POV-Ray : Newsgroups : povray.general : Half a cylinder (with open ends) Server Time
25 Feb 2026 23:36:59 EST (-0500)
  Half a cylinder (with open ends) (Message 1 to 10 of 18)
Subject: Half a cylinder (with open ends)
Date: 26 Jul 2012 09:20:01
Message: <web.5011437418f886087f523b7e0@news.povray.org>
Hey guys!
I was trying to create half of a hollow cylinder (both ends open).  I tried
using CSG with an intersection, and that gave me a half a hollow cylinder, but
I'd like to not have a plane on the end.  That is, I'd like essentially a curved
plane (the side of the cylinder without the endcaps).  Is there some
transformation I could use on, for example, a box to achieve this?
Thanks in advance!
- Chaanakya
Subject: Re: Half a cylinder (with open ends)
Date: 26 Jul 2012 09:31:45
Message: <501146c1@news.povray.org>
Just make a difference of the cylinder and another cylinder with a slightly
smaller radius and which is a bit longer ther the first cylinder.
Date: 26 Jul 2012 09:55:01
Message: <web.50114b78c440f4797f523b7e0@news.povray.org>
Thanks!  That lets me control the thickness of the resulting object.  How would
I cut it in half?
- Chaanakya
Date: 26 Jul 2012 10:05:00
Message: <web.50114df0c440f4797f523b7e0@news.povray.org>
> I cut it in half?
> - Chaanakya
This is a bit weird....the shell seems way too thick when I render this:
#version 3.6;
global_settings {
  max_trace_level 256
  ambient_light White
  assumed_gamma 1.0
  location <10,0,0>
  look_at <0,0,0>
  //rotate <0,0,-clock*90>
light_source {
  <0,100,0>
  color White
plane {
  y, -10
  pigment { hexagon Green, White, Blue }
difference {
  cylinder { <-1,0,0>,<1,0,0>,1}
  cylinder { <-1.00003,0,0>,<1.00003,0,0>,0.99999999}
  pigment { color Red }
The shell should be barely visible, but it's quite thick.  Why?  Is it floating
point error?
- Chaanakya
Date: 26 Jul 2012 10:22:36
Message: <501152ac$1@news.povray.org>
Am 26.07.2012 16:02, schrieb Chaanakya:
>> I cut it in half?
>> - Chaanakya
> #version 3.6;
> global_settings {
>    max_trace_level 256
>    ambient_light White
>    assumed_gamma 1.0
> camera {
>    location <10,0,0>
>    look_at <0,0,0>
> light_source {
>    <0,100,0>
>    color White
> plane {
>    y, -10
> difference {
> point error?
What you're seeing is just a perspective effect; change the camera
location to e.g. <10,3,0> and light source position to e.g. <100,100,0>
to better see what's goung on.
Date: 26 Jul 2012 10:35:00
Message: <web.501154cfc440f4797f523b7e0@news.povray.org>
curved
> >> I cut it in half?
> >> - Chaanakya
> > #version 3.6;
> > global_settings {
> >    max_trace_level 256
> >    ambient_light White
> >    assumed_gamma 1.0
> > camera {
> >    location <10,0,0>
> >    look_at <0,0,0>
> > light_source {
> >    <0,100,0>
> >    color White
> > plane {
> >    y, -10
> > difference {
> > point error?
Ah I understand.  Thank you!  Is there any way to now cut that object in half
(without ending up with a plane "capping" it)?
- Chaanakya
Date: 26 Jul 2012 10:49:35
Message: <501158ff$1@news.povray.org>
Am 26.07.2012 16:31, schrieb Chaanakya:
curved
>>>> I cut it in half?
>>>> - Chaanakya
>>> #version 3.6;
>>> global_settings {
>>>     max_trace_level 256
>>>     ambient_light White
>>>     assumed_gamma 1.0
>>> camera {
>>>     location <10,0,0>
>>>     look_at <0,0,0>
>>> light_source {
>>>     <0,100,0>
>>>     color White
>>> plane {
>>>     y, -10
>>> difference {
>>> point error?
Yes: Introduce a plane to the difference.
Note how the plane only "caps" the object at the resulting cuts, in this
case the walls of the tube. Before that, what you cut was a solid cylinder.
You need to think in terms of solid bodies (after all it's called CSG =
Constructive Solid Geometry): If you have a solid cylindrical object,
and a big planar tool to "disintegrate" part of it, your remaining
object will be a solid semi-cylinder. OTOH, if you have a solid
cylinder, use a cylindrical tool to "disintegrate" a cylindrical part at
its center (giving you a tube with a measurable wall thickness), and
then use that big planar tool, your remaining object will be a half-pipe
(with a measurable wall thickness).
Date: 26 Jul 2012 10:55:00
Message: <web.50115a06c440f4797f523b7e0@news.povray.org>
but
curved
> >>>> I cut it in half?
> >>>> - Chaanakya
> >>> #version 3.6;
> >>> global_settings {
> >>>     max_trace_level 256
> >>>     ambient_light White
> >>>     assumed_gamma 1.0
> >>> camera {
> >>>     location <10,0,0>
> >>>     look_at <0,0,0>
> >>> light_source {
> >>>     <0,100,0>
> >>>     color White
> >>> plane {
> >>>     y, -10
> >>> difference {
> >>> point error?
Okay that makes sense.  Thank you so much clipka and warp! :)  You guys are
awesome :D
- Chaanakya
Date: 26 Jul 2012 10:57:35
Message: <50115adf$1@news.povray.org>
Just a hint: maybe this is described in the manual...? It is really
worth reading and the writers have done a great job; they must feel
frustrated if their work is not appreciated or used...  ;-)
Date: 26 Jul 2012 11:30:01
Message: <web.50116179c440f4797f523b7e0@news.povray.org>
> Thomas
I did read the manual.  I think I didn't completely understand exactly how CSG
worked (and clipka cleared that up for me).  Maybe I didn't search thoroughly
enough.  I did find how to cut a sphere in half somewhere in the manual, and I
tried copying that at first.  I didn't realize that the reason the cylinder
looked solid was because of other issues (not cutting the second cylinder out
properly).  Also, the example given in the manual with the hemisphere uses an
intersection, and the eventual solution here used a difference.  Yes, it's
pretty much the same thing, but as I said, I didn't really understand how CSG
worked.  I've actually been using the manual pretty heavily ;)
