POV-Ray : Newsgroups : povray.general : export to .obj file? Server Time
25 Feb 2026 09:52:00 EST (-0500)
  export to .obj file? (Message 1 to 10 of 14)
Subject: export to .obj file?
Date: 8 Dec 2015 18:35:01
Message: <web.566768f16e39bacce349d4160@news.povray.org>
Is there any software which can input a POVray script definition of an object
and turn it into an .obj file? Thanks.
Subject: Re: export to .obj file?
Date: 9 Dec 2015 09:55:01
Message: <web.56683f7cff12eed3ad6fa18f0@news.povray.org>
If your POV-Ray script has a straightforward structure and contains only mesh or
mesh2 objects, then PoseRay may be able to read it.
Date: 9 Dec 2015 19:32:12
Message: <5668c80c$1@news.povray.org>
Am 09.12.2015 um 15:50 schrieb clipka:
Also, Jerome Grimbert has developed a patched version of POV-Ray that
seems to be able to tesselate (i.e. generate meshes from) arbitrary
POV-Ray objects, and can export them at least in STL format, which
should be convertible to .obj using some external converter.
It is also possible to implement a tesselation algorithm as a piece of
POV-Ray script, but I'd only consider that as a last resort, as it would
probably require quite some parsing time.
Tesselation is a mandatory requirement when converting arbitrary POV-Ray
objects into .obj files, as POV-Ray uses raw mathematical
representations for most of its primitives (e.g. center point and radius
in case of a sphere) during the entire rendering process, whereas the
.obj file format can only store polygon meshes.
Date: 10 Dec 2015 02:42:48
Message: <56692cf8$1@news.povray.org>
Mesh can also be saved (in that same patched version) in gts format.
(and it loads gts too, but not stl)
It is not arbitrary POV-Ray objects, only 3D finite objects:
  * most methods need an interior
  * you cannot make a mesh of povray plane or hyperboloid.
  * but you can make mesh of intersection of planes, if the intersection
is 3D finite and has a non-infinite bounding box.
  * 2D finite objects are not expected (triangle, disc...)
There are 6 tesselation methods... none are perfect (in fact, 2
categories, with 2 & 4 variants). And sometime, it seems there is a bit
of problem like long triangles jumping in the shape.
Date: 10 Dec 2015 03:08:34
Message: <56693302@news.povray.org>
There was a similar question asked earlier this year. It might be worth
a read as Thomas de Groot and William F Pokorny mention macros that
might be useful.
http://news.povray.org/povray.newusers/thread/%3Cweb.556920739fbf4fba62e642c0@news.povray.org%3E/
Regards
Date: 16 Dec 2015 06:05:01
Message: <web.56714484ff12eed389fe99200@news.povray.org>
Thanks to all for your quick and detailed responses!
Date: 16 Dec 2015 21:50:01
Message: <web.567222ceff12eed35e7df57c0@news.povray.org>
I do some work with 3D printers, and so naturally I've come across and used
OpenSCAD.   The way to "build" things is remarkably similar to POV-Ray's SDL.
I'm wondering if it might be "easy" {someone else could do the work ;) } to
translate SDL to the OpenSCAD format, and export as an STL file.   AFAIK, it
should be trivial to convert STL to OBJ.
Date: 25 Jan 2016 12:24:08
Message: <56a65a38$1@news.povray.org>
Is there any way to contact Jerome Grimbert or to download that patched
version of POV-Ray? Thanks.
Date: 25 Jan 2016 14:03:59
Message: <56a6719f$1@news.povray.org>
Am 25.01.2016 um 18:23 schrieb Sven Littkowski:
Le_Forgeron might be able to help you there ;)
Date: 25 Jan 2016 14:52:29
Message: <56a67cfd$1@news.povray.org>
Hash: SHA256
>> patched version of POV-Ray? Thanks.
The code is available on github and bitbucket
(if you like git or mercurial )
and all starts in
http://wiki.povray.org/content/User:Le_Forgeron
The repository is povray, the branch with tesselation and all other
extension/change is Hgpovray (or Hg-povray)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlamfPwACgkQhKAm8mTpkW0ZagP9HxnBIIdFbYYMAKtnIXA7In70
Gt2Zr+An9d9TotFUqeWWMU+QnaV2LQ8TUH+U5P0rJ4ZAmvy9nUHvG26Px5gid0EG
3pBu4+Ldq+ootHE34V0t3EM9NZCOwCi57NeeCKiQapZMAozYQWV397cgH1cyBeds
YeZJCqhDMauJh7VanMI=
=qWmR
-----END PGP SIGNATURE-----
