POV-Ray : Newsgroups : povray.general : rounded_objects: a new feature? Server Time
18 May 2024 16:12:09 EDT (-0400)
  rounded_objects: a new feature? (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: rounded_objects: a new feature?
Date: 15 Sep 2016 13:10:00
Message: <web.57dad3c8696ad3a7cafab50@news.povray.org>
scott <sco### [at] scottcom> wrote:
> It actually sounds similar to distance field rendering which is used a
> lot in real-time raytracing. Once you have the distance fields then it's
> easy to do a "smooth union" between shapes:
> http://www.iquilezles.org/www/articles/smin/smin.htm
Alain wrote:
> You may do a blobbing of the intersection of four planes to get a
> rounded tetrahedron, of six planes for a rounded box,...
> Possible, done before and relatively slow.
I think this means that what I am suggesting is feasible, and indeed already
do-able to a limited extent.
However both the blob definition and isosurfaces are for me non-intuitve.
Take the tetrahedron for example, I will probably know where I want the four
vertices to be, so defining each of the four rounded_object plane elements with
three vectors is simple. Writing it as a set of equasions needs a bit of
pondering, which is what computers are for.
I can see how blob definition has been written in its simplest form by
programmers, but for the user it would be much more convenient to input the
radius of the sphere that would be seen in isolation and the distance the field
extends beyond this. I know these relate to the actual input parameters by very
simple arithmetic, which is also is what computers are for.
Of course calculating field strengths is going to slow things down, but would it
be possible to be able to have a fast mode where this left out and the object
rendered with sharp corners?
I think implementing rounded-object with just planes, cylinders and spheres
would not be that difficult and would give:
- an immediate improvement in usability.
- Individual radii for planes would enable a significant new repertoire of
rounded shapes.
- Rounded objects as elements would extend this
- sphere sweep elements would be amazing.
> Note that there are two distinct types of "round" being discussed, it's
> important not to confuse them. The first is the "CAD" type of perfect
> round that is formed by conceptually rolling a sphere (of radius equal
> to the round you want) along the edge. The second is this type of
> "artistic" round that smoothly blends the two shapes, but is not
> necessarily possible to accurately specify the round radius (or it might
> not even be constant throughout the round).
My point exactly when I wrote:
> >(The calculation might be faster with cubic; the corners would not be exactly
> > circular, but would anyone notice or care?)
Maybe we could go further and, with an extra optional parameter, change the
profile of the rounding from a rounded bevel to a "V" shape?
Date: 15 Sep 2016 13:57:33
Message: <57dae10d$1@news.povray.org>
This will only work for non-interacting blob elements. Whenever two or
more elements interact, the location of the surface will get pushed away
from that location. It can be pushed inward or outward depending on the
strength of each component. Remember that a blob component can have a
negative strength.
The actual rounded "primitives" are really unions of several shapes.
The rounded box use no less that 7 boxes, 12 cylinders and 8 spheres.
The rounded cylinder and cone use 2 cylinders and 2 torus, or a cylinder
and 2 spheres.
They have the normal, union, mode and the merge mode for use with
transparent textures where you don't want the inner surfaces to mess up
things.
I don't think so.
> rounded shapes.
A plane is a plane, a simple surface extending to infinity, it have no
roundness. In POV-Ray, a plane have the geometric definition of a plane:
An infinite, infinitely thin, surface dividing space in two: above and
under.
The sphere_sweep primitive exist and is far from trivial, even for
linear sweeps. Adding blobbing or rounded edges would be absolutely
nightmarish.
How would you round the edge of an irregular twisting tube and a plane,
given that the tube can have a variable curvature,  radius and elevation
over the plane, can travel under the plane or above.
Except in the most trivial cases, you can't make an isosurface
equivalent of the sphere_sweep.
Date: 16 Sep 2016 02:47:43
Message: <57db958f$1@news.povray.org>
I don't think the method you are suggesting is capable of generating
correct rounds (with constant radius curvature and tangent to both
faces) nor creating a constant "V" profile (a bevel). But willing to be
proved wrong, give it a go with some simple shapes and isosurfaces/blobs
and see what you get. If you're on to something then some working
example code will go *far* further than just a text description.
Date: 16 Sep 2016 05:25:00
Message: <web.57dbb989696ad3a7cafab50@news.povray.org>
Totally agree, I am working on it.
The aim is for a tangent at both ends with a smooth curve in between. A constant
radius is only needed in CAD to specify the shape of a real thing. Here, if it
looks good. it is good.
Date: 16 Sep 2016 12:25:00
Message: <web.57dc1bb7696ad3b488d9aa0@news.povray.org>
What about:
http://www.econym.demon.co.uk/isotut/splines.htm
Date: 17 Sep 2016 07:25:00
Message: <web.57dd278e696ad3a7cafab50@news.povray.org>
And here it is:
// This work is licensed under the Creative Commons Attribution 3.0 Unported
License.
// To view a copy of this license, visit
http://creativecommons.org/licenses/by/3.0/
// or send a letter to Creative Commons, 444 Castro Street, Suite 900, Mountain
View,
// California, 94041, USA.
// Demonstration of plane elements for rounded objects
// Vers: 1.00
// Date: 17 Sept 2016
// Auth: John Greenwood
#version 3.7 ;
camera {location <10,10,10> angle 30 look_at <0,0,0> }
  background { color rgb<0.2, 0.4, 0.8>  }
  light_source {<10,20,5> color White}
  global_settings {assumed_gamma 1.0 }
  #declare Corner_Profile = -.5;   // -.5 gives rounded bevel, 0 almost round,
+.5 Not noticebly sharper
  #declare Corner_round = 1;
  #declare R_plane = function( X,r,s){
select((X>r)-(X<-r),2*(r<0)-1,s*pow(X/r,5)-(2*s+.5)*pow(X/r,3)+(1.5+s)*X/r,1-2*(r<0))
  isosurface {
     function {
               R_plane(x+1.5,-Corner_round,Corner_Profile)
              +R_plane(x-1.5,+Corner_round,Corner_Profile)
              +R_plane(y-1.5, Corner_round,Corner_Profile)
              +R_plane(y+1.5,-Corner_round,Corner_Profile)
              +R_plane(z-1.5,+Corner_round,Corner_Profile)
              +R_plane(z+1.5,-Corner_round,Corner_Profile)
     threshold -5
      max_gradient 6
    contained_by { box { -2, 2 } }
  pigment {color rgb < 1, 0.9, 0.65>}
// Example 1. Notes: changing the threshold does have the effect of
shrinking/swelling the object. Corner_round = 1.5 Corner_Profile = -.5 gives a
rounded octrahedron
     function {
     threshold -5
// Example 2. Demonstrates not all the same corner profile
     function {
               R_plane(x-1.5,+.5,0)
              +R_plane(x+1.5,-2,0)
              +R_plane(y-1.5, 1,-.5)
              +R_plane(y+1.5,-1,-.5)
              +R_plane(z-1.5,+1,-.5)
              +R_plane(z+1.5,-1,-.5)
     threshold -5
//Example 3. Five planes, not all othogonal
     function {
              +R_plane(y+z-1,+Corner_round,Corner_Profile)
     threshold -4
//Example 4. Corner definitions can be variable: Round
     function {
               R_plane(x+1.5,-.5,Corner_Profile)
              +R_plane(x-1.5,+1.5,Corner_Profile)
              +R_plane(y-1.5, Corner_round+.5*x,Corner_Profile)
              +R_plane(y+1.5,-Corner_round-.5*x,Corner_Profile)
              +R_plane(z-1.5,+Corner_round+.5*x,Corner_Profile)
              +R_plane(z+1.5,-Corner_round-.5*x,Corner_Profile)
     threshold -5
//Example 5. Corner definitions can be variable: profile
     function {
               R_plane(x+1.5,-.4,0)
              +R_plane(x-1.5,+.4,0)
              +R_plane(y-1.5, Corner_round,Corner_Profile*x)
              +R_plane(y+1.5,-Corner_round,Corner_Profile*x)
              +R_plane(z-1.5,+Corner_round,Corner_Profile*x)
              +R_plane(z+1.5,-Corner_round,Corner_Profile*x)
     threshold -5
Date: 18 Sep 2016 07:00:01
Message: <web.57de7375696ad3a7cafab50@news.povray.org>
"John Greenwood" <nomail@nomail> wrote:
> And here it is:
And now spheres:
License.
View,
// Demonstration of Sphere elements for rounded objects
// Vers: 1.00
// Date: 18 Sept 2016
#version 3.7 ;
camera {location <0,0,22> angle 30 look_at <0,0,0> }
  light_source {<5,20,10> color White}
  #declare R_function = function( F,q,s){
select((F>q)-(F<-q),2*(q<0)-1,s*pow(F/q,5)-(2*s+.5)*pow(F/q,3)+(1.5+s)*F/q,1-2*(q<0))
  isosurface {
     function    {
               R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-1,0)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1 ,-.5,0)
     threshold  1
      max_gradient 4
  texture {pigment {color rgb < 1, 0.9, 0.65>}}
            translate < 3,3,0>  }
  isosurface {
     function    {
               R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-.5,.3)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1 ,-.5,-.4)
     threshold  1
      max_gradient 3
  texture {pigment {color rgb < 1, 0.9, 0.65>}  }
      translate <-3,3,0>        }
  isosurface {
     function     {
R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,min(-.3,-.5-.4*-y),0)
+R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,min(-.3,-.5-.4*+y),0)
     threshold  1
      max_gradient 5
     translate <3,-0,0>         }
  isosurface {
     function    {
                R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-.5,y)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,-.5,-y)
     threshold  1
      max_gradient 4
      translate <-3,-0,0>        }
  isosurface {
     function     {
                R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+.5,-2,-.5)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,-1,0)
     threshold  1
      max_gradient 3
     translate <3,-3,0>         }
  isosurface {
     function    {
                R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+.5,-1,0)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,-1.5,0)
     threshold  1
      max_gradient 4
      translate <-3,-3,0>        }
Date: 19 Sep 2016 03:20:15
Message: <57df91af$1@news.povray.org>
> And here it is:
A good start!
How would you go about doing the union (or difference) of two rounded
cubes? I tried to modify the code to do this but couldn't get it to
work. If that works nicely then I think you're on to something...
BTW you could always use a macro for each element, that depending on
some global switch, either used the standard POV non-rounded primitive
(for speed of setting up the scene) or the isosurface variant (for final
render).
Date: 19 Sep 2016 05:05:01
Message: <web.57dfaa2e696ad3a7cafab50@news.povray.org>
> > And here it is:
> A good start!
> render).
I think I have a plan!
Meanwhile here are some cylinders:
License.
View,
// Demonstration of Cylinder elements for rounded objects
// Vers: 1.00
#version 3.7 ;
camera {location <0,0,17> angle 25 look_at <0,-.30,0> }
  light_source {<5,10,20> color White}
  #declare R_function = function( F,q,p,n){
select((F>q)-(F<-q),2*(q<0)-1,p*pow(F/q,5)-(2*p+.5)*pow(F/q,3)+(1.5+p)*F/q,1-2*(q<0))+n
  isosurface {
     function    {
               R_function(-sqrt(pow(y-1,2)+pow(z,2))+.4-.1*x,-.5,0,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.3,0,-1)
              +R_function(x+1.5,-.3,0,1)
              +R_function(x-1.5,+.3,0,1)
              +R_function(y,-.3,0,1)
     threshold -1
      max_gradient 6
            translate < 0,.7,0>  }
  isosurface {
     function    {
               R_function(-sqrt(pow(y-1,  2)+pow(z,2))+ .5,-.3,.2+.5*x,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.3,.2+.5*x,-1)
              +R_function(y    ,-.5,0,1)
     threshold -1
      max_gradient 6
            translate < 0,-1,0>  }
  isosurface {
     function    {
               R_function(-sqrt(pow(y-1  ,2)+pow(z,2))+ .4,-.5+.2*x,0,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.5+.2*x,0,-1)
              +R_function(y+1    ,-.5,0,1)
     threshold -1
      max_gradient 6
            translate < 0,-2.7,0>  }
Date: 19 Sep 2016 07:15:00
Message: <web.57dfc85c696ad3a7cafab50@news.povray.org>
> > render).
And, more exciting, bendy cylinders!
License.
View,
// Demonstration of Bendy Cylinder elements for rounded objects
// Vers: 1.00
// Date: 19 Sept 2016
#version 3.7 ;
camera {location <5,10,17> angle 10 look_at <0,0,0> }
  isosurface {
     function    {
               R_function(-sqrt(pow(y-.6+.1*x-.1*pow(x,3),  2)+pow(z,2))+
..2,-.1,0,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.1,0,-1)
              +R_function(x+1.5,-.1,0,1)
              +R_function(x-1.5,+.1,0,1)
     threshold -1
      max_gradient 20
            translate < 0,-.5,0>  }
// note that the cross section is a vertical circle, which means that it will be
elliptical on a plane perpendicular to the cuved axis.
// I think this can be compensated for by taking the slope of the curve into
account.
// I have not worked out the details but I think this is a route to sphere
sweeps.
