject: Re: POVRay uses just half of many cores
Date: 7 Dec 2018 14:40:01
Message: <web.5c0acc11aed62423ee75e2ca0@news.povray.org>
I just found out that it has something to do with 'processor groups', as Windows
divides the cores for >64 core machines in several groups and a program which is
not aware of processor groups is limited to stay in one group. In my case the
groups are 48 processors and both groups are equal in size.
Date: 7 Dec 2018 15:05:06
Message: <5c0ad272$1@news.povray.org>
Am 07.12.2018 um 20:37 schrieb Mirfaelltkeinerein:
Yes, you're stuck with 48 threads. I don't think that will change any
time soon - we're using Boost for thread management, which does not seem
to support processor groups yet.
It might be worth trying whether the "Windows Subsystem for Linux" can
make use of all processors simultaneously.
Date: 8 Dec 2018 08:25:01
Message: <web.5c0bc603aed6242340522cf90@news.povray.org>
Hmmmm, here
https://www.boost.org/doc/libs/1_68_0/libs/fiber/doc/html/fiber/numa.html
is something written about it. So it should be able with Boost...
Date: 8 Dec 2018 10:20:27
Message: <5c0be13b$1@news.povray.org>
Am 08.12.2018 um 14:24 schrieb Mirfaelltkeinerein:
> Hmmmm, here
Boost is actually not a single homogenous library, but a collection of
libraries. POV-Ray is using Boost.Thread for multithreading; the linked
page however is about NUMA support in Boost.Fiber, which is an entirely
different library for somewhat similar purposes.
I find it a bit odd to find NUMA support in Boost.Fiber, as that library
is all about /fibers/, which aren't full-fledged threads, but rather
just a programming aid to more easily manage different jobs in a single
thread, using cooperative scheduling.
Date: 10 Dec 2018 04:25:00
Message: <web.5c0e2feaaed62423ee75e2ca0@news.povray.org>
Ok, I have to admit, that I have little knowledge about it.
I'm just hoping, that in future releases POVRay can use all available resources
under Windows, too.
Date: 10 Dec 2018 05:02:50
Message: <5c0e39ca$1@news.povray.org>
>> Hmmmm, here
How do render farms cope with multiple CPUs? Could a variant of that
method be used?
Regards
Date: 10 Dec 2018 06:04:19
Message: <5c0e4833$1@news.povray.org>
Am 10.12.2018 um 11:02 schrieb Stephen:
> method be used?
I'm pretty sure they're either not running Windows, or they're using
software that manages threads via Windows' native API.
Date: 10 Dec 2018 06:20:05
Message: <5c0e4be5$1@news.povray.org>
Am 10.12.2018 um 10:20 schrieb Mirfaelltkeinerein:
> under Windows, too.
It should be possible to utilize multiple processor groups by running
multiple instances of POV-Ray, each using a different processor group.
The problem there is that programs are assigned to processor groups in a
round-robin fashion, so if any other program happens to be started in
the background between running the POV-Ray instances, they'll happen to
be assigned to the same processor group.
Date: 10 Dec 2018 06:49:22
Message: <5c0e52c2$1@news.povray.org>
>> method be used?
Thanks, I was just wondering.
Now I expect that jr will be going :P :P
Regards
