POV-Ray : Newsgroups : povray.general : no_image behaviour Server Time
26 Apr 2024 14:16:53 EDT (-0400)
  no_image behaviour (Message 25 to 34 of 34)
Subject: Re: no_image behaviour
Date: 19 Jun 2018 06:40:00
Message: <web.5b28dcbd6d52b562458c7afe0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> you mean like WF Pokorny suggests in
> http://news.povray.org/5b279884%241%40news.povray.org?
Yeah - I just got around to reading through his code before to see that that's
what he was actually doing.  I had a hard time implementing it from scratch, as
I'm still struggling with the context and syntax for using patterns in
functions.
POV-Ray didn't like this:
density {
     function {pattern {
          object {Intersector
               color_map {
                    [0.0 rgb 0]
                    [0.5 rgb 0]
                    [0.5 rgb 1]
                    [1.0 rgb 1]
> the whole concept is new to me.
Try these:
http://www.f-lohmueller.de/pov_tut/tex/tex_560e.htm
http://www.f-lohmueller.de/pov_tut/tex/tex_561e.htm
http://www.f-lohmueller.de/pov_tut/tex/tex_562e.htm
> > It's too hot to think over here, ...
> lucky so and so..
Surely you jest.   But we got a storm front in last night that whisked away
everything in a sudden downpour.   LOTS cooler at the moment.  (crossing
fingers)
Hoping you work this out - the idea seems very cool, and I'm _really_ looking
forward to seeing the animation!
Date: 19 Jun 2018 09:30:00
Message: <web.5b2905056d52b562635cc5ad0@news.povray.org>
hi,
> functions.
> density {
>      function {pattern {
>           object {Intersector
>                color_map {
>                     [0.0 rgb 0]
>                     [0.5 rgb 0]
>                     [0.5 rgb 1]
>                     [1.0 rgb 1]
> Try these:
thanks.  I will have to get v3.8 installed first though.  next couple of days
or so, is the plan.
phew.  no pressure then.  ;-)
regards, jr.
Date: 19 Jun 2018 15:04:59
Message: <5b2953db@news.povray.org>
> functions.
> density {
>       function {pattern {
>            object {Intersector
>                 color_map {
>                      [0.0 rgb 0]
>                      [0.5 rgb 0]
>                      [0.5 rgb 1]
>                      [1.0 rgb 1]
Obviously, it don't like that. The object pattern don't support
color_map, but demand 2 colours.
function{pattern{object{Object Colour1, Colour2}}}
Date: 21 Jun 2018 04:50:00
Message: <web.5b2b65ca6d52b562635cc5ad0@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> The latest 'Pre_release' has been good to me.
> https://github.com/POV-Ray/povray/releases/tag/v3.8.0-alpha.9606898
thanks.  after installing I tried your code, and yes, you were correct, the
scene demonstrates the exact effect I'm after.
so I printed out the code for closer examination.  it must have taken me 20 mins
or so before I saw where the colours are coming from (the trailing commas in
user_defined{} did that  :-)), and perhaps as long again to understand why the
enclosing sphere doesn't display in white.
I thought I now have a handle on this - until I changed the green component of
the user_defined from multiply to add.  :-)  and now I have more questions..
so, I do not understand why the multiplication and addition differ.  I get the
changed colours, but not why the part of the hidden sphere which does not
intersect the reveal box only shows when added or why it doesn't when
multiplied.
another question regards the actual density of box and hidden sphere.  their
densities decrease away from the centres because functions are used, I presume.
how would one get an uniformly dense box and/or sphere?  is a DF3 needed?
and, last question, is there a particular reason that the media colour is rgb
while all other colours are sRGB?
thank you again for the code (and your time), I feel I'm learning.
regards, jr.
Date: 21 Jun 2018 08:49:47
Message: <5b2b9eeb$1@news.povray.org>
On 06/21/2018 04:48 AM, jr wrote:
> hi,
> multiplied.
The object pattern returns 0 or 1. Where we have the reveal box for the
red channel, the density value is always 1.0 and we always see that box.
To reveal the hidden sphere only where the reveal box exists we're using
the green channel and multiplication. Only where we have 1(reveal
box)*1(hidden sphere) in the green channel does it turn on (=1) and red
and green now mix to get yellow for box samples within the hidden
sphere. Outside the reveal box where have 0(reveal box)*1(hidden sphere)
or 0 for density.
When you use addition instead for the green channel of the reveal box is
also on inside the box (as already was red) and you get yellow for the
box alone. The sphere is 1 where points are inside so you get green for
the parts which are outside the reveal box. Inside the reveal box you
get 1+1 green channel density and a more intense yellow green where they
mix.
The densities in the original implementation are 1 or 0 inside the
reveal box. The apparent density decrease you see is due the differences
in path length through the constant the density. In other words each
ray's travel time through the density is different. When using emissive
media this means the longer travel distances end up brighter. You can
normalize to degrees in various ways, but up front I'd suggest adding
absorbing media also at 1/white to start. As rays travel further the
more absorption you get.
The media spec could be srgb so long as you understand the resulting
internal linear rgb values, but with densities and media it's much
easier to work and think in linear, 'assumed_gamma 1.0' space.
Happy to help - it's an interesting challenge.
> regards, jr.
Aside: In the code the overall media container encloses the reveal and
hidden shapes. In an actual implementation you likely want your reveal
object to also be your media container for performance reasons.
Bill P.
Date: 21 Jun 2018 16:53:19
Message: <5b2c103f$1@news.povray.org>
Le 18-06-21 à 04:48, jr a écrit :
> hi,
> multiplied.
> regards, jr.
The actual effect of all media depend on how long is the path through
them as well as it's density. Double the path's length and you double
it's contribution.
Next, that density can get affected with some pattern, like spotted,
granite, spherical, planar, ... You don't need to use any DF3.
If you don't use any pattern, then the media's density is uniform and
only the length of the paths through it will affect the end result.
Using an orthographic camera parallel to an axis and a container/pattern
aligned to the axis can ensure that all paths are of the same length. In
all other cases, you can't be sure that all paths have the same length
unless you are extremely careful.
Take those colours : rgb<1,0,0.5> and rgb<0,1,0.5>
When you  multiply them, you get :
Mult = <1,0,0.5>*<0,1,0.5> = <1*0, 0*1, 0.5*0.5> = <0,0,0.25> (dark blue)
When you add then, you get :
Add = <1,0,0.5>+<0,1,0.5> = <1+0, 0+1, 0.5+0.5> = <1,1,1> (white)
That's when working in rgb or linear colour space.
If you use srgb instead, the actual values you give are gamma adjusted
before the rendering start. If all of the colour components are 0 or 1,
then, it makes no difference to use rgb or srgb. In all other cases,
there is a difference.
rgb<0.1, 0.5, 0.8> is not the same as srgb<0.1, 0.5, 0.8>
Whenever you have additive effects to take into account, you need to
work in linear colour space to get accurate results. That's why it's
highly recommended to always use "assumed_gamma 1" in the
global_settings block.
Date: 22 Jun 2018 12:25:01
Message: <web.5b2d22706d52b562635cc5ad0@news.povray.org>
hi,
> it's contribution.
> Next, ...
I'll need to print, read, and then study this reply + many of the preceding.
hoping to .. assimilate the information .. somehow.  :-)
thank you very much, and everybody who has "chipped in".
the plan now is to make a simple "pre-cursor" animation to play with the
concept, learn.  hoping to start on this in the next few days.
regards, jr.
Date: 22 Jun 2018 20:08:08
Message: <5b2d8f68@news.povray.org>
Le 18-06-22 à 12:23, jr a écrit :
> hi,
>> it's contribution.
>> Next, ...
> regards, jr.
Two very simple tests :
1) Make a scene with a few boxes in an union. Use an orthographic
camera. All boxes have the same frontal area, but are progressively
deeper and filled with some uniform media. Apply the media to the whole
union, not to each individual box.
The deeper the box, the more intense the media effect will be.
2) Make a scene where the box depth is controlled by the clock variable
and render as an animation.
Use a box like this one :
box{<-1, -1, 0> <1, 1, 20*clock> pigment{rgbt 1}hollow
  interior{media{emission 0.1}}
Render with +kff10 on the command line.
Date: 25 Jun 2018 11:10:01
Message: <web.5b31046a6d52b562635cc5ad0@news.povray.org>
> concept, learn.
trying, and so far failing.  :-(
the main difference between the example code posted by WF Pokorny and mine is
(a) no enclosing sphere or box, and (b) use of emission colours other than
white.
I have also tried a variation based on the same code which attempted to
implement Alain's idea of a union with a common material, no success either.
so I'll post a zip with a wip test scene file and an ini "driver" in
p.text.scene-files; the sixth frame is where I'd hoped the hidden object would
interact with the majority of the (few sample) notes (it's all pretty crude, I'm
no artist :-)).  frames take a couple of seconds to render.
if anyone could have a look to tell me whether the approach is viable
(everything's in arrays, basically), and where I'm "missing the boat", I'd much
appreciate it.
thank you.
regards, jr.
Date: 26 Jun 2018 22:10:00
Message: <web.5b32f1086d52b562458c7afe0@news.povray.org>
Check p.b.animations for movie and code
