![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I use a visualization software that generates pov ray files. I have the
following declared
#declare VertGlyph = object { sphere {<0,0,0>,1} };
#declare vertex_geometry = union
#declare vertctr=0;
#while (vertctr < nverts0000)
#declare vertvalue=ptscalars[verts[vertctr][1]];
object {
VertGlyph
scale VertScaleFunction(vertvalue)
translate pts[verts[vertctr][1]]
#declare vertctr = vertctr+1;
Then the geometry is instantiated as
object {
vertex_geometry
vertex_geometry is basically a bunch of spheres that were declared (not shown
here). I want a blob of all these spheres. I tried the blob around the object
within the while loop in the union. And I also tried the blob command at the
instantiation step around vertex_geometry. In both cases I get the error that
"Parse Error: Need at least one component in a blob."
Is there something wrong because "union" is used? How can I achieve a blob of a
bunch of spheres from the above code?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> following declared
> #declare vertctr=0;
> object {
> VertGlyph
> #end
> object {
> vertex_geometry
I think you have to replace the code like this:
#declare vertex_geometry = blob {
#declare vertctr=0;
sphere {
{<0,0,0>,1, 0.8
I hope there is no error in my code.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 16.01.2014 12:26, schrieb Simulator:
> following declared
You should better make this a macro, otherwise it won't work with blobs.
(The "sphere" statements in blobs aren't objects proper.)
E.g.:
#macro VertGlyph(Radius,Pos)
sphere { Pos, Radius, strength 1.0 }
> #declare vertctr=0;
> object {
> VertGlyph
> #end
You should then be able to modify the vertex_geometry as follows:
#declare vertctr=0;
VertGlyph(
VertScaleFunction(vertvalue),
(BTW, POV-Ray now supports a #for statement that makes counted loops
easier.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > following declared
> E.g.:
> #end
> > #declare vertctr=0;
> > object {
> > VertGlyph
> > #end
> #declare vertctr=0;
> VertGlyph(
> #end
> easier.)
I have tried this an the above suggestions. I still get the same error "Need at
least one component in blob."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 17.01.2014 07:07, schrieb Simulator:
>> #declare vertctr=0;
>> VertGlyph(
>> #end
>> easier.)
Are you sure "nverts0000" is set to a positive value?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
