POV-Ray : Newsgroups : povray.general : Omni-directional Stereo Content Server Time
18 May 2024 09:58:15 EDT (-0400)
  Omni-directional Stereo Content (Message 11 to 20 of 54)
Subject: Re: Omni-directional Stereo Content
Date: 2 Mar 2016 11:40:08
Message: <56d71768$1@news.povray.org>
On 2/28/2016 6:19 PM, Clodo wrote:
> There are a lot of VR Headset now in the market.
> Oculus Rift, GearVR, HTC Vive, Google cardboard etc.
> Also YouTube support 360 panoramic.
> I understand there are a lot of options about rendering with other raytracing
> software, but i don't find any information about Povray.
> The projection model it's called ODS and is full explained in this Google doc:
> https://developers.google.com/cardboard/jump/rendering-ods-content.pdf
> I'm trying to render an ODS, 360 3D shot with Povray.
> There are a function inside the above doc that return the viewing ray for a
> given pixel in raytracing,
> but i don't understand how to use it in Povray.
> Any advice? Thanks.
Can Youtube do cube map 360 degree views? I think they look much better
than sphere maps.
Mike
Date: 2 Mar 2016 13:06:08
Message: <56d72b90$1@news.povray.org>
El 02/03/16 a las 14:57, William F Pokorny escribió:
> Entirely possible I've not myself yet understood what is needed,
   Nor me... just tested the idea I mentioned, but got nowhere.
> think the mesh will be more of a circle of circles of triangles where
> the latter circles are each split between the left and right "eye-rays"
> assigned to the top and bottom portions of the final image - in opposite
> horizontal directions.
> Meaning, the final arrangement of all triangles would - if the circles
> of triangles had some >0 diameter(1) - look more like a cylinder from afar.
   I'm sorry but I cannot imagine what you are describing... :(
jaime
Date: 3 Mar 2016 00:39:23
Message: <56d7ce0b$1@news.povray.org>
On 3/2/2016 7:42 AM, Clodo wrote:
> Another stuff that can be interesting: modern VR headset need to works with 2K
> display at 90fps.
Rendering 90 frames of anything in POV-Ray is going to take forever...
Mike
Date: 3 Mar 2016 09:40:00
Message: <web.56d84b2e976329954e8811590@news.povray.org>
> To state clearly what you probably know - for non-stereo images -
> POV-Ray has the spherical built in camera
Sorry Bill P, this was my fault.
I tested spherical camera some days ago, but caused by an error in my code i
wrong suppose it is a POV-Ray problem. Sorry again.
I confirm that camera{spherical} without any other parameter (like angle) works
perfectly with every video player i tested in VR headset. Non-stereo of course.
I still think will be a great improvement if POV-Ray can support side-by-side
and up-down stereo format out-of-the-box, considering it's now a de-facto
standard and this kind of render will become common with VR headset upcoming
market.
Date: 4 Mar 2016 21:05:00
Message: <web.56da3e6d976329954e8811590@news.povray.org>
I try to build two camera{spherical} image, left and right, simply by translate
on X axis the camera{location} by -0.065/2 and +0.065/2. And of course copy both
image in a single image.
On Oculus DK2 VR headset the 3D look nice, but only in front. Looking to left or
right have 3D effect wrong, looking bottom is messed up. I can't explain it
better. So, it's not so simple.
I done some research, and i discover this page:
http://paulbourke.net/stereographics/povcameras/ that include a specific
"Stereoscopic spherical projection".
Source code changes are for PovRay 3.6.1.
I download latest PovRay 3.7 from GitHub, upgrading and compiling with Visual
Studio 2015. All ok.
I started adapting the patch, parser & tokenizer seem easy, but the patch alter
a "render.cpp" file that now it's called "tracepixel.cpp", and unfortunately the
patch
use a lot of function that i don't have knowledge about adapt it (VLinComb3,
VAddScaled, Frame.Screen_Width etc.).
Sorry but i still not understand why your talking about a Mesh projection, i
simply don't have some background knowledge.
I'm asking myself if the render approach of Paul Bourke described in the above
link can produce a similar render or equal render of ODS.
I will try to download PovRay 3.6.1 and reapply the patch to test it.
Date: 4 Mar 2016 21:10:01
Message: <web.56da3f42976329954e8811590@news.povray.org>
A lot more if i need to use the 3.6 ...
Date: 5 Mar 2016 04:11:08
Message: <56daa2ac$1@news.povray.org>
Am 05.03.2016 um 03:03 schrieb Clodo:
That doesn't cut it, as you've discovered yourself. The problem is that
the offset required is different for each pixel (or, more precisely,
each column of pixels).
I definitely need to bookmark this one.
POV-Ray 3.7 has introduced a new camera type "mesh_camera". It has
different modes, some of which serve quite different purposes, but they
all have in common that the camera geometry is defined by one or more
mesh or mesh2 objects.
In most modes, each mesh triangle defines the ray origin and direction
for an individual pixel of the result image, giving you full control
over the camera geometry on a per-pixel basis.
Date: 5 Mar 2016 04:14:38
Message: <56daa37e$1@news.povray.org>
Am 05.03.2016 um 03:06 schrieb Clodo:
Hmm... presuming your CPU has N cores... what is N*forever?
Date: 5 Mar 2016 07:45:00
Message: <web.56dad3d5976329954e8811590@news.povray.org>
A correct FPS target to avoid illness in VR is 120 FPS.
Oculus and HTC don't want to request high-specs GPU to customers, so it's stay
for the moment on 90 FPS,
but 120 FPS it's the future for next generation headset.
Sony already say that their headset (expected at end of 2016) will be 120 fps.
Also, unlike a normal LCD monitor, VR headset have screen-door effect
( https://en.wikipedia.org/wiki/Screen-door_effect )
caused by lens distortion.
Current headset (Oculus, HTC Vive) use a 2160 x 1200 panel, but it's expected to
reach a 4K for each eyes in a few years.
So, the future (2017/2018) target for VR will be 12K stereo (to obtain around 4K
in FOV) at 120 FPS.
A lot of pixel, around pow(forever,forever) :P
Currently i'm trying to create a simple scene,
a checked plane (for check projection),
mirrors in circle with some sphere at ground and floating (for check 3D effect).
Short in time, but can be looped, an evolution of this:
https://www.clodo.it/blog/mirrors/
Quick to render even in high resolution (at least with multithreading POV-Ray
3.7).
I now it's plain, newbie, weird... but my current objective is to create some
sample/reference video
at different resolution and FPS for testing in VR headset,
and testing if current videoplayers can reproduce it smoothly.
Maybe a correct approach if i render that with a custom/patched POV-Ray, sharing
it with VR community,
and when feedback are positive, integrate in POV-Ray main code (if you are
interested).
I write a mail to the author of the article to inform him about this discussion.
Date: 6 Mar 2016 08:04:25
Message: <56dc2ad9@news.povray.org>
No worries. We all stumble when trying something new - and I stumble
more than most! :-)
> market.
I agree.
In the meantime I did find some time and attempted a mesh camera
solution. See the attached POV-Ray file. Please read the header in the
file as there are some quirks with how scenes must be set up and the
resultant image used.
I would normally post such an example in povray.text.scene-files, but I
have no VR headset with which to test. Would you please render, view and
let us know if the result OK or not?
Bill P.
Download 'utf-8' (6 KB)
