Hey guys! I'm getting a puzzling image from POV-Ray and I thought you guys
might be able to help:
When I render the following POV-Ray source file, I get parts of the inner cube
which are semi-transparent. I don't think that should be happening. Take a
look:
#version 3.6;
global_settings {
max_trace_level 256
ambient_light White
assumed_gamma 1.0
location <10,0,0>
look_at <0,0,0>
//rotate <0,0,-clock*90>
light_source {
<1000,1000,0>
color White
plane {
y, -10
pigment { hexagon Green, White, Blue }
box {
<-0.99,-0.99,-0.99>,<0.99,0.99,0.99>
checker Red, Yellow
difference {
box { <-1.3,-1.3,-1.3>,<1.3,1.3,1.3> }
box { -1,1 }
transmit 1
finish {
ambient 0
diffuse 0
conserve_energy
reflection {
1.0
fresnel on
specular 0
roughness 0.001
interior {
ior 1.5
The ior of the covering box is 1.5, which is that of glass if I'm not mistaken.
So why is there transparency of the inner cube?
Sincerely,
Chaanakya
> look:
> #version 3.6;
> global_settings {
> max_trace_level 256
> ambient_light White
> assumed_gamma 1.0
> camera {
> location <10,0,0>
> look_at <0,0,0>
> light_source {
> <1000,1000,0>
> color White
> plane {
> y, -10
> box {
> pigment {
> checker Red, Yellow
> difference {
> box { -1,1 }
> pigment {
> transmit 1
> finish {
> ambient 0
> diffuse 0
> conserve_energy
> reflection {
> 1.0
> fresnel on
> specular 0
> roughness 0.001
> interior {
> ior 1.5
> Sincerely,
> Chaanakya
My main issue is the transparency of the solid box when the outer box has an IOR
of 1.5 - the solid box should not be even slightly transparent! Is there
something I'm doing wrong? Is this a bug?
- Chaanakya
Am 24.07.2012 22:02, schrieb Chaanakya:
The inner box isn't transparent - it just looks like that because the
outer box reflects the pattern of the ground.
Rotate the ground plane by y*15 (for instance) to see what I mean.
Okay. That makes sense. But shouldn't the image change if I give it an IOR of
-1.5 (instead of 1.5)? There's no change in the image.
Thanks for your help!
- Chaanakya
> - Chaanakya
An ior of -1.5! I've tested with negative ior and it gives me a perfect
mirror. You are beter to use finish{reflection 1}
This makes sence since the ior is the ratio between the speed of light
in vacuum and it's speed inside the material.
Inside_Light_Speed = c/ior.
A negative ratio means that the direction of the light is reversed.
With an ior of zero, the result is undefined: Divide by zero.
In your sample, you use reflection{1.0 fresnel} (a prefect mirror! )
whitch is equivalent to reflection 1. Note the single reflection value.
As you also have conserve_energy, the 100% reflection means that you
have 0% transmition. In this case, fresnel have no effect, and the ior
is useless.
To get a correct result, you should use:
finish{reflection{0, 1 fresnel}conserve_energy}
interior{ior Your_ior}
> > - Chaanakya
> is useless.
> Alain
I was told in this thread
(http://news.povray.org/povray.unix/thread/<web.500560817fd5a6c37f523b7e0@news.povray.org>/)
that I should be fine using
pigment { transmit 1 }
finish { reflection { 1 fresnel on } conserve_energy }
interior { ior -1.5 }
as conserve_energy would ensure that the correct amount of light was
transmitted/reflected.
Also, I was told (and the same message is in the docs) that reflection { 1 } is
the same as reflection { 0,1 } because by default it assumes reflection { 0,n }
where n is the float you give it.
Thanks!
- Chaanakya
Am 25.07.2012 03:30, schrieb Alain:
When the "fresnel" keyword is used, a single reflection value is always
taken to mean "0, X".
Am 25.07.2012 04:41, schrieb Chaanakya:
There was never a mention of negative ior :-P
Am 25.07.2012 00:45, schrieb Chaanakya:
There is, if you pay close attention. For instance, the total internal
reflections are gone.
That said, as has been mentioned before a non-positive IOR is physically
nonsense. (Metals have a complex IOR, but that's an entirely different
story.)
Try something like 1.0, 0.5 or 2.34567.
> story.)
No natural materials have a negative index of refraction, but metamaterials do -
https://en.wikipedia.org/wiki/Negative_index_metamaterials
Hmmm...I see what you mean. Okay, so essentially there's no transparency, the
image is just being reflected. Thanks for clearing that up!
