POV-Ray : Newsgroups : povray.general : Colour from single trace Server Time
29 Apr 2024 01:39:06 EDT (-0400)
  Colour from single trace (Message 17 to 26 of 26)
Subject: Re: Colour from single trace
Date: 15 Nov 2018 13:38:01
Message: <5bedbd09$1@news.povray.org>
Am 15.11.2018 um 18:33 schrieb Le_Forgeron:
> Now, let's fight about trace_uv_map or any better spelling or wording.
Since you cannot compute an UV coordinate without computing an
intersection, I would lean towards designing this as an extension to the
existing `trace` function, via yet another optional parameter after the
normal variable. That way we can avoid double work when the user wants
both the intersection point's location and the UV coordinates.
Also, if for some reason we need to implement it as a separate function,
I would prefer `trace_uv`. We don't have the `map` appendix in any other
UV mapping related stuff (e.g. it is `uv_vectors`, not
`uv_map_vectors`), so adding it here would be inconsistent.
Date: 16 Nov 2018 14:33:21
Message: <5bef1b81$1@news.povray.org>
So, it should look somewhat like :
#declare Location= trace( Object, Start, Dir, Normal, UV_Location );
or
#declare Location= trace( Object, Start, Dir, Normal, UV_colour );
If it ever get implemented.
Date: 16 Nov 2018 23:20:01
Message: <web.5bef968b306629fe2efea42a0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Le 15/11/2018 à 18:08, Le_Forgeron a écrit :
> > Le 14/11/2018 à 11:05, And a écrit :
> >> In my imagine there is another function traceUvMap(start_point, direction)
> >> return the uv-map <u, v>
> > Objections, my dear:
> > 1. usual SDL is lowercase, and words are separated with underscore, not
> > Camel syntax (as Uppercase is reserved to users)
> > 2. trace() requires an object, as the whole scene is not yet available,
> > and you might trace to defined but not present in scene object
> > So it would rather looks like
> > trace_uv_map( object, start_point, direction)
> And it's a kind of 5 minutes patch, see at;
> https://github.com/LeForgeron/povray/tree/feature/traceUvMap
Sorry, how to use...
I mean github
> demo to get output:
> UV : <0.000, 1.000>
> with
> #version 3.8;
> global_settings{ assumed_gamma 1.0 }
> #declare Object = sphere { 0, 1 }
> #declare Start = <0,4,0>;
> #declare Dir = -Start;
> #declare UV= trace_uv_map( Object, Start, Dir );
> #debug concat("UV : <", vstr(2, UV, ", ", 0, 3 ), ">\n")
Date: 17 Nov 2018 04:51:45
Message: <5befe4b1$1@news.povray.org>
Am 17.11.2018 um 05:18 schrieb And:
> I mean github
I guess the most important things to know (in this case):
- What the link takes you to is GitHub's overview of a patched version
of POV-Ray.
- Clicking on the green "Clone or download" button and then "Download
ZIP" (at the bottom of the pop-up) will download a ZIP package
containing that version's complete source code.
- The version does not come with binaries, so to use it on a Windows
machine you would have to compile it yourself.
If you are more interested in having a look under the hood of the patch
rather than test-driving it:
- To view what has been changed in the patched version, click on
"Compare" immediately below said button (in the line reading "This
branch is 1 commit ahead of POV-Ray:master")
Date: 17 Nov 2018 05:31:10
Message: <5befedee$1@news.povray.org>
Am 16.11.2018 um 20:34 schrieb Alain:
Yes, that would be the trivial-to-implement solution.
> or
In this case, it would be more like:
     #declare Location= trace( Object, Start, Dir, Normal, colour );
While I agree that this would be the most desirable solution, I'm not
sure whether it would be possible to implement in a fully consistent
manner. As someone hinted at earlier in this thread, objects don't have
pigments - they have textures, which may be arbitrarily complex. There
may be cases (either now or in the future) where there's no single
unambiguous colour associated with the ray-object intersection.
As an extreme example, take SSLT: In the first incarnation (somewhen
during the beta phase of POV-Ray v3.7.0) the colour of SSLT textures
wasn't controlled by a pigment, but was an emergent property of quite
different physics-based parameters.
While it may turn out to be possible to resolve this issue in a
well-defined manner, it certainly won't be trivial.
Date: 3 Dec 2018 09:50:00
Message: <web.5c05411d306629fe25503a850@news.povray.org>
> > I mean github
> of POV-Ray.
I think I will use this function in the future, but temporary not.
In fact I'm unable to compile it.
> > or
From my perspective UV_Location = trace_uv_map(Object, Start, Dir); is better,
after all not every objects have uv map.
#declare Location= trace( Object, Start, Dir, Normal, UV_Location ); does the
same function (for my needs)
At the beginning I want this function because I want to create some scene. E.g
fungus growing on a rock. And I want to produce the rock with a third party
software like blender, and paint a texture on it to design the density of
fungus. If I have the trace uv map function I can trace the rock to get the
color of texture, then use random() <? texture color to decide whether
is the fungus there to achieve my intention.
Date: 3 Dec 2018 10:00:01
Message: <web.5c0543d1306629fe25503a850@news.povray.org>
Inspired by these pictures
https://www.pinterest.com/pin/186617978287852820/
https://www.pinterest.com/pin/477663104213161095/
https://www.pinterest.com/pin/518265869605948864/
https://www.pinterest.com/pin/451837775112045194/
Date: 31 Dec 2018 06:44:23
Message: <5c2a0117$1@news.povray.org>
You can have the best of both world, now, at >
https://github.com/LeForgeron/povray/commit/cea994f8e69375f9de809bea5df241f1a269f702
(same branch as before):
* added uv-vector as optional parameter of trace(), after normal
* changed trace_uvmap to trace_uv, for the ones which only wants uv data
and do not care about intersection & normal.
Download 'traceuv.pov.txt' (1 KB)
Date: 2 Jan 2019 03:10:01
Message: <web.5c2c70e9306629feff23041c0@news.povray.org>
Date: 3 Jan 2019 06:15:00
Message: <web.5c2dee0c306629feff23041c0@news.povray.org>
Waiting a binary release
(Or should I understand how to compile a c++ program)
