POV-Ray : Newsgroups : povray.general : turning off mutual shadowing between objects Server Time
14 Jan 2026 23:31:11 EST (-0500)
  turning off mutual shadowing between objects (Message 1 to 9 of 9)
Subject: turning off mutual shadowing between objects
Date: 25 Aug 2014 03:25:00
Message: <web.53fae46957eb8dcf6a92a3a00@news.povray.org>
I want to generate a POV image NoShade(x,y).My question:how can I turn off
mutual shadowing between objects?Can anyboby tell me how can I do? Thanks and
expecting reply! Beg a hot!
Subject: Re: turning off mutual shadowing between objects
Date: 25 Aug 2014 03:36:38
Message: <53fae786$1@news.povray.org>
object {
    no_shadow
Date: 25 Aug 2014 07:25:00
Message: <web.53fb1c922158d2866a92a3a00@news.povray.org>
> object {
>     no_shadow
> Thomas
Thank you!I have a try,but I have a confuse:
test2:
box
        -1.55,1.55
        rotate y*-31
        translate<x1-center_x,y1-center_y,z1-center_z>
        pigment{color rgb ref}
        finish{ambient 0 diffuse 1}
test3:
box
        -1.55,1.55
        rotate y*-31
        no_shadow
why the results are the same when I add  no_shadow,which means turn off
 mutual shadowing between objects.
Date: 25 Aug 2014 10:15:01
Message: <web.53fb44dc2158d2865e7df57c0@news.povray.org>
no_shadow only stop an object from casting a shadow on anything else in the
scene.
If you don't want the other object to cast a shadow, then you need to add a
no_shadow modifier to that as well.
Date: 25 Aug 2014 11:04:18
Message: <53fb5072$1@news.povray.org>
Am 25.08.2014 09:36, schrieb Thomas de Groot:
>> off
>> Thanks and
> object {
>     no_shadow
> Thomas
or
   light_source {
     <X,Y,Z> colour rgb <R,G,B>
     shadowless
Date: 25 Aug 2014 14:04:15
Message: <53fb7a9f@news.povray.org>
If you want a single object not to cast any shadow, add no_shadow to
that object.
That object will still receive shadows cast by other objects.
If you don't want any objects to cast any shadow at all, add shadowless
to your light_source, all of them.
If you want shadows cast on the ground but not on other objects, it can
get tricky.
You'll need to use light_group.
Have a general light_source and your ground, as well as any object that
you want to receive shadows, outside any light_group.
Place all your objects in a light_group. The light_source IN the
light_group are to be made shadowless.
To get consistent results, the global lights and those in the
light_group MUST be in the same locations.
It works because objects in a light_group, while not been illuminated by
global light_source, can still block their light, and can thus cast
shadows on objects that outside of the light_group.
If you want no shadows and only need full illumination without any
shading, you can use +q0 on the command line. This force all textures to
have ambient 1, diffuse 0 and don't compute any light. As a bonus, it's
prety quick.
Date: 26 Aug 2014 01:15:00
Message: <web.53fc16bb2158d2866a92a3a00@news.povray.org>
> that object.
> get tricky.
> prety quick.
> Alain
I want all objects have shadows themselves but have no mutual shadow between
objects.How can I do?
Date: 26 Aug 2014 08:14:58
Message: <53fc7a42$1@news.povray.org>
Am 26.08.2014 07:10, schrieb CAS:
Light groups might do the trick.
Date: 27 Aug 2014 20:51:38
Message: <53fe7d1a@news.povray.org>
>> that object.
>> get tricky.
>> prety quick.
>> Alain
So, you want all objects to cast shadows on the ground/walls, but not on
any other object.
The problem:
All object that don't have no_shadow can cast shadows on any object,
even on objects in other light_group.
One possibility would be to #declare all objects beforehand. Those
objects should NOT have any pigment or texture.
If the objects are CSG objects with parts having different textures,
you'll need two instances: One textured and one not textured.
Place all objects in individual light_group.
The trick follow:
In EACH light_group, have two lights: The first been a normal
light_source, and the second identical but with the projected_through
light modifier that is set to project through an union of ALL other
untextured objects placed in exactly the same position with the exact
same scalling and rotation as those that are visible.
That way, that second light_source will exactly fill the shadows
possibly cast by by those other objects.
Finaly, have the global light_source cast the shadows on the ground or
wall(s).
It's important that ALL lights from all light_group to exactly match the
location and colour of the global light. If the global light is an
area_light, then all those on the light_group must also be area_light
with similar caracteristics.
